22.5 degree drop angle on trailer axle? Explain... - Polaris RZR Forum - RZR Forums.net
post #1 of 8 Old July 17th, 2011, 04:32 PM Thread Starter
Official Parts Breaker
orangecrush's Avatar
My RZR: 2013 Jagged X
Member #21745
Feedback Score: 21 reviews
View orangecrush's Photo Gallery(20)
Does anyone know how much a 22.5 degree drop angle changes the height on a trailer?
Also, is it something you can add after the trailer is built?
Thanks,
Mark
orangecrush is offline
post #2 of 8 Old July 17th, 2011, 04:40 PM
sanduras's Avatar
First Name: TONY
My RZR: 09 rzr,s(hers)11 xp (his)
Member #20092
View sanduras's Photo Gallery(0)
Re: 22.5 degree drop angle on trailer axle? Explain...
Thanks,
Mark
referring to a torsion axle, unless it is an adjustable (which seems pretty rare anymore)axle .it depends on what you are looking at. the trailer will be made with certain degree axles for deck height. most are welded on an hard to remove or replace. a 22.5 degree will put the torsion arm at about 10 oclock if i remember right. but the height will still vary on make and such.
sanduras is offline
post #3 of 8 Old July 17th, 2011, 04:42 PM
Jeffco's Avatar
First Name: Jeff
My RZR: 2013 XP 900
Member #11931
View Jeffco's Photo Gallery(0)
What I think you're talking about is the angle of arms on a torsion axel. Its not something you can change the angle on, Its something you choose and install. The only way to change the angle it to change the axel.
Jeffco is offline
post #4 of 8 Old July 17th, 2011, 05:04 PM Thread Starter
Member #21745
Thanks guys, any idea of how much it would cost to have a set of these axles installed?
I ask because I’ve been looking at VRV aluminum trailers because they are aluminum and are of a deck over axle design. I’m just afraid that a 28’ enclosed trailer (as in cargo or car hauler) will drag on the ground going up some of the roads around the bends.
I was talking to a trailer builder and he said they could make the trailer with a 22.5 degree angle possibly raising the trailer a couple (2) of inches.
As much as I like the VRV trailers, I’m having a problem justifying 25-30K for an aluminum trailer for the half a dozen times we may use it a year.
By adding the 22.5 degree angle axle, I could go back to a regular cargo trailer and save some money.
Thanks,
Mark
post #5 of 8 Old July 17th, 2011, 05:12 PM
Jeffco's Avatar
First Name: Jeff
My RZR: 2013 XP 900
Member #11931
These axels bolt on with 4 bolts per axel. The easy way to lift the trailer is to install spacers between the axel and frame, it might take an hour to do both axels.
Jeffco is offline
post #6 of 8 Old July 17th, 2011, 05:13 PM Thread Starter
Member #21745
Jeff,
Are you saying any type of torsion axle or were you referring to leaf spring axles?
Thanks,
Mark
post #7 of 8 Old July 17th, 2011, 05:19 PM
Jeffco's Avatar
First Name: Jeff
My RZR: 2013 XP 900
Member #11931
Check out the link. You can see the mounting flanges on these. Its pretty easy to do this lift, but keep in mind, moderation is every thing. I wouldn't go higher than 2-3"http://www.amazon.com/Flexiride-Torsion-Axle-Frame-Width/dp/B001N11LUS
I would never reccomend lifting a leaf spring set up with lift blocks.
Jeffco is offline
post #8 of 8 Old July 17th, 2011, 05:26 PM Thread Starter
Member #21745
Ahhhhh, great idea, I should have looked up a pic of it. Makes sense now. I agree, I was thinking 2” top. Any more than that and I think it would pull like crap.
Thanks so much for everyone’s time.
Mark
12ft single axle trailer where to position rzr rzrhoss General RZR Discussion 2 May 16th, 2011 05:24 AM
2010 16ft Carson trailer, tandem axle ek98 Misc For Sale 7 February 1st, 2011 08:04 PM
rzr s axle angle. problem? southtxmudrzr Muddin' 9 July 6th, 2010 07:24 PM
Super ATV +5 "S" kit and 2.0 Foxes. Max axle angle?? onanysunday Suspension 4 May 6th, 2010 09:15 PM
trailer axle question MrBill04 General RZR Discussion 2 July 9th, 2008 11:10 AM
