How to make 27" Swamp Lites Fit my stock RZR
This is a discussion on How to make 27" Swamp Lites Fit my stock RZR within the Wheels and Tires forums, part of the General RZR category; I own a full set of brand new 27x12x12 rear and 27x10x12 fronts off my Brute Force and I would like to know the most ...
Go Back   Polaris RZR Forum - RZR Forums.net > General RZR > Wheels and Tires
Old February 1st, 2008, 10:55 PM
kuss22's Avatar
Member #1162
View kuss22's Photo Gallery(0)
I own a full set of brand new 27x12x12 rear and 27x10x12 fronts off my Brute Force and I would like to know the most efficent way to put these on my stock RZR. Also what is the best setup if I just sell these and go to 14" rims with some new tires? Thanks
Old February 1st, 2008, 11:42 PM
mdevans's Avatar
Member #878
View mdevans's Photo Gallery(0)
Re: How to make 27" Swamp Lites Fit my stock RZR
kus22 swamp lites are a cool looking tire. if tires are on kawi rims you have to buy wheel spacer that will convert bolt paturn to rzr. thay need to be thick enough to push tire out so you can clear motor mount. if you have just the tires i would mount them on -43 offset rims. motorsport alloys offer -43 offset. you dont need spacer. the off set pushes the rim out. the money you save on the spacers can be spent on rims. you should put highlifter 2 inch lift ($259) do to the fact your puting 27 inch tires on i dont think you will be gitting big air. if you dont mind a stiff ride i would put hunterworks front spring spacer in. ($65) this way you wont rub inner fender well at all. this will give you 13.5 inchs of clearance under your skid plate. near the back its only 12.5. i might try puting spring spacer in the rear of my rzr and see if i can gain an inch more. i think 14 inch rims look the best when there new but 12 inch rims have a taller sidewall. this will help keep the rims from geting banged up.
Old February 2nd, 2008, 09:02 AM
qdawg1976's Avatar
Member #848
View qdawg1976's Photo Gallery(0)
I am running 27" Swamplites on my RZR and the Swamplites are on 14" ITP SS 108's and I love them, No rubbing and excellent hook-up
Old February 2nd, 2008, 10:15 AM
mdevans's Avatar
Member #878
if kuss22 go's with 14's he will need to know what spacer to use. im not saying thay rub. but without lift its hard to beleave. i would think in hard turns under power or droping of hill rut area. thay would rub. how much do you weigh.
Old February 2nd, 2008, 07:06 PM
LAYNFRM's Avatar
First Name: tyler
My RZR: 08 green
Member #1103
View LAYNFRM's Photo Gallery(0) Send a message via AIM to LAYNFRM
i'd go with a 2" spacer if you want to use stock wheels. otherwise, as was previously stated, the MSA's with the -43 should work, or the itps with the middle offset..... i have the 28" MST's on ss108s with the standard offset (not the stock offset or the really wide offset, but the middle one) and i jumped mine a couple times and hit some 8-10 inch logs going straight at 25-30 this weekend and it didn't rub. the front springs are on their stiffest setting, which wasn't that stiff IMO. now when i'm turning is a different question, lol. when on flat ground and slight off camber situations they don't rub, but if i get to where i'm crossing a rut or hit a bump turning, they slightly rub. i thought they were gonna be bad since everybody is saying they rub with 27s, but it wasn't bad at all, and i wasn't easy on it testing them out. it's audible, and you can feel a slight vibration on the floorboards. at most i'll get some highlifter springs. maybe all new shocks since it'll jump better. hope that essay i just wrote helps, lol
08 rzr with 28" MST's on black ITP SS108s, polaris winch, pre runner bumper, 4 points, snorkel, custom laser cut grill, under dash dome light, horn, old school police light up top, full underbelly skid plate, bent stock cage, more to come...
07 crf80 with 115 big bore mini motard
06 Husaberg FS650C plated race-tard
05 KLX110 plated mini dual sport
01 XR650R plated supermotard/dual sport
Old February 8th, 2008, 08:09 PM
stacrzr's Avatar
Build Your Own
My RZR: Green G2
Member #1216
View stacrzr's Photo Gallery(0)
to run a 27" swamplite on 12" or 14" do I need spacer?????
Old February 8th, 2008, 09:05 PM
mdevans's Avatar
Member #878
smalrzr go back and read my post. it tells you if you use -43 offset rims you dont need wheel spacers. i have 27 inch mudlights. my rzr is 57 inchs wide in rear and 53 inchs wide up front it handles better than a stock rzr. if you go on mdevans pic's you can see a set. the offset gives the rim a deep dish that looks good.
  #8
Old February 11th, 2008, 08:05 AM
stacrzr's Avatar
Build Your Own
My RZR: Green G2
Member #1216
thanks i'll check it out
  #9
Old February 11th, 2008, 02:05 PM
Code Blue's Avatar
My RZR: two red ones
Member #524
View Code Blue's Photo Gallery(0)
seems your getting the run around so I'll answer with pic's 14" swamp lites on ITP no spacers just tell the wheel dealer you use to send the extra wide ITP's.
  #10
Old February 11th, 2008, 02:13 PM
stacrzr's Avatar
Build Your Own
My RZR: Green G2
Member #1216
thanks, swamplites look great, wish we could some snow like that here in east TN
  #11
Old February 11th, 2008, 07:27 PM
1idrod's Avatar
My RZR: Gen 2 Green
Member #784
View 1idrod's Photo Gallery(0)
I looked on ITP's site today and I can't find 14'' 108's standard 4/3 offset. Can someone help in what I need. I'm going with 14'' because I already have the tires from my King Quad. Do I get same size wheels all the way around or get front and rear with different offsets. Thanks
  #12
Old February 12th, 2008, 06:49 AM
mdevans's Avatar
Member #878
dont forget a lift kit . you will rub. thats all i have to say.
  #13
Old February 12th, 2008, 07:58 AM
1idrod's Avatar
My RZR: Gen 2 Green
Member #784
I ordered 2'' RD yesterday
  #14
Old February 12th, 2008, 08:31 PM
1idrod's Avatar
My RZR: Gen 2 Green
Member #784
Sorry for hijacking this thread again, but one more question. What size WHEELS would you use on the front? SS108's 14x6(4+2) or 14x8(5+3)offsets? Tires will be 27x9x14 front, 27x11x14 rear. Would you use same size rim all the way around or use 14x8rear,14x6front. I've tried to explain this earlier and on another site, I hope someone understands what I'm looking for before I start thinking I'm crazier than I thought I was.
  #15
Old February 12th, 2008, 09:33 PM
LAYNFRM's Avatar
First Name: tyler
My RZR: 08 green
Member #1103
you can use the ITP "standard offset" to run those tires. i didn't get the extra wide offset. i got the standard offset. mine rub only during braking when turning and in off camber situations
do the swamp lites handle pretty good? my uncle has some on his arctic cat and i'm considering buying them from him to put on stock wheels and use for fast trail riding where i have to be 50"s
Bookmarks
Bighorns or Swamp Lites walbright Wheels and Tires 6 November 21st, 2008 11:11 PM
WTB 2009 RZR "S" Stock Exhaust luggnut Want to Buy 7 October 4th, 2008 07:05 PM
+4 Kit "Holz Racing" Make me an offer GIFF-TURBO RZR RZR's and Parts 13 September 8th, 2008 02:00 PM
28" mud lites on 14 have slices and knobs coming off birdmanf250 Wheels and Tires 1 July 11th, 2008 12:39 PM
Swamp Lites? Schwenddog Wheels and Tires 12 May 25th, 2008 10:39 AM
