| Tow Rigs, Trailers and Camping For discussion of trucks, RV's, and other recreating vehicles |
Re: RZR in the bed of a truck...good or bad |
June 27th, 2008, 10:01 AM
Originally Posted by hellrazor
A buddy of mine got his welder out one afternoon and made a reciever hitch attachment that when you put it in your reciever it extends a brace out beyond your tailgate with two bars going crossways that your back tires rest in between. Works great and takes the weight off the gate.
To haul your RZR in back of 1/2 ton pickup, simply buy two 2X10 planks, cut them the length of your pickup bed (to end of tailgate) Drill anchor bolt hole through board and box, drop in bolt (no nut needed) drive rzr up on ramps (not using the 2X10 as ramp) The front wheels of rzr on planks and rear on blanks distribute the weight so not all the weight is on tailgate. Worked for me with a Mule.
June 27th, 2008, 10:07 AM
Just take two 2x10 planks, cut to length of pickup box so they are to end of tailgate, anchor them with bolt through box. Drive mule up with ramps onto the planks. Front wheels on plank and back wheels on planks distribute the weight, that way there is less weight on tailgate. Works better than a sheet of thick plywood and easy to take out when not hauling the rzr. Worked great when I had my mule
June 27th, 2008, 11:45 AM
Or you could get something built for this purpose.
Love my Bulldog Rack.
UTV Carrier
June 27th, 2008, 01:37 PM
First Name: Tom
My RZR: 2008 Red RZR
How much was that ?
June 27th, 2008, 02:03 PM
$1700. 10 foot ramps included.
He will even custom make one for you if you need room for a fuel
tank up front or something else.
June 28th, 2008, 08:53 AM
My RZR: 2008 Green Gen 3
Here it is in a short bed Chevy. I put 2X10's on the right and left side to keep the weight off the airgate and you must back in the rzr. I drove over 600 miles like this. Note there is 2 straps underneath and one on front you can't see in this pic.
Jeffro
08' Green Polaris Rzr (Gen 3)
26" ITP Mudlite XTR's on 12" Vision Bruiser Wheels
Deluxe Front & Rear Brushguards
3500lb Polaris Winch
July 13th, 2008, 04:24 PM
Here's my new RZR loaded in a truck bed. No problems. It passed right between the wheel wells. I have 4 sets of tie downs. my only concern is the tailgate. I really don't want to use 2x12 but I will if I can't ensure the gate dropping.
July 17th, 2008, 09:19 PM
Try putting a piece of 3/4 plywood in the bed, extending out to cover the tailgate. This will help reduce the load factor. Works great in my Dodge.
July 18th, 2008, 08:00 AM
The plywood works too. The only reason I suggested the two 2X10's is that if you cut them to the right lenght you can shut your tailgate when not using them and it is also easier handling the 2X10's that wrestling with the sheet of heavy plywood, unless you want to leave the plywood in all the time.
July 18th, 2008, 08:39 AM
My RZR: Red - 08
Post some pix of that...
July 18th, 2008, 08:42 AM
First Name: Don
My RZR: '08 Red
Personally, for 5 years I've loaded Rangers and lately a RZR onto the tailgate simply by installing a heavy qauge tailgate protector to spread the load. No need for plywood etc.
I have had a full size Ranger hauled on the very end of the tailgate with no problem but I did take precautions by adding a second cable thus picking up two anchor support points instead of the stock one.
Cables are very strong and buying the metal folding tailgate hangers does little if any in adding strength partly because the anchor points are actually the weakest link. If done right adding a second hanger more than doubles the support partly because it is added to the furthest point of the tailgate thereby increasing leverage.
The added 'D' ring is attached (in my case) to an existing latch bolt and also to a full thread rod that ran through the entire tailgate.
Simple and cheap - cost less than $25 from a harware store.
'05 DODGE 3500 DUALLY
H.D. CUMMINS
Vision '02 Trail Lite Trailer
'07 Polaris Ranger XP
'08 Polaris RZR
July 18th, 2008, 11:34 AM
First Name: Nick
My RZR: '08 RED
wish i'd have read this about 3 months ago!! ;(
July 19th, 2008, 11:25 PM
First Name: Eddie
My RZR: 2008, bought it 7/29/07
I haul my rzr in the back of my short bed 2500 GMC. You need to tie down the ramps so they dont slip and cause the rzr to fall. My tail gate is funky from the weight. I use a wooden 2x12 setup to drive my rzr up on to and to take the weight off the tale gate. As soon as I find a trailer I am going to switch to a tow rig. It is alot safer and not so scary.
fast eddie.
