B&M Gated Shifters Available @ Alternative Offroad - Polaris RZR Forum - RZR Forums.net
 6Likes
  • 1 Post By Bizill
  • 1 Post By RZR_Joe
  • 2 Post By Bizill
  • 1 Post By captjack
  • 1 Post By Bizill
post #1 of 13 Old December 19th, 2018, 05:09 PM Thread Starter
AlternativeOffroad's Avatar
First Name: James
My RZR: XP4 Turbo
Member #27877
Feedback Score: 28 reviews
View AlternativeOffroad's Photo Gallery(0)
We have both versions available- stock replacement or Hill Killer
Stock replacement is a trigger activated gated shifter, and the Hill Killer allows you to shift from Drive (past Park) and straight into reverse by slamming the shifter forward when you find yourself about to tip backwards on a hill climb
These shifters are made by B&M, the legendary shifter company!
They have been flying off the shelves. Let us know if you have any questions!
https://www.alternativeoffroad.com/B...it_p_4457.html
https://www.alternativeoffroad.com/B...t-_p_4458.html
Name:	Screen Shot 2018-12-19 at 4.09.26 PM.png
Alternative Offroad- Your #1 Source for Offroad Lighting & Accessories
From Parts & Accessories to Full Builds!
21133 Superior Street
Chatsworth, CA 91311
[email protected]
www.facebook.com/AlternativeOffroad
Instagram: AlternativeOffroad
(818) 725-1020
AlternativeOffroad is offline
post #2 of 13 Old December 19th, 2018, 06:42 PM
RZRdavid's Avatar
First Name: David
Member #161625
Re: B&M Gated Shifters Available @ Alternative Offroad
Does the Hill Killer gate "R-N-L" or "R-N-L-H" together?
The standard one; you have to depress the trigger to change to any position?
Can you clarify?
RZRdavid is offline
post #3 of 13 Old January 24th, 2019, 03:26 PM
Bizill's Avatar
My RZR: 2016 XP 1000
Member #261600
View Bizill's Photo Gallery(0)
Can you clarify?
You've probably already found pics for yourself and can see it gates R,N,L together and you'd need to pull the lever to get into Park and High. I'll know for sure soon enough as I just bought from Alternative Offroad, the hill killer model.
RZRdavid likes this.
Bizill is offline
post #4 of 13 Old January 24th, 2019, 03:52 PM
RZR_Joe's Avatar
Member #23438
Feedback Score: 6 reviews
From P you pull the shifter to engage R. Then you can shift from R N L by pulling/pushing the shifter without depressing the lever. The lever then needs to be depressed again to engage H. So basically P & H are locked out by the lever (gates). The is so it can be slammed from H or L straight to R without over shifting into park. Comes in handy when climbing steep hills and you need to engage R quickly to prevent a rollover
RZR_Joe is online now
post #5 of 13 Old January 24th, 2019, 03:57 PM
Bizill's Avatar
Member #261600
Not sure if I'll have to make any fine-tuned adjustment when I install mine, but what I'm really looking forward to is not having to hunt for gears anymore. Hot damn it gets old really quickly. And that's not even during a stress situation but rather normal shifting even pulling into and out of the garage!
Bizill is offline
post #6 of 13 Old January 25th, 2019, 05:20 AM
RZRCrawlin's Avatar
My RZR: 2017 RZR XP4T
Member #17965
View RZRCrawlin's Photo Gallery(0)
What's the difference between the two shifters?
Sent from my SM-G935V using RZRForums.net mobile app
Let me know if you're heading to Sand Hollow to rock crawl!
RZRCrawlin is offline
post #7 of 13 Old January 25th, 2019, 02:31 PM
Bizill's Avatar
Member #261600
Hill killer...
With the other model you have to pull the lever to shift in/out of any and every gear.
RZRCrawlin and RZRdavid like this.
Bizill is offline
post #8 of 13 Old January 25th, 2019, 08:27 PM
captjack's Avatar
Member #138537
View captjack's Photo Gallery(0)
I bought the Hillkiller, works awesome!! Love not having to search for reverse all the time. If you're in H, you just push it and it stops in R.
You pull the trigger to get it out of P and into R, then you just pull to L, then grab the trigger and pull for H. It works really well!!
captjack is offline
post #9 of 13 Old January 26th, 2019, 05:22 AM
RZRdavid's Avatar
First Name: David
Member #161625
Excellent, thanks.
RZRdavid is offline
post #10 of 13 Old February 1st, 2019, 12:54 PM
Bizill's Avatar
Member #261600
Got my shifter the other day and installed it. Not bad at all. Had to adjust my shift cable a bit which is no biggie. Haven't taken it on a ride yet but looking forward to it. Playing with the shifting in my driveway and things feel pretty smooth. I like it. I added the blue accent insert for a bit extra cost...
Bizill is offline
post #11 of 13 Old June 18th, 2019, 03:33 PM Thread Starter
First Name: James
My RZR: XP4 Turbo
Member #27877
Looks amazing!
[email protected]
(818) 725-1020
post #12 of 13 Old June 18th, 2019, 04:25 PM
Bizill's Avatar
Member #261600
I like it a lot. Only small issue is after I've adjusted the cable the best I can, chasing back and forth, Park is the only one to give me issues at times. I might have a stretched cable causing the issue or perhaps B&M should add just a bit more space to the gate plate for the parking position. I could possibly file it down and keep the same angle but I'll wait to see if it ever gets worse. It's been a few months now. All the other gears shift as they should. I can adjust to go into Park better at the expense of barely getting into reverse. So I'll leave it as-is.
Love it regardless and would definitely buy it again.
Bizill is offline
post #13 of 13 Old June 19th, 2019, 06:35 AM
RZRdavid's Avatar
First Name: David
Member #161625
I bought the Hill Killer and really like it.
High quality product, easy install and functions exactly how I wanted/needed it to.
Very pleased with the B&M gated shifter, only issue...I wish I would have installed it sooner.
One note, it is a little tricky to adjust for proper engagement. Take the tools with you to adjust on the trail. It took a couple tweaks to get it perfect. Adjustment was expected, but kind of surprised what one or two threads made. It's a precisely milled piece and required a fairly precise adjustment.
I've already used the Park position lock, very nice deterrent.
My riding partner has the "other" version. Very annoying to have every gear position gated. It was gift from his kids, so no complaints. But I told him which detent to remove to make it like mine.
Value meter = Very high
RZRdavid is offline
Rigid Industries LED Lighting @ Alternative Offroad AlternativeOffroad Alternative Offroad 74 January 9th, 2014 11:43 AM
The Alternative Offroad F150 Got Wrapped! AlternativeOffroad Alternative Offroad 6 September 26th, 2011 03:02 PM
Alternative Offroad is a Supporting Vendor! 4Nines Alternative Offroad 6 August 8th, 2011 04:12 PM
Radio Headset Bracket & Other Stuff from Alternative Offroad loderup General RZR Discussion 11 August 8th, 2011 09:59 AM
