Whats Draining My battery on my Camper? - Polaris RZR Forum - RZR Forums.net
This is a discussion on Whats Draining My battery on my Camper? within the Tow Rigs, Trailers and Camping forums, part of the Other Off-Road, UTV, and Watersports Discussion category; I've got a 2007 Keystone Travel Trailer... When I unplug it from power and turn everything off, My battery is draining down with in a ...
Go Back   Polaris RZR Forum - RZR Forums.net > Other Off-Road, UTV, and Watersports Discussion > Tow Rigs, Trailers and Camping
Old March 29th, 2009, 08:19 AM   #1
Feedback Score: 4 reviews
Liftedpowerstroke's Avatar
My RZR: 08 Carbon White
Member #3654
View Liftedpowerstroke's Photo Gallery(12)
I've got a 2007 Keystone Travel Trailer... When I unplug it from power and turn everything off, My battery is draining down with in a bout 2 days... I was wondering what this could be? I've been told my converter is out but I dont even have it plugged up so the converter isn't work... I'm looking to find out what could be possible draining my battery? I've even flipped all the breakers... still no luck... Thanks.
Liftedpowerstroke is offline   Reply With Quote
Old March 29th, 2009, 08:26 AM   #2
bigmike58's Avatar
Member #1218
View bigmike58's Photo Gallery(0)
Re: Whats Draining My battery on my Camper?
do you have a main disconnect? all trailers and motorhomes have those... ihave left a compartment light on before and had that happen..a dead cell in the batt. would kill it also..
bigmike58 is offline   Reply With Quote
Old March 29th, 2009, 10:12 AM   #3
bagman's Avatar
My RZR: 2015 1K Havasu Red
Member #649
The LP detector is always on but I don't think they draw much.
If you were to take the cables off the battery(s) does it still drain?
The breakers are probably for your 120 volt outlets and wouldn't drain the battery.
Does your converter have fuses? Those are the 12VDC circuits that would drain the battery.
Most volt meters have a DC amp scale you could put in series with your battery cable.
Pull the fuses out until the drain stops.
bagman is offline   Reply With Quote
Old March 29th, 2009, 10:20 AM   #4
Feedback Score: 18 reviews
GIFF-TURBO's Avatar
First Name: Gary
Member #3946
I would have the battery load tested to see if it's any good first.
I am no electrician but if you have a short you could track it down by putting a 12v meter on the Positive pole of the battery, and to the frame on the trailer.
If you have a short you will get a reading on the meter, start disconnecting your 12v items one at a time until you find the one that is sneaking the power from your battery.
Or you could Put in a Battery disconnect switch, but then you haven't solved the problem.
GIFF-TURBO is offline   Reply With Quote
Old March 29th, 2009, 12:18 PM   #5
King of crash!
Member #787
the lp and co sensors do draw power..... and like gary said have your batterys checked and one of the most overlooked battery problems on a rv....is the battery dirty take your volt meter connect the poss to the pos term and take the ground lead and touch the top of the battery all over if you get any reading the battery is shorting out from the dirt and acid on top this happens alot get the cleaner out and wash it baking soada works good also make sure you have a good clean battery terminals
Old March 29th, 2009, 12:19 PM   #6
rjsmith's Avatar
First Name: Ralph
My RZR: 2009 RZR Red
Member #4388
Carbob monoxide detector and smoke detectors are always on, but these do not draw much current. Did you make sure your fridge is not set toauto and running off the 12 volts, what about the electric brakes saftey braek away cable. If the plunger is pat pulled out of the safety break away that could make contact, put your breaks on and drain battery.
rjsmith is offline   Reply With Quote
Old March 30th, 2009, 05:40 AM   #7
Member #3654
Thanks for all the replys now I have somewhere to start... I'm going to keep the battery charger hooked up for now... but when i get back from Mud Nationals I'll have it all checked out... Thanks agian...
Old March 30th, 2009, 08:11 AM   #8
Don
DonPro's Avatar
First Name: Don
My RZR: red gen2 +5 LT
Member #648
View DonPro's Photo Gallery(8)
My Dometic fridge has a switch inside the door jam for a heater that burns off condensed water when the humidity is high. Even if the fridge is turned off it draws half an amp. Turning that off worked for me when I had the same problem.
DonPro is offline   Reply With Quote
Old March 30th, 2009, 09:25 AM   #9
Member #3654
I do have a switch in the door jam of my refridgerator... I'll check to see what it is... I was wondering if the light may be stayin on inside it. but the light is cold when i touch it so it must not be on while the door is closed...
Old March 30th, 2009, 10:18 AM   #10
VegasRider's Avatar
First Name: Don
My RZR: 2010 RZR-4
Member #6607
View VegasRider's Photo Gallery(6)
I found that I had the power boost switch turned on for my antenna. Check that it draws a lot of power. Good luck
Don
Las Vegas
VegasRider is offline   Reply With Quote
battery run down in trailer in short time
camper trailer battery dieting fast?
can i leave my pop up camper tiled up when not in use to drain water off it
can rv drain truck battery
converter for keystone travel trailer
how to find a power drain in a travel trailer
rv converter causing battery drain
travel trailer battery drain
travel trailer battery go dead in 2 hours
travel trailer battery shows empty when unplugged from power source
what is draining my travel trailer battery
whay hapoens when the 12v battery on an rv runs down
why converter in rv is discharging my batteries
why does my rv battery keep dying
why does my travel triler battery drain
Cargo trailer / camper? USMCSKI Tow Rigs, Trailers and Camping 153 June 5th, 2014 06:49 AM
2 Rzrs:light, shortest toy hauler, or truck w/camper? akcol Tow Rigs, Trailers and Camping 21 May 16th, 2014 04:56 PM
draining coolant ccie6872 General RZR Discussion 1 December 13th, 2008 07:59 AM
water draining sound from intake when you shut off rzr?? GearHead General RZR Discussion 2 November 3rd, 2008 08:58 AM
Improving Floor Pan Watertightness/Draining sr12345 General RZR Discussion 2 September 21st, 2008 02:13 PM
