Re: Omf Beadlocks & Wheels
Zuk, I'll have to get back to you on the spring rates. It does have the Elkas but I went with the upgraded Eibach springs. Dual rate 36mm up front and the larger 46mm bodies in the rear. I will have the trailer home this weekend and will get the rates for you. It rides great, but will bottom out the rear with two people if catching ALOT of air in the dunes, but I also have a pretty heavy cage on it now which I didnt when I ordered the LT. Might have to raise the springs rates a bit now...
