How long does CO2 last??? - Polaris RZR Forum - RZR Forums.net
post #1 of 7 Old June 5th, 2010, 04:30 PM Thread Starter
txwpd103's Avatar
Does anybody know how I can calculate how long a CO2 tank will last at a particular psi and cfm. For instance, if my requirements are 4.5cfm at 60psi. The only measurements I can find for CO2 tank is there capacity in lbs. Any help is appreciated.
Sleep safe in your beds knowing rough men stand ready in the night to visit violence on those who would do you harm.
__________________________________________________ __
UMP airfilter, Custom Cage, Custom Rear Rack, Custom Doors, Rear Chassis Brace, ProComp Gauges, Rugged Intercom, 2" Rubberdown Lift, Comm Radio, Custom Soft Top, 4000lb Winch, Half windshield, DunerTunes amp/speaker pods, Odyssee PCL925, Holz Grill, 4pt. Harnesses, Rear wheel spacers, pnp HIDS, 4x VisionX Solstice, Parking Brake, RacerTech Dual Rate Springs.
txwpd103 is offline
post #2 of 7 Old June 5th, 2010, 08:12 PM
RMR Man's Avatar
Re: How long does CO2 last???
I'll run the calcs for you if you can fill me in:
What do you need to power and for how long do you need 4.5 cfm? That's a pretty fair amount of volume.
RMR Man is offline
post #3 of 7 Old June 5th, 2010, 08:17 PM Thread Starter
txwpd103's Avatar
Originally I was wanting to provide air to a Hypertherm 380 plasma cutter until I found out that it wont arc with Co2. Now just wanting to know how long I could run an impact wrench or cutoff tool say on a 20lb tank.
txwpd103 is offline
post #4 of 7 Old June 5th, 2010, 08:37 PM
King of crash!
Send a message via Yahoo to johnnycat8
i have a 15 and a 20 lb tank and the 20 lb will fill 6 trucks with 31 to 33 in tires from 20 psi to 70 psi and run a impact to change all our sxs's tires sevrall times 5 sxs's and also fill tires on them all weekend....and have never run out .... a cutout tool will use alot.
a 15lb tank has 120 cuic ft of air or 900 gall of air
johnnycat8 is offline
post #5 of 7 Old June 5th, 2010, 08:42 PM Thread Starter
txwpd103's Avatar
Thanks for the info. I am definately leaning this direction.
txwpd103 is offline
post #6 of 7 Old June 5th, 2010, 08:51 PM
I just wanna ride
RZR Jeff's Avatar
The impact generally uses short burst of air/co2. So you can use a 20lb. tank to change a few sets of tires. A cutoff tool / die grinder sucks up air like crazy. You will empty a 20lb. tank in just a few minutes.
RZR Jeff is online now
post #7 of 7 Old June 5th, 2010, 08:58 PM
RMR Man's Avatar
A 50# cylinder of CO2 will be mostly liquid, which is where you get the big volume numbers. Compressed air, on the other hand is always in a gaseous state, and therefore the volume is very low for even a large diameter cylinder. Most hobby shop air compressors have about a 20 gallon tank. Air is measured in gallons, CO2 in pounds because of it's liquid state.
With the proper regulator, and keeping the CO2 tank between 60 and 90 degrees (slows the gassing rate) you should be able to use your impact off and on for weeks. This is a really tough calculation. Here are the variables: are your hose fittings tight? Is the tool working like new, or are the rotary vanes worn to the point that the efficiency has dropped? Are you doing routine tasks, or are you breaking rusty or corroded farm machinery fasteners?
Remember, air motors are extremely inefficient in performing tasks. They eat air like it's going out of style. We use electric tools when possible, as there is no waste. Electricity is 100% efficient. Air tools are never better than 50 % effecient. You need to have electricity to compress the air, then you need the air to run the tool. Makes sense! If you are looking for portability, I would go rent a 50 pound CO2 tank and the correct regulator for 4.5 cfm. There are many different regulators for beer kegs, soft drink fountain machines, HVAC servicing to blow debris out of coils etc.
This is a tough question with no pat mathmatical answer. Sorry.
RMR Man is offline
Considering long travel TPL33 Suspension 9 November 23rd, 2009 09:29 PM
Do I really need long travel. saw8279 Suspension 19 November 7th, 2009 08:48 PM
Looking for a long travel kit 3240 RZR 170 Specific Disccusion 11 June 27th, 2009 03:07 PM
Long travel? hot rod RZR 170 Specific Disccusion 3 April 24th, 2009 11:06 PM
