This is a discussion on Will Slime seal a bead leaking ? within the Wheels and Tires forums, part of the General RZR category; I do have little air bead leaking on my sand tires. Did anybody have experience with Slime helping with that problem, I know work good ...
I do have little air bead leaking on my sand tires. Did anybody have experience with Slime helping with that problem, I know work good on puncture in rubber, but not sure if seal between rims and tires too. Don't want to mess up with it, if don't work and will rather install tubes instead. Any experience with it ?
![]() milos .
2008 Attitude TH 06 raptor 734 09 Raptor 700 11 RZR XP900 Aerocharger Turbo http://czechracingteam.com/ |
| Sponsored Links | ||
Re: Will Slime seal a bead leaking ?
Slime can seal bead leaks, you need to lay tire on angle and let the slime work its way around the bead. This may require you to slowly rotate it on a tilt, this is the hard part about slime and bead leaks.
Factory UTV Skids & A-Arms, UMP Filter J-Strong Roof, Stereo & 4" HIDs ITP SS212, 26" Bighorns,WARN Winch Trinity Stage 4 pipe & Trinity fuel control, Dirty Dawg Clutch Afco MT1 shocks (with progressive springs) They're Awesome ![]() 1 Limey in a world of Yanks
I would unseat the bead, clean the sand out, and reset the bead.
______________________________________ My Links: Polaris Parts Microfiche , How to change a RZR clutch belt VIDEO Free Downloads: 2009rzr800, 2009rzr170, 2010rzr800, 2011rzr800, 2011rzr900xp, 2012-2013rzr170, 2013rzr900xp-eps, Yamaha Apex ![]() ![]() other rzr service manuals for sale here: brssm website (not affiliated with this forum) |
I had that exact problem at my dune trip in Oct. No, slime made no difference at all. The only way I got it fixed was to unmount the tires, clean everything and put it back together.
This is the stuff you need it works awsome.Stan's Tire Sealant
http://www.sharetrails.org |
I would break down the tires and clean around the tire and also the rim. Then when you reinstall the tires use a lube around the bead ( k-y jelly might work ) ,air up and go to town
Ya what he said.^
#8
best tire sealant= 8 oz liquid silver alumaseal and 15 oz undiluted antifreeze
about the only thing I found that works and was for a 1300x 15 sand car tire and rim. cant stand slime, get the valve all icky and eats inside of alum rims etc.
#9
x2 just had this done to mine... now no more leaky....
link for crow dog's site!!! www.utvguide.net running makin trax afco shocks and springs |
#10
Thanks guys, I will try first to clean and remount tires, if no luck I will try other options you guys suggested. THX
![]() milos
#11
I had the same problem. The tire shop I used cleaned the bead and then sealed it with something like Stan's Sealant and it never had another problem.
RZR Tech +3 suspension Makin' Trax MT2 Shocks W/ Progressive Springs http://www.makintraxsuspension.com/ |
#12
I had the same problem. The tire shop I used cleaned the bead and then sealed it with something like Stan's Sealant and it never had another problem. I should order some. milos
| Search tags for this page |
bead leak sealer,how to seal a leaking tire bead,how to seal a rim leak,how to seal a tire bead leak,seal leaking tire bead,sealing leaky tire bead,sealing tire rim leaks,slime bead sealer,slime tire bead sealer,will green slime seal around rim,will green slime tire repair seal a leaking bead,will slime fix a bead leak,will slime fix a leak on bead,will slime seal a bead leak,will slime seal abead
| Thread Tools | |
| Display Modes | |
| Front axel seal leaking??? | willgrizzle | Engine and Drivetrain | 7 | November 10th, 2009 10:03 AM |
| Tire slime | Hayden | General RZR Discussion | 4 | July 7th, 2009 02:43 PM |
| SLIME ???? Does it work ???? | LvDirtJunky | Wheels and Tires | 14 | January 27th, 2009 08:15 AM |
| right rear seal leaking | 06vegas | Engine and Drivetrain | 9 | January 2nd, 2009 08:03 PM |
| New RZR S water pump seal leaking! | Pimp Dog | RZR-S Specific Discussion | 6 | November 25th, 2008 11:24 AM |
