Itp Ss 108
Old April 3rd, 2008, 10:28 AM
wgladde's Avatar
wgladde wgladde is offline
My RZR: Green 08
Itp Ss 108
I would like 14" SS 108's with 26 inch Terracross tires. Is anyone running this setup? Need spacers or lift? Thanks
Re: Itp Ss 108
Old April 3rd, 2008, 06:20 PM
trapit trapit is offline
Re: Itp Ss 108
I'm running that exact setup. I noticed a little bit slower acceleration due to tire size and the weight of 14's, but they look 10 times better and really make the machine pop. I was told they have wheels set aside just for the RZR due to something in the rear suspension. All it does is give more offset and the wider stance really helps stability
Re: Itp Ss 108
Old April 3rd, 2008, 08:07 PM
BIG ISLAND KART SHOP's Avatar
First Name: JASON
Re: Itp Ss 108
I have a set of 14'' ss106's w/26'' terracross's for sale in classifieds if any one is interested.
Re: Itp Ss 108
Old April 11th, 2008, 04:37 PM
shaunt shaunt is offline
First Name: Shaun
Location: Troy, Inverness Co, Cape Breton, Nova Scotia, Canada.
Re: Itp Ss 108
Hi, shaunt here. I don't no about terracross tires but I would think they would be fine, because I have the SS112 rims w/ 27" mudlite XTR's and no spacers or lift and they don't rub in any situation. Hope this helps.
Re: Itp Ss 108
Old April 13th, 2008, 09:10 PM
wgladde's Avatar
My RZR: Green 08
Re: Itp Ss 108
Thanks shaunt Im leaning more towards 27's now. I might go with the Mud lights. Are you pleased with those tires and did you lose much power when you went to 27"s? Thanks for your help.
Will
Re: Itp Ss 108
Old April 18th, 2008, 04:31 AM
First Name: Shaun
Re: Itp Ss 108
Hollo again Will, as far as the power diff. I can't tell you because I've never ran the RZR without them, but it seems to be fine and I still get 56 mph. and the power is still there. I went w/ the SS 112's (standard)wide stance kit witch makes the RZR unbeleivably smooth and stable at any speed and the tires have very good traction in all terrains. Just a little foot note, the tread was a bit close to the RR motor mount in front of the RR tire so I cut the corner off the mount support just to be safe. With the type of susp. the RZR has in the rear the tire gets further from the mount as the susp. compresses, so I don't think it would have made contact anyway.
Re: Itp Ss 108
Old April 18th, 2008, 11:01 AM
First Name: JASON
Re: Itp Ss 108
The reason I am selling my ss106 14'' wheels w/26'' Terracrosses is because the are so heavy, They really eat up some horse power. I put light weight 4 speed tires with light weight omf beedlock wheels and it was like I gained 10 horse power.
