I was talking with trailersplus about a trailer for my rzr.
They sent me pictures of a crew cab ranger in one of their loadrunner trailers.
Whats everything think of these trailers? I am looking for a 7x16 enclosed with the height to get my rzr in. I have S with 30's so i need the height of this type of trailer. But i really wanted a v nose and they dont have any.
Im in kansas city if anyone knows where to get a deal.
I have a 6X12 Loadrunner for my "S" (with an aftermarket cage) and I love it. Great quality trailer. LED lights, polished diamond plate gravel guard and fenders, brakes on both axles, undercoating, 3/8" ply on the walls, air flow vents, spare tire and lug wrench included. I highly recommend the brand.
Interstate cargo trailers are nice.. But they are pretty expensive. What is the height of the trailer? I had a little trouble with them getting me a 6'6" tall ceiling in the size trailer I wanted.. Their standard plus height was like 6'3" or something like that. As far as how they are built though.. They are well made trailers from what I could tell. The biggest drawback to them is the plastic roof cap on the nose of the trailer. I think the make the trailer look better, But They leak and crack over time.. I was warned by a few people to get a trailer did not have a cap at the top. I looked a few used trailers with front caps and a couple of them did have leaks. Interstate does have a 5 year warranty though..
The loadrunner interior height it 79" and she told me the door height is 72 ro 73 cant remember.
hey mosslager, whats your door height do you know? and how well do you fit. I got to get my S with 30s in there. Oh did you use it with the stock cage? Howd it fit then?
I can't remember what my door heighth is off hand. I know it is about 1/2" shorter than a stock RZR-S cage though. When I had my stock cage it would rub going in and out. Now I have about 6" of clearance with my new cage. You'll never get an "S" on 30's in it. They make a Load Runner Pro Line that I think is slightly taller but you pay for it becuase it has a few other upgrades. However even it will not fit an "S" running 30's I don't think, unless you change the cage then that changes everything.
Check with cooper trailers in Oak Grove, Mo and tell them Josh sent you. I worked there all through high school. A couple years ago they where the largest trailer dealer in the midwest.
Yea ive got about 10 cages on bendtech and cant make up my mind which one to build cause they are all so sweet, but they all take between 5-6 inches out of the height. And yes the Loadrunner pro is the one i was looking at. And your right it does have more and you pay for it but i was looking from some of the stuff anyways. I guess ill have to just go test it. I wonder if they will think its funny if i just ram it in there and be like hmm it doesnt fit that well.
Well not sure if it helps but I looked at several models before going with the Loadrunner and you get what you pay for. With the others they were cheaper to start with but wanted extra for the spare and extra for undercoating and extra for tie down points and extra for the 3/8" wall ply and stab jacks, and LED lighting.... the list went on and on and the Loadrunner came with all that. The 5 year roof warranty was the best I found also.
Yea I think the pro serious is lifetime on the roof. I just really wanted a vnose but im sure i can pull flat easy enough.
You are right about the pricing everything i have found cheaper is cheaperrr. I like all the extras. Ill prolly be going with the pro series but now I cant decide if i want 6x12 or 7x16 lol. I would like all the extra room but prolly cost a bit more towing it all over. Lifes decisions lol.
I have when they go to pull it lol. 7 Wide is nice for the extra room but I went with a 6 wide because the box part doesn't stick out past my truck "5.7L 2008 Tundra" My RZR with a +4 and a 3" lift fits in a 6wide with 6'6"ceiling height.. The door is 6' I believe..
Here is my Freedom brand.. I bought a pretty much stock 6x14 and made it into a cheap toy hauler. FWIW stab jacks, lights, tiedowns, ect are all pretty cheap and easy to add.. So I wouldnt' get caught up to much in that stuff.. Main thing is the construction,,16" on center floor and walls, Size of the frame Tubes and the quality of the plywood on the floors, walls and maybe the ceiling if you have them insulate it.. Of course a one piece roof is nice also.. I don't care for front fiberglass caps.. Like I said before they crack and leak over time..
One thing to help get taller RZRs into enclosed trailers: I back the truck just up to the hitch point and then pull forward a couple of inches. That allows me to hook up the safety chains and then lower the tongue all the way to the ground. Then set the rear loading jacks all the way to the ground. This way there is more angle between the loading ramp and the interior deck. Thus as the back edge of the roof or cage goes through the doorway, the rear tires are lower, compared to the interior deck, and thus there is clearance for the top or cage. Works everytime for me!
I guess ill just have to roll mine and crush the cage down so itll fit. I want it to fit no matter where im parked with it hooked to the truck. Dont wanna take any time other than to tie in down when i get done riding.
It only takes us about 10 minutes for the whole process. And if I spent another $285 for another electric jack for the enclosed trailer it would take even less time. And it beats the heck out of tearing up your roll cage and or trailer. Remember the spring for the fold down door is just above the door opening!!!
I am trying to figure out a way to tow my Razor s and my Can Am 800r Mxr on one traile. Looks like I am going to have to get a 20 ft traile unless I can figure out how to stack my Can Am up against the Razor. F@$King combined length between the two is 18x8ft long and 9 ft wide....oh Hell!! looks like I might new a 20 ft trailer!!!!!
I am running a 24Ft LoadRunner , I can drive my wifes 2010 Dodge Ram Pick-up inside with no issues.. I used to use it to transport my Ultralight (small plane) or my Chrysler 300..Now its dedicated to either my RAZR and my son 170 for going out and having fun..Or helping out people move...I just had it delivered from Arizona (I guess thats where it was made??) I think, not sure but think its an Interstate Loadrunner?? As for the exact dimensions, I would have to check.. But I think its longer than 24Ft..thats the inside measurements I think?? Its probably the first trailer I have ever towed tha even when loaded with my Chrysler, I dont even notice its there..and thats towing it with my wifes little 1500 Laramie dodge (I really miss her F-350 Turbo diesel, she traded it in??), but in her defence, the dodge does have the hemi and the car and trailer together are only 6,500Lbs... The RAZRs dont weigh enough to need a huge 350 anymore...
I bought a 20' V nose from the Pace manufacture in St. George, Utah. It is 8'6" wide. The price was right and it is a well made trailer. I can put my RZR and my Sportsman 500 in side with not any problems. The width and length gives me plenty of room to take all my stuff. The trailer tows great behind my 2006 Ford F250. Looked at smaller trailers but could not get all my stuff inside. I think smaller trailers create you problems, we all take more than we need except for the things we forget and need.
i have the 7x16 for my rzr might be sellin has 30 miles on it gonna buy a 7x20 to haul all my toys..upgraded to 15s, stands on rear, tire holder and spare ect.
robbie 2563109400
Related Threads
3.1M posts
141.5K members
Since 2007
