Wheel Spacers from UM Racing Products
Old May 12th, 2008, 03:42 PM
Bena Bena is offline
Has anyone heard about this company, if so, are the wheel spacers any good?, these are made of titanium & graphite and mention that the RZR has to have 1.5" on the front & 2.5" on the rear for the stability to work best and keep the factory stand.
Any help will be appreciate it !!
Thanks !!
Re: Wheel Spacers from UM Racing Products
Old May 12th, 2008, 03:52 PM
milosusa's Avatar
milosusa milosusa is offline
My RZR: 2008 Red
Only problem I see with them that you need to replace the studs to use them and will be not so easy go back to original wide stand, if you need to . I use this kind of spacer and is very easy to take them out, but they are only 1.5 inch.httphttp://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&viewitem=&item=170210410563 #ebayphotohosting
Milos
2008 Attitude TH
04 raptor 660
06 raptor 700
08 RZR
Old May 12th, 2008, 04:02 PM
This page has all the instructions.
Performance Aluminum ATV Products from UM Performance Products
Old May 12th, 2008, 04:30 PM
milosusa's Avatar
My RZR: 2008 Red
Originally Posted by Bena View Post
Sorry, I thought it is a complete stud you need to replace, but they are just extensions. Should be not so bad, if you need to take them out.
Milos
Old May 12th, 2008, 04:44 PM
Milos
They don't look so bad, do they?
Thanks Milos, appreciate the reply !
Old May 12th, 2008, 05:07 PM
BigDogF250's Avatar
BigDogF250 BigDogF250 is offline
My RZR: 2008 RZR - Green - Built 3/25/2008
I'm not a big fan of this design because of the way it attaches. You are in essence adding 2.5" to the length of a bolt (original stud) that was never designed to support the torque that will be present. It basically "makes the lever longer" and can lead to failure of the original studs. Yes, the add on hub helps offset some of that but I much prefer a design like the one that milosusa linked to.
Just my 2 cents...
Old May 12th, 2008, 05:23 PM
milosusa's Avatar
My RZR: 2008 Red
They don't look bad and probably are very light, but I do agree with BigDog about putting to much stress on the original studs. But, if you like to have 2.5 inch I think you don't have another choice, but only go with them, because I don;t think I ever saw 2.5 inch aluminum spacer. But I could be wrong. I added 1 inch off set rims to get 2.5 inch total.
Milos
Old May 12th, 2008, 05:40 PM
Makes sense what bigdog says, and the other wheel spacers look better, I tought for a moment that this could work, the new material and all, well.
Appreciate the replies guys !!
