I had some custom made...25X12-12 12 Paddle Extremes for rear (Ex ITP Mud Lites)....25X8-12 Mohawks for front (Ex Mud Lite AT with only 20/32" lugs....
They worked great...bottom end response through mid range is awesome...the take off is way better than before on sand...wheel spin at the top of Olds is still there but not as much...
We gained 4-5 mph at top of Olds from 23-24 mph originally (With 12 Paddle 26X12-12 Edges) we are now hitting the top of Olds at 28-29 mph...these speeds are with 70 lbs of Rear Seat and Roll Bar, 25 Lb Odyssey 925 Battery, Two Tool Sets, My Wife at 100 lbs (Wet), Our 3 yr old at 24 lbs, Rear Cooler 12 Pack Rack full of drinks, Two Cameras, Tow Strap, Aftermkt Hitch and 2" Ball, Other small accessories, Full Tank of fuel
Weights for Tires & Wheels:
Rears:
26X12-12 on .125 Real Wheel rims = 28 lbs each
25X12-12 on .125 Real Wheel rims = 24 lbs each
Fronts:
26X10-12 on Douglas .190 Wheels = 28 lbs each
25X8-12 on Real Wheels .125 rim = 14 lbs each
so you can see we lost a total of 28 lbs of unsprung weight off the front and an additional 8 lbs off the rear
Yes the RZR Sand setup that Fullerton is selling is not the best so I scrapped them and made my own...we did lose ground clearance that was noticable but it worked to our advantage for topping out over Razorbacks as you would drag in the center and not drop straight off...even my wife was pleased with how they handled when originally she was not impressed at all by their looks at first, but after driving around Glamis she was convinced this is a better setup...it may not be the best, but I did get close...sorry for no rear view pictures the camera died when I went to take it!...forgot to charge it
