Flipping the axles?? - Polaris RZR Forum - RZR Forums.net
post #1 of 19 Old March 25th, 2010, 10:16 AM Thread Starter
Polaris RzR LE
ctate's Avatar
First Name: Clarendon
My RZR: 2009 LE
Member #6805
View ctate's Photo Gallery(0)
I am thinking about flipping the axles on my toyhauler for more ground clearance. If I do, Will towing be rougher and will the trailer feel heavier? Im expecting a little bit of a rougher tow but I dont want to much. Will I lose mpg since the trailer will be sitting higher? Thanks for your thoughts.
ctate is offline
post #2 of 19 Old March 25th, 2010, 01:56 PM
quadnkev's Avatar
First Name: Kev
My RZR: Red
Member #610
Feedback Score: 19 reviews
Re: Flipping the axles??
Don't know before or after to compare, mine have always been flipped from the factory.
Those I know that did flip theirs have never had complaints, just gee glad I did it comments.
quadnkev is offline
post #3 of 19 Old March 25th, 2010, 02:37 PM
dave@utvtech's Avatar
First Name: Dave
My RZR: 2010 White SEMA build
Member #9515
View dave@utvtech's Photo Gallery(0)
I have done it and many others have with no problems at all, I am sure you may lose a little bit on fuel economy but I bet it doesn't seem to be noticeable. I do not think that the trailer feels heavier but I am towing with a Duramax that has a compound turbo system and getting over 550 hp. I didn't notice the ride rougher at all but keep in mind I turned my fifth wheel into a gooseneck with a product called Ranch hitch Adapter.
A long explanation from a RV Blog on doing the job:
Ok you boondocking, wrought traveling, dune busting freaks – you’ve decided to buy the 5th wheel trailer of your dreams, the one that you can pull with your new 4X4 pickup truck. Thoughts of going up into the hills away from the crowds in the campgrounds flow through your mind until your brain hears the sales person saying something about having to flip your axles on the trailer before you can pull it with your truck. “What’s an Axle Flip?” you ask. The sales man explains that your truck is 51 inches high at the top of the bed side rails. The trailer neck is only 52 inches high to the bottom of the neck, which means that the trailer has to be raised by about 4 inches to keep the neck of the trailer from resting on the bed of the truck – an unhappy experience !
Axle flips are becoming more and more common as 4-wheel drive trucks are used to pull fifth wheel trailers. The axle normally rides on springs which are located below the axle and held by a mounting plate called a spring perch. Because trailer axles have a pre-stress curve built into them they can only be installed in one direction. This means that to raise the trailer a new spring perch must be welded to the top of the axle and the spring re-installed above the axle. This will raise the trailer body between 4 and 6 inches from the stock height.
The Job – Lots of safety stuff here ! Have a buddy stay with you while doing the work, use good jacks and jack stands and make sure the trailer can’t move while everything is disconnected from under it. It is crucial to think safe before you touch a single thing !! If there are ANY questions in your mind about how to do this job take it to a pro ! Now that I’ve scared the dickens outta ya let’s get started.
While the wheels are on the ground, loosen the lug nuts by a half turn. Now use a floor jack to raise the right rear of the trailer enough so that all the wheels clear the ground on that side. Place jack stands under the frame of the trailer to support the trailer and then repeat the process on the left rear of the trailer. Make sure that the jack stands are rated at or above the weight of the trailer !
Remove all the wheels from the axles. The brake wires are now exposed behind the brake hub. If they are connected with twist nuts simply unscrew them and separate the wires. If they are crimped together, cut the wires to separate them. Remember to mark the wires so that they can be reconnected the same way when we get to putting things back together.
The axles are then unbolted from the spring pad and the U-bolts are removed. Remove the spring pad from the opposite side of the trailer the same as the first. At this point the axle is being supported at both ends by the springs. Place the floor jack under the center of the axle to be removed and raise the axle slightly above the springs. Now remove the center shackle bolt from the springs on both sides and using the floor jack, slide the axle out from under the springs and lay the axle on the ground. At this point you can re-attach the shackle bolts to the springs. Now repeat the process with the other axles until all are on the ground.
Spring perches can be purchased from RV and trailer supply stores. You will need to tell the folks there the diameter of the axles and the height of the perch. If there is any doubt as to the size you need simply measure the old ones and order the same size.
Place the axles with the old spring perch pointed down and clamp the new ones to the top of the axle. Ensure that the new ones are directly over the old by using a straightedge or a square. Next measure the height of the ends to make sure that the perch is even on the axle. Use a hammer to lightly tap the perches into place. Now that the perches are clamped and aligned we can do the welding. Remember that this is where the entire load of the trailer on the axles is being carried as you go down the road so the welding must be first class. If there is any doubt, have the welding done by a pro after you have removed the axles from the trailer. Another thing is the alignment of the perches, they must be even to each other on the axle so when the springs and trailer are back on them the whole critter doesn’t go down the road sideways.
Now, using the floor jack, slide the axles under the springs. The new spring perch should be facing up. Adjust the axles so the new perch is centered under the spring in the same location as the original. Re-attach the spring pad and U-bolts to the axle. Repeat this process for each axle. Now reconnect the brake wires for each wheel. If wire nuts were used on the brake wires you may want to consider using crimp connectors. They produce a better water proof seal and provide a better mechanical connection.
This is also a good time to check the condition of the brake shoes and bearings before replacing the wheels on the brake hubs.
Use the jack to raise the right rear of the trailer and remove the jack stand on that side. Lower the trailer back onto the wheels and repeat the process on the left side of the trailer. Use a ruler to measure the height of the rear and front edges of the trailer to make sure that it is level. Now measure the height of the pin-box to see if it is high enough to clear the top of the truck’s bed. Ideally there should be between 4 and 6 inches of clearance between the bottom of the trailer neck and the bed of the truck.
There are a few things to check now. The umbilical cable for the trailer lights, brakes and power may be a bit too short. Your options are to relocate the receptacle or put on a longer cable. The trailer will tow a bit differently now that it has been raised and it will brake differently. Take it out to an empty parking lot, or open area, and practice making turns and stops with it until you feel confident enough to get out in traffic with it. After you have towed the trailer for about 50 miles check the u-bolts and spring shackle bolts to make sure that they haven’t loosened. Also check the wheel lug nuts. Repeat this process at 100, 200 and 500 miles just to be safe and sure.
Having a flipped-axle trailer will also provide you with extra benefits, like increased ground clearance so that you can try some of those back country roads that prevent others from being able to follow. Yee Hawww !!
Later – -
The Old Ranger
dave@utvtech is offline
post #4 of 19 Old March 25th, 2010, 05:05 PM Thread Starter
Polaris RzR LE
ctate's Avatar
My RZR: 2009 LE
Member #6805
Awesome, thanks for the replies. Dave, what year is your d max? got any pictures of that motor?
ctate is offline
post #5 of 19 Old April 2nd, 2010, 01:15 PM
First Name: Dave
Member #9515
2007 and Diesel Power did this article on the install, my good friend Brent Willsey owns Powerlabs Diesel here in Idaho Falls.
Twin-Turbo Duramax - Diesel Tech - Diesel Power Magazine
I know longer have the Fabtech lift on the truck as it is for towing.
post #6 of 19 Old April 2nd, 2010, 01:23 PM
Kip
Kip's Avatar
Member #9016
View Kip's Photo Gallery(0)
thats a good looking truck. Do you ever go to any of the truck pulls?
Kip is offline
post #7 of 19 Old April 2nd, 2010, 01:37 PM
First Name: Dave
Member #9515
I go to them but I can't afford to tear my only towing vehicle to pieces, so I do not participate. To tell ya the truth, I only have ran on the max-hp tune a handful of times because I think black smoke is annoying (the tow tune never smokes).
post #8 of 19 Old April 2nd, 2010, 02:52 PM Thread Starter
Polaris RzR LE
ctate's Avatar
My RZR: 2009 LE
Member #6805
Man those gains are amazing!! You added more than another motors power. Man, I had to go and have some alone time with the pictures of your rig. Is the tow tune numbers 569 hp and 1,124 lb-ft of torque? How much does a tune like that run?
ctate is offline
post #9 of 19 Old April 2nd, 2010, 03:53 PM
First Name: Dave
Member #9515
Yes, the tow tune is about 550 hp and 1,100 torque. You can buy the compound turbo set up for $4500 and the tranny upgrade is about another $3,000 and it comes with a two year warranty. The bonus of these systems is your truck runs extremely quiet and when properly tuned you will never see black smoke even up a steep grade with a load.
Most people are running closer to 700 hp with these products, but it really is overkill after a certain point. The last dyno day they showcased a build they did that put up 905 hp Duramax, and was an everyday driver for a local potato farmer.
Going to be at Moab for both rallies if you're interested in seeing the setup and taking it for a spin to see for yourself.
post #10 of 19 Old April 2nd, 2010, 05:39 PM
Kip
Kip's Avatar
Member #9016
Yeah the people blowing smoke every where is gonna kill diesel trucks. Have you seen the wild diesel power wagon that my uncles truck. He is building another pulling for this season though.
Kip is offline
post #11 of 19 Old April 2nd, 2010, 06:35 PM
MossLager's Avatar
Member #12471
View MossLager's Photo Gallery(8)
I have had mine flipped for 3 years with lots of towing from Pismo to Glamis with no issues. It is only a 23' tandem axle however. I wouldn't tow into Ocotillo as it was stock... sat too low and needed a spotter to save your plumbing. It does make a negative difference when towing in the wind though.
2007 Rhino
2010 RZR-S
2013 XP
MossLager is offline
post #12 of 19 Old April 2nd, 2010, 06:39 PM
King of crash!
Member #787
you all forgot to add the down side of flipped axles......i know but someone had to rain on this....
it makes your trailer top heavy so it in a nasty wind or emergency swerve flip over.....
and if ever involved in a accident it will bring big problems with cop's and insurance.... remember I'm just pointing it out....( Ive helped many a friend flip their axles)
johnnycat8 is offline
post #13 of 19 Old April 2nd, 2010, 07:04 PM
Beach Leo's Avatar
First Name: Leo
My RZR: 08
Member #10516
View Beach Leo's Photo Gallery(10)
When you raise it I think its better in cross wind..The wind has 2 places to go when raised..Over the top and now with it raised underneath..This works for my motor -home so I assume it would work with toy Hauler..When it real windy I raise my motor-home up with the air bags..even make it better when passing a semi..With the bags down lower I will get pushed all over the road, cause wind only has one way to go..With it up Wind has 2 ways to-go..
Beach Leo is offline
post #14 of 19 Old April 2nd, 2010, 07:06 PM
King of crash!
Member #787
i can see leo driving down the freeway having a air bag up down with some low rider contest
post #15 of 19 Old April 2nd, 2010, 07:52 PM
Beach Leo's Avatar
First Name: Leo
My RZR: 08
Member #10516
You have seen mee before Its does go low
Upgraded AXLES.... Calling all hard drivers... Which axles are the best? rzrmike Engine and Drivetrain 32 January 30th, 2010 09:04 PM
all axles the same pes1004 Suspension 3 January 15th, 2009 02:49 PM
Flipping the wheels Harryscarlot Suspension 24 November 8th, 2008 08:28 PM
Need axles hellrazor General RZR Discussion 0 June 20th, 2008 04:26 PM
Flipping the wheels Buckeye_RZR General RZR Discussion 1 March 19th, 2008 03:33 PM
