cannot pull the seat belt to buckle it! |
April 2nd, 2008, 08:55 AM
my seat belts have never been out of the vehicle, and i have never tampered with them at all. but they still want un-roll. i dont have any idea what is wrong. has anyone else had this problem?
Re: cannot pull the seat belt to buckle it! |
April 2nd, 2008, 09:35 AM
Very common. They get dust and mud, and crud in them. I use the garden hose at pressure in mine, while jerking on them untill they release, and then keep the hose in there while unrolling the entire seat belt a couple times. Once you have them free, repeate process with WD40. I did this one time when they were fairly new, and havent touched them since. Or you can throw them in the trash, and buy some harnesses.
April 2nd, 2008, 09:40 AM
First Name: Al
My RZR: 08 Red
I haven't had a problem with mine but I do use them quite a bit and hose them down during cleaning, lucky I guess.
April 2nd, 2008, 09:53 AM
First Name: Brian
I had the same problem after my first ride..the passenger side worked but not mine..went home and clean the rzr and then both wouldn't work..its in the shop now for blown rings, and we told them about the seat belts, they said they haven't heard of problems with them but would replace them
08 RZR, 3" Extreme Lift, 30" Mud Lites, ITP Tires, Extreme Snorkel Kit
April 2nd, 2008, 12:02 PM
The rzr need harnesses I would just rep;ace them with harnesses. JMO
April 2nd, 2008, 12:18 PM
I had the same thing to happen to me when I bought mine so I trashed them and bought harnesses....those inertia locks in them suck because they clog up with dirt. then if you remove them and they roll up, you're toast because they will NOT roll back out.
April 24th, 2008, 06:58 AM
First Name: Larry
My RZR: 08 RZR
My Passenger Side Also Did The Same Thing
I Talked To The Dealer And He Told Me There Was At Least 5 That He Had Recently Do The Same Thing.
July 12th, 2008, 11:52 AM
My RZR: Red 2008
I just went through this same problem with the passenger side seat belt. Thank god I remembered viewing this thread  . I also finally worked the seat belt free with the pressure washer. Then pulled it all the way out & washed the crap out of the inside (lots of dirt & mud). With the belt still out, I laced the inside with WD-40 & then retracted the belt. Wolla  its working fine. Thought I would pull the drivers side out & take a Boo. Tons of mud & dirt found. I repeated the process. I think its safe to say that if your riding in some harsh conditions with stock seat belts. You might have to periodically maintain these steps to keep them workin all the time.
July 28th, 2008, 09:41 PM
My RZR: 2008 RZR
I just encountered this problem on my recent Dusty Vacation and after I cleaned it thoroughly with a good pressure burst of water I used some new dry film spray and it worked a little better than new.
...Light travels faster than sound. That's why some people appear bright until they open their mouth and you hear them speak...LTCG
July 29th, 2008, 06:21 AM
My RZR: green RZR
I got locked in my RZR in the middle of a ride...pretty dam funny. In the garbage they went.
July 29th, 2008, 01:31 PM
My RZR: 2008 RZR
Now that sounds like something that would happen to me!
I can imagine that cell phone call now!
August 4th, 2008, 06:30 AM
First Name: Andy
My RZR: 2008 gen2
Get Harnesses!!!!!
"I THINK we can make it"
August 4th, 2008, 06:35 AM
First Name: Andy
My RZR: 2008 gen2
belt would'nt pull out this weekend after about 2 hours of mud riding. kept riding, had a rollover and as I type this sitting on the couch with a broken collarbone I can tell you. BUY the harnesses Its a hell of a lot cheaper in the long run..
