Re: HELP!! Confused 12 inch rims or 14 inch
  #16 (permalink)
Old July 5th, 2008, 11:16 AM
BIG ISLAND KART SHOP's Avatar
First Name: JASON
Rock crawling- 12''s all the way
  #17 (permalink)
Old July 5th, 2008, 06:08 PM
jerrzr's Avatar
jerrzr jerrzr is offline
I have 14" beadlock itp wheels with 26X9 front and 26X11 rear bighorns. Last night on windrock cut my rear sidewall with a rock. I still rode for about 3 hours on a flat. Does anybody know how to fix a 2inch cut in the sidewall? Will that green slime stuff fix it?
J & T
  #18 (permalink)
Old July 9th, 2008, 06:04 PM
rbwapiti rbwapiti is offline
New tire and probably a new wheel after three hours.
  #19 (permalink)
Old July 10th, 2008, 11:20 AM
jerrzr's Avatar
The wheels fine, having true beadlocks the tire never came off the wheel. I can tell you that the bighorn tires are tuff. The only damage to the tire after riding it on a flat for so long is that it wore down my side traction quite a bit. I put five tire strings in the sidewall and have put about 20 miles on it since. I dont trust it but its holding for now.
  #20 (permalink)
Old July 10th, 2008, 07:36 PM
Muddawg Muddawg is offline
Originally Posted by gdog View Post
I got my 14" 108's and 26" Bighorns yesterday. Took them for a short spin today and really like the setup. I don't do any hard core rock crawling and such, so I'm not worried about the 14" wheels being much of an issue.
Looks sweet! Now need to decide lift or not????
Do you need a lift for the 26's? I wanted the 27's on ss108's but that combo doesn't come in 156 bolt pattern... Any idea the offset you got and are you running spacers? Thanks
08 RZR
26" Bighorns, SS112's, Snorkeled, stereo
