Will they clear?
Old August 12th, 2008, 06:44 AM
Muddawg Muddawg is offline
Will they clear?
I was told that 27" Bighorns on ITP SS112 rims(2+5 offset) would not rub. Is this true? Having trouble finding the SS112 5+3 offset. Was looking at 26" BigHorns on 14" SS112 wide offset rims, but can't find the rims and was told the above would not rub?? Anyone know before I order..
08 RZR
26" Bighorns, SS112's, Snorkeled, stereo
Re: Will they clear?
Old August 12th, 2008, 07:16 AM
simadownow6988 simadownow6988 is offline
If your not 1st,Your last
First Name: Jon
My RZR: 2009 RZR S!!!!
Tire and wheel questions dont get much response sometimes because everyones opinion is different.
I just ordered 27 inch Bighorns mounted to some 12 inch T7 Beadlocks. I ordered them in the Rhino 4/110, 5+2 rim, then I am going to run 1.5 inch spacers. That will get me at 56 inches wide in rear. I think you will have a problem with the 27s on a stock RZR. I will be putting a 3" lift on mine, and Im still not for sure if they will rub in the front.
Old August 12th, 2008, 07:25 AM
Baditude's Avatar
Baditude Baditude is offline
I have 27" Swamplites on 14" SS112s no spacers and they do not rub. I have the 2" lift kit though
Old August 12th, 2008, 07:53 AM
First Name: Jon
Remember, the 27 inch Bighorns are actually very close to 28 inches tall.
Old August 12th, 2008, 08:25 PM
Old August 13th, 2008, 12:59 AM
crutch's Avatar
crutch crutch is offline
The Front Will Rub In Turns In The Rough Stuff I Have The 27 Big Horns On 5x2 Offset , Rhino Wheels 212's And 1.5 Spacers And 3" Lift
Old August 13th, 2008, 05:24 AM
crutch, They don't rub with the 3" lift do they?
Old August 13th, 2008, 06:53 AM
First Name: Jon
crutch, I have that same setup coming in for mine. What kind of clutching and belt did you use? Notice any problems with your setup? Do you recommend clutching and did you notice a difference?
Old August 20th, 2008, 12:50 PM
crutch's Avatar
yes they rub a little
