This is a discussion on CROW 5 Point harnesses within the Seats and Belts forums, part of the Safety category; Which ones work i bought a set and found out they dont fit over the high back seats. which model does crow make that would ...
Which ones work
i bought a set and found out they dont fit over the high back seats. which model does crow make that would work or which company has a 5 pint that will work? |
| Sponsored Links | ||
Re: CROW 5 Point harnesses
I"m not sure why you are saying that Crow does not work. I just installed a set of 3" 4-point Crows this weekend and they work fine. Love them. Bought them from UTV Crap. Did you run them over the lower roll bar as you should have?
Crow sand car harness pn 11554 is the 2" 4-point Y-harness with aircraft-type latch.
The 5-point 3" that fits Rzr is supposed to be pn 11004 The shoulder harness in these can either bolt down or you remove the lug and wrap the webbing around the roll bar. HotRide4U has them on eBay all the time. Just search "Crow Rzr" If you want something special (different latch, different ends, etc) call Fred Crow Crow Enterprises 160 E. Freedom Avenue Anaheim, Ca 92801 714-879-5970 FAX 714-680-4776 http://www.crowenterprizes.com
_______________________________ Why buy the cow? Romeo, MI |
I bought two sets of 5-point harnesses from my friend that has a shop.
These are 3 inch padded shoulder belts in red. The number on the box is 20132-P should I return these and get the pn 11004 units? Are they padded shoulders? I did also get the wrist restraints. Crow sand car harness pn 11554 is the 2" 4-point Y-harness with aircraft-type latch.
The 5-point 3" that fits Rzr is supposed to be pn 11004 The shoulder harness in these can either bolt down or you remove the lug and wrap the webbing around the roll bar. HotRide4U has them on eBay all the time. Just search "Crow Rzr" If you want something special (different latch, different ends, etc) call Fred Crow Crow Enterprises 160 E. Freedom Avenue Anaheim, Ca 92801 714-879-5970 FAX 714-680-Crow Enterprizes Home
No issues whatsoever. I installed the Y type and did have to buy 2 longer bolts and 8 washers (4 for each side) for where the Y attaches so that the bracket will clear the plastic in the back. There is a thread here that explains it very well. I used the existing top bolt of the 3 point to secure the outside of the 4-point and the existing bolt of the inside 3-point to secure the inside of the 4-point. The most time consuming part is making the first adjustment of the Y belt in the back to get it to the right height for the should straps. Spent about an hour total.
#8
I installed the 2" 4-point harnesses and posted about it here:
http://www.rzrforums.net/projects-ho...esses-rzr.html I slightly preferred the look of the Y shoulder straps over the separate ones but both function & cost the same. The Crow 2" harness looks like it would mount up exactly like the ones I used but you may need to call them to get the bolt lug for the tail. The RJS belts include both for either a wrap-around or bolt-down tail attachment. I don't have any experience mounting the 3" belts in the Rzr so I don't know if these are as easy to mount as the 2" or if there are some different issues to deal with. |
#9
I used your directions to mount the 3" belts and it went fine for me. Thanks for the tip about the "special" pliers for the plastic fasteners. I never knew that was in the toolkit.
#11
The toolkit that should have been under the hood when you bought it. There are a pair of pliers in it that have a notch in the end so you can pull the black plastic fasterners out very easily.
#14
RZR Forums.net - Polaris RZR Forums, Events, Discussion, Classifieds, and More! > Forum Vendors > UTV Crap
UTV Crap Polaris RZR Billet Harness Slot for OEM Seats
![]() 623.934.3070 Please understand we support many forums and cant keep up with Private messages or questions on the forum boards so If you have a question Please Call the Retail Shop 623-934-3070
#15
UTV Crap <----click there
this is what you need with Y harnesses to do it right ....this is really the way they should all be done because the stock seats are so wide it the top the harness could slip off your shoulders
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| DFR 4 Point Harnesses | gdog | Seats and Belts | 87 | February 18th, 2010 12:21 PM |
| Crow 4pt Harnesses FS or Trade | outlandish | RZR's and Parts | 2 | February 6th, 2009 11:06 AM |
| Crow Harnesses | joe1045 | General RZR Discussion | 12 | September 10th, 2008 08:33 AM |
| 4 point harnesses | USMCSKI | Roll Cages and Safety Equipment | 14 | July 28th, 2008 07:02 PM |
| Best Price - Crow 4 point? | gdog | Seats and Belts | 1 | July 2nd, 2008 06:09 PM |
