Wheel Offset |
August 16th, 2008, 03:55 PM
Wheel Offset
Can someone explain to me the wheel offset. what does the " 5+3 " mean?
Re: Wheel Offset |
August 16th, 2008, 04:14 PM
First Name: Nick
My RZR: '08 RED
Re: Wheel Offset
distance in inches from outside wheel edge to mounting surface to inside wheel edge. an easy to adjust track width.
Re: Wheel Offset |
August 16th, 2008, 04:28 PM
First Name: steve
My RZR: 08 red rzr
Re: Wheel Offset
yeah but just backwards of what he said....5" is inside lip to mounting surface and 3" is how far it will stick out from flat of hub......4+4 would be a perfect centered 8" wheel.......oh and a 5+3 with 26" tires make you 55" wide in the rear....
 hc pistons,port work,valves, springs,guides,clutch kit,bored throttle body, pushrods,cam,and oil cooler from hpd,maier hood,black t-7 w/red beadlocks,maxxis 4-speeds,mb cage,LTE SINGLE, dragonfire airbox,lonestar brace and gussets,utvcrap tubes,pro ALUM bumper,emp skid,crow 4point. pcIII ,hotride ecu,custom gusseting,shawz panels and +4 with fox shocks,billet handle, cupholders, speedo, rails, cap,shifter ,polaris suspension seats, piaa lights
Re: Wheel Offset |
August 16th, 2008, 10:27 PM
Re: Wheel Offset
Thanks for the help. I am looking into the 14" Widestance itp's with the 26" maxxis Bighorns. cant wait! just need to sell my truck and I will be in the market.
Re: Wheel Offset |
August 17th, 2008, 03:55 AM
First Name: Jonathan
My RZR: Red
Re: Wheel Offset
i get the 5+3 but what if it is a 7" rim and you can get it in either a +10mm or a -47mm which one would you need so not to have to get spacers
Re: Wheel Offset |
August 17th, 2008, 08:17 PM
Re: Wheel Offset
I'm not familiar with this way of specifying the offset. I assume zero is a centered mounting hub (4+4 for an 8" rim) and so a negative offset to mean narrower...so that's not what you need. And 10mm of offset isn't enough to even bother mentioning...
Now a 2-Rzr household.
http://tinyurl.com/8ltm8
Re: Wheel Offset |
August 17th, 2008, 09:05 PM
First Name: steve
My RZR: 08 red rzr
Re: Wheel Offset
a +10 is 10mm from center towards outside which is close to a 4+3
and a -47 is more like a 2+5.......not exact numbers but if you wand exact figure 25.4mm per inch x7 inch wheel....then go to center and positive towards front and negative towards rear.......the auto industry uses this method (metric) hope this helps oh and remember that a 7' wheel or any other measurement is bead to bead and does not include lip which on a beadlock itp for example a 4+3 is actually a 4+3.5 when you add the beadlock......and so on
Re: Wheel Offset |
August 18th, 2008, 07:57 AM
Re: Wheel Offset
So a negative offset in this spec is wider?
Re: Wheel Offset |
August 18th, 2008, 08:15 AM
First Name: Nick
My RZR: '08 RED
Re: Wheel Offset
Will Make The Track Width Wider, Yes!!
