Rims & Tires 12" vs 14" Pros & Cons?
This is a discussion on Rims & Tires 12" vs 14" Pros & Cons? within the Wheels and Tires forums, part of the General RZR category; Ok I know it has been brought up before. What are the positives and negatives with 12" vs 14" tire wheel combos and performance? Does ...
Go Back   Polaris RZR Forum - RZR Forums.net > General RZR > Wheels and Tires
Old August 10th, 2008, 11:21 AM
Camlsr's Avatar
Member #2959
View Camlsr's Photo Gallery(0)
CA Rims & Tires 12" vs 14" Pros & Cons?
Ok I know it has been brought up before. What are the positives and negatives with 12" vs 14" tire wheel combos and performance? Does the 14" combo afffect milage? I am looking at buying new tires and rims. Any help is appreciated!
Old August 10th, 2008, 12:12 PM
hotlicks2go's Avatar
Member #2809
View hotlicks2go's Photo Gallery(0)
Re: Rims & Tires 12" vs 14" Pros & Cons?
The only real differance is wheel weight vs. rubber (tire) weight and the fact the sidewall will be less on 14, more on 12's. 12" tire may flex more due to taller sidewall. 14" may feel stiffer. I guess it all depends on the application you are using it for. 14" are now coming with tons of tire size options now. Paddles will be in 12"
Old August 10th, 2008, 12:38 PM
Camlsr's Avatar
Member #2959
Cool Thanks for the input. I think I will need to stick to the 12's We ride in the high desert gravel , sand & rocky terrain. I have little chunks off of the stock tires allready on the sidewalls from rocks and thick brush.
Old August 10th, 2008, 01:17 PM
Member #2809
Yeah, I ride in high desert as well, sometime through some very rocky terrain. I perfer the 12" due to extra rubber give and wheels are a bit more protected from rocks.
Old August 10th, 2008, 07:51 PM
Camlsr's Avatar
Member #2959
Right on you understand the conditions. Thanks
Old August 12th, 2008, 10:01 AM
Gunfighterdusty's Avatar
Old West Reenactor
First Name: Dusty (Another Mike who uses his middle name cause there's enough Mikes here now)
My RZR: Red 08 & Green 08
Member #2916
View Gunfighterdusty's Photo Gallery(29) Send a message via AIM to Gunfighterdusty Send a message via Skype™ to Gunfighterdusty
I ride a little Glamis and alot of our river bottom here. River bottom has river crossings, quick sand , rocks, brush and silty dust. What a mess. I put the Polaris brand 14in. w/ Goodyear Rawhide MT/R and didn't notice a loss in power. I also fit thru the 50 in. wide post in the ground at Gorman (Hungry Valley) for the ATV Trails.
Old August 13th, 2008, 06:48 PM
Member #2809
What is the wheel / tire width of those? Are the wheels still 6" wide with 8" tires on Front... 8" wheel w/ 10" tire on back? Also have you measured the width of the front/rear? Very curious to know of other options besides the Polaris 12" wheel. Keeping stock width. Thanks.
  #8
Old August 14th, 2008, 10:18 AM
Old West Reenactor
Member #2916
I haven't measured the width but the rims I got from the dealer are Polaris brand called "Crushers" They are in catalog from Polaris.
  #9
Old August 14th, 2008, 09:40 PM
Member #2809
Oh, I'm pretty sure those will measure over 50". The only thing that I know of and have found are the Polaris 12" aluminum wheels. They keep me 50" wide. 14" Crushers and Bruisers that I've seen take it to 52-54".
  #10
Old August 15th, 2008, 06:20 PM
Camlsr's Avatar
Member #2959
I have a 6" Lone travel I can measure but I do not think in this case it would matter. Thanks for the replies! My RZR is + 12" total width. I think the rear measurement was like 63" for the rear . I ride in the desert mostly.
Bookmarks
Front swaybar removal Pros & Cons MotoXXX Suspension 28 June 6th, 2009 08:21 PM
26" ITP Mudlite XTR tires on ITP SS108 Rims Re-doo RZR's and Parts 6 September 11th, 2008 09:09 AM
"Cheaper" beadlock rims? ITP T7 seem a bit $$$ michael Wheels and Tires 8 July 4th, 2008 06:19 PM
Are the 14" Bruiser Rims/MTR Tires the right choice??? jake Wheels and Tires 17 May 27th, 2008 10:16 PM
Any running 8" ITP rims and 26" Bighorns? BigSilly450X General RZR Discussion 1 September 27th, 2007 08:50 PM
