What do these numbers mean? - Polaris RZR Forum - RZR Forums.net
This is a discussion on What do these numbers mean? within the Wheels and Tires forums, part of the General RZR category; Front: 12x7 5+2 Rear: 12x7 5+2 Im looking for some rims for my standard Rzr to put stock rubber on for now I will upgrade ...
Go Back   Polaris RZR Forum - RZR Forums.net > General RZR > Wheels and Tires
Old November 12th, 2009, 04:00 PM   #1
mark408's Avatar
My RZR: 09 Standard
Member #9195
View mark408's Photo Gallery(5)
Front: 12x7 5+2
Rear: 12x7 5+2
Im looking for some rims for my standard Rzr to put stock rubber on for now I will upgrade tires later.So what does the 5+2 mean?Also what size should I run front and back 12X?
Im running a 3 inch lift and plan on progressive springs also.
Thans guys
mark408 is offline   Reply With Quote
Old November 12th, 2009, 04:04 PM   #2
Tuf-Skin's Avatar
First Name: Clifford
Member #2228
Re: What do these numbers mean?
12x7 means 12" diameter and 7" wide.
The 5+2 is the offset. So there would be 5" of wheel inside the hub and 2" outside the hub for 7" total.
12" is the most popular and there are lots of tires available.
A 26x10x12 tire would be 26" in diameter, 10" wide, and fit on a 12" wheel.
1129 what do these numbersmena
25x11.00-12 what does these numbers mean
p285/45r22, what do these numbers mean?
polaris belt belt number meaning
what do numbers mean on wheels
what do numbers on the back of wheels
what do numbers on wheels mean
what do the numbers mean on polaris rzr tire
what do the numbers on a belt mean
what do the numbers on inside wheel mean
what do the numbers on my stock rims mean
what do the numbers on wheels mean
what does 285/35/22 mean
what does 285/35r22 mean
what does the numbers on a poilaris range tire mean
Need help with part numbers or prices? blueline15 General RZR Discussion 13 October 6th, 2016 09:22 AM
DMC Exhaust with numbers to back it up giannamyhero RZR-S Specific Discussion 2 July 10th, 2009 01:44 AM
LONG TRAVEL Numbers TPL33 Suspension 8 July 7th, 2009 08:37 PM
Wheel Bearing numbers Pappy Engine and Drivetrain 4 May 11th, 2009 06:32 PM
Air filter part numbers fast eddie Engine and Drivetrain 3 August 28th, 2008 12:20 AM
