This is a discussion on Tires on the right way ???? Terracross within the Wheels and Tires forums, part of the General RZR category; Hey guys, I just noticed something, and not sure the answer... Look at my pictures below and tell me if the tires are on the ...
Look at my pictures below and tell me if the tires are on the correct way ?? I never noticed cause the dealer put them on for me..... Are they on the correct sides ?? or should the grouves be pointing the other way... ???? They are different on both sides... I see the ITP website shows both (opposite of mine) and some of the other gallery pics of peoples quads some go the other way ! Whats your experieince ? should I change them around (one side at least )LOL Mac |
| Sponsored Links | ||
Re: Tires on the right way ???? Terracross
the driver side are mounted the wrong way. the passenger side are correct.you will have to dismount the driver side and turn the tires around and remount them.
Thanks thats what I thought too, but on some quads and video's on itp site show different. Ie; Drivers side is backwards
sooooo which is correct ????? Mac |
They are correct, it does not matter which way they are mounted they are not a directional tire. I have had 3 sets now.
I believe either way is correct. Based on the side lugs, the driver side will try to keep you in the ruts more, but should clean out better. The passenger side will help to pull out of ruts (or get side bite) but won't clean out as well. Again, that is strictly the side tread I am talking about, I don't know what the center tread looks like.
Not mentioned so far is that on a non-directional tire like the Terracross when the lugs get worn and rounded you can swap your tires left/right and expose some fresh rubber.
_______________________________ Why buy the cow? Romeo, MI Last edited by guy48065; May 17th, 2008 at 07:53 PM. |
#8
Actually, on the right side (passenger) only when turning right on Hard surface like pavement etc.... there is a loud clanking noise from Passenger side front
The clanking only happens when turning and mostly 90 % when turning to the right... any ideas Mac |
#9
Thanks all for feedback
I changed the driver side to match the Passenger side.... the clanking was not a bearing, not a CVboot, not a shaft prob. but in fact when I took the front hub off to look at bearing when I loosened the bottom pinch bolt of the Bottom Ball joint, I heard it go clank and seperated a little from hub (still with bolt in) re-assembled everything, and clanking is gone... I did try tightning the castle nut and still was clanking first round.... before I decided to take the hub right off ~ I mean I really think the ball joint into the pinch bolt was causing the clanking..... I too feel like a Nascar pit crew member changing tires.... LOL anyway, those that have clanking coming from one side of front end when turning on hard packed surfaces should check the ball joint pinch bolts (don't just tighten !!!! loosen them first, then put them back on per the manual) and hopefully your clanking will go away as mine did... Mac |
#10
Mac, do you have the extra wide offset with your ss112's? If so, do your flares cover them or do the tires stick out past the flares.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| bighorns or terracross? | roadsidedoc | Wheels and Tires | 15 | May 11th, 2009 09:21 AM |
| Itp Terracross | ditch pickel | Wheels and Tires | 24 | November 22nd, 2008 05:42 AM |
| Installed My SS212 and Terracross Tires | F7 Possum | Wheels and Tires | 13 | June 16th, 2008 10:52 AM |
| Itp 14'' Ss106 W/ Terracross 26'' Tires | BIG ISLAND KART SHOP | RZR's and Parts | 3 | March 28th, 2008 04:33 PM |
| NEW ITP C-Series SportLock Wheels with ITP TerraCross tires | brad4021 | RZR's and Parts | 0 | November 6th, 2007 09:38 PM |
