mixed up info
This is a discussion on mixed up info within the Wheels and Tires forums, part of the General RZR category; Hey all, So as I posted already, in someone elses thread, I am going from stock LE to aftermarket rims/tires. I read here http://www.rzrforums.net/wheels-tire...s-rubbing.html that ...
Go Back   Polaris RZR Forum - RZR Forums.net > General RZR > Wheels and Tires
Old July 2nd, 2009, 09:53 PM
liquid's Avatar
First Name: Lindsey
My RZR: 09 RZR LE sunset orange edition
Member #4177
View liquid's Photo Gallery(0)
mixed up info
Hey all,
I read here http://www.rzrforums.net/wheels-tire...s-rubbing.html that with 26" I would get slight rubbing... yet people are talking about running 28" zillas
Whats the deal??
I was wanting bigger mudding tires, and wanting to keep the weight low so I thought 28 zillas on 14" rims would be the ticket.. but if they rub when you go hard right or left... I dont want that
Whats probably the biggest size I can go with an 09 rzr? 2" lift available(not purchased), spacers if needed (rims should offset tho no?), minor minor modifications like cutting corners, heating and pushing back plastics but only MINOR stuff... I dont want to fully retro the rzr.
Thanks for anyone that can help me out here... I dont wanna waste a grand finding out they wont work.
Old July 2nd, 2009, 09:56 PM
gone!!!!!!!
Feedback Score: 6 reviews
Member #787
Re: mixed up info
i have 26 in the front and every now and then it rubs the drivers side against the back i have 2 in spacers no lift..... after i put afco shocks on (that lifted it a inch) it hasnt hit anymore and when it did it was only the left front....as to otheir tire sizes cant coment as this is what i have....
lots of toy's
Old July 3rd, 2009, 12:25 AM
liquid's Avatar
First Name: Lindsey
Member #4177
Re: mixed up info
Soo much info.. the more you read the more you get screwed up
So I read something about getting 5 rims/tires the same so you have a spare.. that sounds good... and they said to go with something not too wide so you can keep your power ^^b
Wonder if I could continue my path and get 4 28x9x14 or 4 27x10x14
Opinions?
Specs:
Zillas 6ply
28x9x14 23.1lbs
27x10x14 22.8lbs
27x9x12 20.3lbs
Not sure on rim weights :/
Old July 3rd, 2009, 06:24 PM
gone!!!!!!!
Member #787
Re: mixed up info
1 lb of unsprung weight is huge !!!!! thats up to 3 lbs per tire......
lots of toy's
Old July 3rd, 2009, 08:06 PM
liquid's Avatar
First Name: Lindsey
Member #4177
Re: mixed up info
I dont understand
I know unsprung weight is very important.. what do you mean up to 3lbs per tire?
I'm thinking still of going with the 28x9x14s... will wait a bit tho so I can get more info.
Old July 3rd, 2009, 09:00 PM
jeepster's Avatar
First Name: Dan
My RZR: 08 Green
Member #34
View jeepster's Photo Gallery(0)
Re: mixed up info
1" spacers and 27" outlaws dont rub.
Old July 4th, 2009, 12:55 AM
liquid's Avatar
First Name: Lindsey
Member #4177
Re: mixed up info
hey jeepster,
Do you have a lift as well? and what width are your 27's? What size and offset are your rims?
Have you checked at full compression hard left and right? and if you remember, does it look like you have a bit of room left, so as to accomodate a 28?
Thanks for any more info
Hatfield info! colts66 Local Rides and Events 2 February 12th, 2009 03:23 PM
FST Intake info please royalnine General RZR Discussion 1 September 14th, 2008 02:35 PM
lift kit info? bc5210 Suspension 19 September 1st, 2008 09:09 PM
Need some info and help! Dogo X General RZR Discussion 5 August 26th, 2008 06:15 PM
