29.50-10x12 Swap Lites All Around
This is a discussion on 29.50-10x12 Swap Lites All Around within the Wheels and Tires forums, part of the General RZR category; JUST INSTALLED 29.50-10X12 SO THE TIRES SIZE IS THE SAME FRONT AND REAR. I was just wondering, the front tires look alot taller than the ...
Go Back   Polaris RZR Forum - RZR Forums.net > General RZR > Wheels and Tires
Old May 31st, 2008, 05:04 AM
dls64chev's Avatar
Member #1809
View dls64chev's Photo Gallery(0)
JUST INSTALLED 29.50-10X12 SO THE TIRES SIZE IS THE SAME FRONT AND REAR. I was just wondering, the front tires look alot taller than the rears. Is this going to be ok or am i going to screw something up.
They are on stock rims and I would say the difference is about 1/2 inch.
thanks drew
2008 polaris rzr
2005 Honda crf450x
2008 Siverado Vortec Max
2006 700 Fusion/136
Old May 31st, 2008, 05:53 AM
gsxr's Avatar
Member #2473
View gsxr's Photo Gallery(0)
Re: 29.50-10x12 Swap Lites All Around
You may not have enough power to turn those big babbies !
Old May 31st, 2008, 06:12 AM
dls64chev's Avatar
Member #1809
Can Always Make More Of That.
2008 polaris rzr
2005 Honda crf450x
2006 700 Fusion/136
Old May 31st, 2008, 08:38 AM
gtmcgeejr's Avatar
Member #2498
View gtmcgeejr's Photo Gallery(0)
you'll have pleanty of power for those. I run 30" mudlites and they are the same way the front looks taller than the back. You want hurt anything.
Old May 31st, 2008, 01:19 PM
Schwenddog's Avatar
First Name: Steve
My RZR: Still dont have one, but want a green one! Its getting Close!
Member #2378
View Schwenddog's Photo Gallery(0)
Mwink Re: 29.50-10x12 Swap Lites All Around
Where's the pics? I want to see the Swamplites. How do you like them so far?
Old May 31st, 2008, 03:36 PM
gtmcgeejr's Avatar
Member #2498
here's my 30ies on flipped rims.
Old June 1st, 2008, 12:08 PM
Schwenddog's Avatar
First Name: Steve
Member #2378
Laughing Re: 29.50-10x12 Swap Lites All Around
So you just flipped the rims to make them a little wider? Right on. Those are 30" wow they look great. Nice that is what i am looking to buy, but with the rumors of Polaris coming out with a HO 850 RZR in Late July, i might just have to wait for the big Dog!
  #8
Old June 1st, 2008, 08:43 PM
dls64chev's Avatar
Member #1809
gear ratio should not be a problem then
2008 polaris rzr
2005 Honda crf450x
2006 700 Fusion/136
  #9
Old June 2nd, 2008, 05:11 AM
dls64chev's Avatar
Member #1809
Thats weird, my 29.50 will not fit on the front, rubs like crasy on the inner fender. The 3 inch lift should cure that though.
2008 polaris rzr
2005 Honda crf450x
2006 700 Fusion/136
  #10
Old June 2nd, 2008, 10:49 AM
dls64chev's Avatar
Member #1809
well got the tires on and took out for the first ride. We'll just say that these tires are not what I would consider road worthy as they seem to whobble alot. Anybody else experience this with swaplites or any other mud tire.
2008 polaris rzr
2005 Honda crf450x
2006 700 Fusion/136
  #11
Old June 2nd, 2008, 04:27 PM
gtmcgeejr's Avatar
Member #2498
any heavy mud tire rides like that. However some better than others. Mine seem to be fine even at 40mph.
  #12
Old June 4th, 2008, 06:23 AM
dls64chev's Avatar
Member #1809
checked with the people I purchased the tires from and said it is a common problem and they are sending me a new tire. Only one of the tires shakes really bad, will almost pull the wheel out of your hands.
2008 polaris rzr
2005 Honda crf450x
2006 700 Fusion/136
  #13
Old June 4th, 2008, 06:52 AM
BADRZR's Avatar
First Name: Charlie
My RZR: 2008 Red RZR 800
Member #1399
View BADRZR's Photo Gallery(0)
I'm running 31 inch outlaws with a clutch kit plenty of power
The ride at 40 or below is better with the outlaws than the 28 inch mudlites i just took off
With 3'' of lift you should clear 29.50 with no problems my 31's barely scrub with that much lift heres a few pic 17 1/2 inches of ground clearance
[IMG]http://i259.photobucket.com/albums/hh304/BADRZR/rzr002.jpg
[/IMG]
  #14
Old June 4th, 2008, 06:59 AM
BADRZR's Avatar
First Name: Charlie
Member #1399
  #15
Old June 5th, 2008, 01:49 PM
dls64chev's Avatar
Member #1809
badrzr I dont see the sway bar relocation brackets on the front of your machine. whats the deal with that.
2008 polaris rzr
2005 Honda crf450x
2006 700 Fusion/136
27 all around
Bighorns or Swamp Lites walbright Wheels and Tires 6 November 21st, 2008 10:11 PM
RZR Frame Swap Molsondrinkr Projects and How-To 28 October 30th, 2008 09:09 PM
28" mud lites on 14 have slices and knobs coming off birdmanf250 Wheels and Tires 1 July 11th, 2008 11:39 AM
Swamp Lites? Schwenddog Wheels and Tires 12 May 25th, 2008 09:39 AM
How to make 27" Swamp Lites Fit my stock RZR kuss22 Wheels and Tires 45 March 28th, 2008 01:55 PM
