Need help setting up trailer + tongue weight - Polaris RZR Forum - RZR Forums.net
This is a discussion on Need help setting up trailer + tongue weight within the Tow Rigs, Trailers and Camping forums, part of the Other Off-Road, UTV, and Watersports Discussion category; I need some help setting up my trailer to get some of the tongue weight off the vehicle. I'm towing a 2012 RZR 800, it's ...
Go Back   Polaris RZR Forum - RZR Forums.net > Other Off-Road, UTV, and Watersports Discussion > Tow Rigs, Trailers and Camping
Old April 16th, 2013, 01:43 PM   #1
appzman's Avatar
Member #35600
View appzman's Photo Gallery(0)
I'm towing a 2012 RZR 800, it's pretty stock, just has front bumper, winch, skid plate, some tools and fluids. It's definitely under 1200 lbs.
I'm also towing a 2006 Sportsman 800 X2. It's around 800 lbs with fluids and gear.
I'm using a Polaris brand trailer, the PATV83x14, which weighs 425 lbs.
I tow with a 2006 Lexus RX330, and while I'd love to get a truck, I'm stuck using it for the next couple years.
I usually load up like this:
The vehicle is rated to tow 3500 lbs. I noticed when loading up last weekend that the rear of the vehicle sagged a lot when I was loaded. I did some research, and it turns out the tongue weight is only 350 lbs.
I try to get the RZR as far back on the trailer as possible, but the problem seems to be that most of the weight of the Sportsman is sitting right on the hitch of the vehicle.
I'm wondering if anyone has any suggestions as to how else I can load up the trailer so I can take a bit of load off the vehicle. Would getting an adjustable hitch that raised the ball up a couple inches distribute some of the weight back on the rear axel? Any ideas?
Thanks!
appzman is offline   Reply With Quote
Old April 16th, 2013, 01:55 PM   #2
dsmracing1's Avatar
First Name: Cameron
My RZR: 2011 RZR 800 Walker Evans Edition
Member #27601
View dsmracing1's Photo Gallery(8)
Re: Need help setting up trailer + tongue weight
Having a raised hitch will help out very minimally. I think its just the fact that the big sportsman is weighing the tongue of the trailer down. Thinking you just might be over the recommended weight of your specific vehicle.
Your Not Having Fun Til Your Rolled Or Stuck!
Warn RT40 4000lb Winch, 30" Gorilla Silverback Tires on STI HD2 SE Rims, Rhino Axles On All 4 Corners, Arctic Thunder Snorkel, Racer Tech 2" Lift/Progresssive Springs, EMP Gas Tank Guard and Outback Bumper, Pro Armor Doors, FUTV A-Arm Guards, SSV Marine Stereo, 30" Totron Light Bar, Dalton Clutch, Cooter Brown Skid, SATV Power Steering
BRAAAAAAP!
dsmracing1 is offline   Reply With Quote
Old April 16th, 2013, 01:58 PM   #3
MikeA62's Avatar
My RZR: None yet
Member #40884
View MikeA62's Photo Gallery(0)
A weight distributing hitch will transfer alot of the weight forward onto the frame of your Lexus, but it won't work if your trailer has surge brakes. These are available at harbor freight, camping world or any trailer supply store.
MikeA62 is online now   Reply With Quote
Old April 16th, 2013, 01:58 PM   #4
Scoundrel's Avatar
First Name: Paul Sterley
My RZR: 2010 RZR S
Member #20335
View Scoundrel's Photo Gallery(2)
Given that most of the weight of the RZR is in the back, you could try loading the RZR nose-in and the ATV behind it. The majority of the weight would then be centered on the trailer axle, with some stuff up front to keep you from swaying.
Changing the ball height isn't going to make a big difference.
If changing your load positions doesn't help, your best option is probably going to be a weight distribution hitch.
The idea behind one of those is that it uses leverage to transfer some of that weight to the front of the vehicle, reducing the sag on the rear end.
Here's some more info on that: Trailer Hitch Selection Guide - HitchSource.com
Most weight distribution hitches are very heavy themselves, and I could see someone being reluctant to attach one to a situation where the tow vehicle is already sagging. They're also messy (grease and stuff).
But, there is one that is very lightweight, and easy to attach, and doesn't use grease.
4" Drop/Rise No Sway Weight Distribution Hitch - Hitchesandmore Store
I would have used this one myself, except I needed a larger capacity (1500+ lbs tongue weight) and this one is rated for 1400.
Check out my UTV Guide to Western Washington at http://www.utvadventuresllc.com!
The UTV Guide to Eastern Washington is finished!.
The eBook is available now. I am taking discounted PRE-ORDERS for the printed one while I wait for the print shop to crank them out!
Sterley, Paul
Scoundrel is offline   Reply With Quote
Old April 16th, 2013, 02:00 PM   #5
Bobby.Digital's Avatar
First Name: Bobby
My RZR: 2011 900xp LE
Member #24519
View Bobby.Digital's Photo Gallery(0)
You can add AirLift air bladders to the rear of your vehicle to raise it back up after hooking up your trailer. You will achieve your normal ride height with this setup and it will cost less than $200.
Call up 4 Wheel Parts
Search Results by 4 Wheel Parts
Buy your Glamis passes from the American Sand Association
__________ 2011 Rzr 900xp LE ___________
Awesome Vendors: http://www.blackrhinoperformance.com/, http://www.ruggedradios.com/
♦ SDR Rollcage to rear & front bumper ♦ EZ Steer ♦ Elka Stage 4 Shocks ♦ Pro Armor slotted doors ♦ Factory UTV Skid Plate ♦
♦ Twisted Stitch Vortex seats ♦ Rugged Radio Car2Car ♦ Rigid 30" Light bar and D2 Duallys ♦ Crow Harness ♦ Mobil 1 Racing Oil 0w 50 ♦ Airaid Air Filter ♦
Bobby.Digital is offline   Reply With Quote
Old April 16th, 2013, 04:25 PM   #6
Addicted
Feedback Score: 12 reviews
CFDWheeler's Avatar
First Name: Steve
My RZR: 12' Voodoo Blue XP
Member #6186
View CFDWheeler's Photo Gallery(0)
While this will help to eliminate the sag, it does nothing to fix the overloaded hitch, assuming it is indeed over the 350lb limit.
I would first try loading the rzr on first, then the quad in the rear. Try keeping them all as rearward as possible. If this does not work, then I would go the weight dist hitch route.
Have you ever actually weighed the tongue weight? A normal bathroom scale placed under the jack of the loaded trailer will tell you how close you are within or above the limits of the hitch. Being that the vehicle wasn't exactly built for towing, it will likely squat with any load. Just the nature of the beast...
2012 Voodoo Blue 900XP :rzrs:
Factory UTV UHMW skids & A-arm guards, UTV Inc TA guards, SATV radius rods, CROW 4pts
Viper Elite 4K on EMP front bumper, Pro Armor rear bumper, TFBB Doors, SSV Works Stereo; EMP Hard Top
30" Roctanes on STI HD5's w/ fender mod; RacerTech Heavy Springs, 30" front and 6'' rear LED lights
IAFF LOCAL 38 Covington KY
CFDWheeler is offline   Reply With Quote
Old April 16th, 2013, 04:33 PM   #7
Scoundrel's Avatar
My RZR: 2010 RZR S
Member #20335
Good idea to get that actual tongue weight, for sure.
If putting the tongue directly on the scale overloads it, there are tricks you can do to distribute and still measure the weight (explained in that first link I sent).
Or you can go to a truck scale on the freeway when it's closed, and sometimes you can see the scale readout through the window of the shack.
In addition to the usual concerns about safety and vehicle damage, if you are involved in an accident, even if you did not cause the accident, and the insurance adjusters determine that you're out of spec on your towing setup, you could be in a world of hurt. I'm not just talking about losing your stuff and having insurance claims denied, but there could also be civil lawsuits.
Not trying to be a hard-nose or anything. It's your choice, but just keep that in mind when you decide what to do.
Sterley, Paul
Old April 16th, 2013, 04:42 PM   #8
appzman's Avatar
Member #35600
I tried loading exactly as you detailed a couple weeks back, and it's a huge pain in the a** to load this way. I positioned the ATV as far back as possible, and it ended up being that the inside tire of the Sportsman was right over the trailer axel, meaning the entire RZR was ahead of the axel. I think it ended up being pretty much the same tongue weight either way because of how tight the inside of the trailer is.
For the weight distribution hitch you linked to, I'm not sure how to tell if it will work with my vehicle and if it will work with such a low weight (it lists a max, but I'm considered that it won't be effective at 450 to 350lbs TW). Any ideas?
Thanks for your help!
Old April 16th, 2013, 04:43 PM   #9
appzman's Avatar
Member #35600
I've never weighed the tongue weight, I'll try to do that this weekend. Good idea.
Old April 16th, 2013, 04:48 PM   #10
Scoundrel's Avatar
My RZR: 2010 RZR S
Member #20335
Bummer. I suggest you call the manufacturer of that hitch and ask them.
When I called, I asked the lady who answered if I could speak with someone about my setup. I got Dave Andersen on the phone. After talking over my setup, he said it sounded like I'd be better off with a heavy duty Reese setup because of the high capacity I needed. He was genuinely interested in helping me find the right setup, as opposed to just wanting to sell his product.
Andersen Manufacturing Inc.
They have a bunch of combinations to fit your setup:
Andersen 'No-Sway' Weight Distribution Hitch
You might want to read the site, do some measuring, and be ready to send a photo before you call.
Sterley, Paul
Old April 16th, 2013, 04:54 PM   #11
Scoundrel's Avatar
My RZR: 2010 RZR S
Member #20335
BTW, if you're over 3000 lbs, does your tow vehicle have wiring for trailer brakes? Does your trailer have brakes?
I prematurely wore out an axle and the shaft that connects the tranny to the transfer case in an SUV a few years back, as well as warping out the brake rotors, because I was towing over capacity.
It can get expensive. More expensive than a cheap used pickup.
Sterley, Paul
Old April 16th, 2013, 06:03 PM   #12
dogcatcher's Avatar
First Name: Jason
My RZR: 2016 RZR XP 1000 Sunset Red
Member #8488
View dogcatcher's Photo Gallery(0)
X2
2016 XP 1000 Sunset Red
2013 Stellar 28 DBG
2011 Ford F350 crew cab dually 6.7
dogcatcher is offline   Reply With Quote
Old April 16th, 2013, 11:47 PM   #13
appzman's Avatar
Member #35600
I'm at less than 2500 lbs fully loaded with fluids and gear. Trailer is rated for 3500 lbs with no brakes.
I'm trying to avoid getting a used truck because we don't have any more garage space, and it gets pretty darn cold up north where the property is. I've seen the harsh Canadian winter kill a bunch of old trucks parked for the winter.
If I was going to get a used truck, something that would be parked almost all year and would just be used for light towing, probably less than 800 miles a year, what would you recommend? Other than towing the rzr and sportsman to the trails, it would be parked the rest of the year. What model, year and max miles would you suggest?
Old April 17th, 2013, 12:19 AM   #14
ZigzagKey's Avatar
My RZR: 2013 Stealth black 900xp
Member #51984
View ZigzagKey's Photo Gallery(1)
I imagine you have a couple hundred pounds of gear in the back of the vehicle as well....could you not strap some of that weight to the back of or into the RZR cockpit? Any weight out of the vehicle and near the rear should help.
ZigzagKey is offline   Reply With Quote
Old April 17th, 2013, 12:24 AM   #15
Scoundrel's Avatar
My RZR: 2010 RZR S
Member #20335
In my state, brakes are legally required for loads over 3000 lbs. So you'll see a lot of trailers around here that weigh 800 lbs and are rated for 2200 lbs of cargo capacity, even though the trailer is actually capable of more than that. Probably different in your state.
I feel your pain regarding garage/driveway space and your stuff falling into disrepair when not in use.
If I was shopping for an inexpensive truck to take the beating so my Lexus didn't have to, and I was going to drag 2500 lbs around, I'd probably look for a Chevy or GMC 1500 that wasn't too beat up. If it was a gasoline engine, no more than 75K miles, if diesel, no more than 150K. Year wouldn't be that important, but I wouldn't want one older than 2000. Or, maybe a Ford Econoline E250 cargo van would work OK. You wouldn't be able to fit the ATV inside, with that big windshield on there, but it would carry your gear and give you a warm, dry place to change clothes at the trailhead.
But there are many different tow setups out there to choose from.
Sterley, Paul
2011 rzr 800 towing tongue weight
best trailer to tow two polaris ace utv
harbor freight tongue weight scale
harbor freight trailer tongue weight
how much tongue weight can a 2006 polaris sprotsmand 450 handle?
how to increase tongue weight polaris sportsman
need a trailer to tow my polaris rzr
polaris 450 sportsman tow weight
tongue weight of rzr4 and trailer
tongue weight scale harbor freight
toung weight pulling yahmaha rhino
towing utv on a 700lb tongue
trailer tongue weight scale harbor freight
two bathroom scales to check toung weight
will tambrins help with overloaded toung weight
Dang Trailer Tongue Jack Macs Dad General RZR Discussion 14 August 13th, 2012 08:37 PM
Weight distribution of all models RZR? & changes to weight distribution for handling Ryan31783 General RZR Discussion 0 January 6th, 2012 12:17 AM
Happy Birthday Cactus Tongue FJK General RZR Discussion 3 December 31st, 2011 06:26 PM
Trailer tongue length JJammo1 General RZR Discussion 7 April 20th, 2011 03:53 PM
help setting tps thomphj Engine and Drivetrain 20 December 9th, 2009 09:16 PM
