Re: New Omf Beadlocks |
February 25th, 2008, 11:35 PM
Well that sucks about the mix up, but they do look very cool!
February 26th, 2008, 06:00 AM
My RZR: 2007
They look great but can you tell us how the adjustable offset works? Also do the wheels keep the machine at 50" and adjust outboard? What is the total width? Thanks!
February 26th, 2008, 06:41 AM
First Name: tony
My RZR: rhino
megadeasert diesel has those wheels.. you might wanna check with him if oyu have questions...
those wheels are very cool though.
February 26th, 2008, 07:46 AM
Rhino defector
My RZR: green gen 3 racer
OMF will make any offset wheel into a billet center.
so i matters what offset you are starting with. then you will be able to adjust about 9/16" when flipping the billet center.
i still have not decided if they are worth the money spent for them. i just ordered 17" true beadlocks for my dodge and they were $125 less for each wheel than the OMF billet centers.
February 26th, 2008, 08:08 AM
are they rubin on the exhaust too,or just the mount,are you sayin they gave you the wrong size rears? did they come with tires on them
February 26th, 2008, 08:33 AM
First Name: Nick
My RZR: '08 RED
lets get to specifics, i've got a set of reinforced wheels on order right now. i've got the utmost confidence in the crew @ omf but if theres a need for caution, lets have it!!
February 26th, 2008, 09:12 AM
Rhino defector
i have learned to deal with BONES and BONES ONLY at OMFand you will sleep better at night knowing all is good..
February 26th, 2008, 10:22 AM
First Name: Nick
My RZR: '08 RED
Cool, Thats Who I Deal With Also...he's Been Good To Me
February 26th, 2008, 11:56 AM
that,s funny I just got off the phone with him, he thinks it,s a tire problem because if the 12' rears. I have a dfr exhaust so the only problem i,m having is the motor mount. He is going to ship out a new set of tires but now I don,t know what ones to go with. I think i,m going to go with 25x9x12 or just have him ship out 2 26x9x12 rears. I don,t know , bummmmer
If you have one on order from them you should call and make sure, I should have more answers by this weekend. should of bought the long travel first.
February 26th, 2008, 12:01 PM
Let me say i,m also sure omf will fix me up. I have never had a problem with them before.
February 26th, 2008, 01:49 PM
First Name: Nick
My RZR: '08 RED
i just ordered wwheels, tires to come later. gotta get'um powder coated first!
February 26th, 2008, 07:33 PM
So my lesson for today: 26x12x12" rear bighorns Will rub with omf's 12x8 with a 5b+3n back spacing in the rear. (stock wheel base)
After talking to Bones I decided to keep the bighorns for when the long travel gets here, and he is sending me out 25x8x12 front's and 25x10x12" rear razor's. I don't know if that was the right decision but it's done now. It's only money till my wife finds out.
Bones from omf stepped up. thx
February 26th, 2008, 08:08 PM
First Name: JASON
Why Not Just Run Some Spacer's Until L.t. Kit Comes?
February 26th, 2008, 08:09 PM
Stock rear is 6+2. The only reason the stock setup doesn't rub is the 10" tires. Any 12" tire on stock offsets will be over 50" and will rub the motor mount. I have stock offset and run 11" rears and still get a little rubbing at full droop. Took care of it by grinding the mount corners off and beveling the frame tubing ends.
I talked with Bones and decided against the billet centers when he told me the offset "flexibility" they boast about in the magazine ads was only about 1/2".
Now a 2-Rzr household.
http://tinyurl.com/8ltm8
