Question on how to adjust upper ball joints. - Polaris RZR Forum - RZR Forums.net
This is a discussion on Question on how to adjust upper ball joints. within the Super ATV forums, part of the Supporting Vendors category; First of all I want to say thanks to Tyler and everyone at superatv for great products and super fast shipping! I just received the ...
Go Back   Polaris RZR Forum - RZR Forums.net > Supporting Vendors > Super ATV
Super ATV Super ATV - Madison, IN - (812) 574-7777
Old April 15th, 2011, 05:34 PM   #1
itsjustagreat1's Avatar
First Name: Preston
My RZR: 08 rzr
Member #18568
View itsjustagreat1's Photo Gallery(0)
First of all I want to say thanks to Tyler and everyone at superatv for great products and super fast shipping! I just received the 1.5in offset aarms and was wondering how I know where to adjust the upper ball joints. Is there a certain measurement that I need to do to angle the spindles? Thanks again, Preston
RED 08, Bikeman Full Velocity Exhaust, UMP airbox, flashing LED pole, Renegade bench seat w/ DFR harnesses, optima 925, Polaris winch and plow, 14" crushers w/ 26"Big Horns, full and half window w/ vinyl rear, Hard top, JVC Cd w/memphis 4's and 6's and a 10" sub, Raptor V2 HID's, HOLZ clutch, Super Atv storage, JJ&A Rock Crusher sprague
2001 Blue & Silver Banshee (ported)
itsjustagreat1 is offline   Reply With Quote
Old April 20th, 2011, 11:42 AM   #2
Contact: 855-743-3427
Super ATV's Avatar
First Name: SuperATV
Member #7943
View Super ATV's Photo Gallery(0)
Re: Question on how to adjust upper ball joints.
What do you mean by adjusting the ball joint? It just slides right into the spindle.
SuperATV Official Website
10% Forum Member Discount Up to $400.00.
Just enter RZRFORUM code at checkout! No multiple forum coupon codes accepted.
Super ATV is offline   Reply With Quote
Old April 20th, 2011, 03:36 PM   #3
First Name: Preston
My RZR: 08 rzr
Member #18568
I meant in and out of the a arm for the camber adjustment.
Old April 20th, 2011, 03:47 PM   #4
RZRTOURS's Avatar
First Name: TROY
My RZR: RZRS RZR4 RZR
Member #25042
View RZRTOURS's Photo Gallery(0)
There is no adjustment
RZRTOURS is offline   Reply With Quote
Old April 20th, 2011, 08:47 PM   #5
First Name: Preston
My RZR: 08 rzr
Member #18568
Um, yes there is. Otherwise there wouldn't be a ball joint that threads in to the upper a arm and has a locknut. The stock aarms don't have any adjustments but these arms do.
Old April 20th, 2011, 08:51 PM   #6
Mad Scientist
martymoe's Avatar
First Name: Marty
My RZR: 08 RZR 800 & 12 RZR XP
Member #385
View martymoe's Photo Gallery(7) Send a message via MSN to martymoe Send a message via Yahoo to martymoe
he has the superatv kit, they have a heim for a ball joint(with adjustment)
most likely it's already pretty close, put it all together and eyeball it.. the biggest thing is that their both the same.
2008 RZR 800 (built apr 27 07)
2012 RZR XP 900 (built apr 21 12)
2000 Banshee
(4) 2000 Scramblers
(4) 2002 Blasters
20?? Eaton Rascal 40
martymoe is offline   Reply With Quote
Old April 21st, 2011, 05:28 AM   #7
Super ATV's Avatar
Member #7943
So I am assuming you have the +6 kit? The +5 kit that has the 1.5" offset does not have heims, but the +6 kit does. Adjusting that heim is all in how you have the other heims adjusted as well. The easiest way to adjust it is to play around with it with by placing a angle finder on the brake rotor.
Old April 21st, 2011, 11:31 AM   #8
RZRTOURS's Avatar
First Name: TROY
Member #25042
My mistake, I was just referring to stock Arms. Its nice to know super atvs kit has adjustment.
Old April 21st, 2011, 04:00 PM   #9
First Name: Preston
My RZR: 08 rzr
Member #18568
No problem. I have the 1.5 or 2 in forward offset standard 50" aarms.
Old May 19th, 2011, 05:13 PM   #10
ADKrzrlvr's Avatar
First Name: Frank
My RZR: 2016 1KS
Member #18783
View ADKrzrlvr's Photo Gallery(0)
I just received my set...on the upper heims what angle am I looking for??? 90??? does it matter if I run radials or not, set them both the same regardless I assume. You should update the instructions...mine says 2" forward when I thought I ordered 1.5" and to reuse the lower ball joints. Besides that the quality looks great. Frank D
ADKrzrlvr is offline   Reply With Quote
adjusting heim joints, offroad
ball joint adjustment
ball joints for superatv offset a-arms
how to adj adj balljoints
how to adjust a ball joint
how to adjust ball joints
how to allign offset ball joints
offset upper ball joints 1.5 adjust how far
polaris rzr 800 offset a-arm adjustment
renegade a arm camber
rzr 800 reuse ball joints
rzr forum forward a-arm top ball joint
top ball joint for forward a arm kit
upper ball joint adjustment
Ball Joints HivoltageRZR Engine and Drivetrain 17 August 29th, 2010 10:29 PM
ball joints buckethead General RZR Discussion 11 December 15th, 2009 04:19 PM
Ball joints buckethead General RZR Discussion 0 December 9th, 2009 10:17 AM
bad ball joints azrzrrider Suspension 13 July 13th, 2009 11:49 PM
Could ball joints be done already ? hearnmanzr2 General RZR Discussion 4 August 13th, 2008 10:38 PM
