Going down a steep HILL - Polaris RZR Forum - RZR Forums.net
 13Likes
post #1 of 17 Old April 19th, 2017, 07:26 AM Thread Starter
bamagurl's Avatar
My RZR: 2016 Turbo XP RZR
Member #194873
View bamagurl's Photo Gallery(0)
Cool Going down a steep HILL
I have a 2016 RZR XP Turbo. On the Turbo's when going down a steep hill the back end tends to come around. What is the best way to handle this situation? Would it be best to drive the turbo in low 4wd or place in neutral? Does anyone else have this problem? I'm still new to the RZR family so I'm still trying to get use to it.
bamagurl is offline
post #2 of 17 Old April 19th, 2017, 07:46 AM
JDeere7296's Avatar
Member #111697
View JDeere7296's Photo Gallery(0)
Re: Going down a steep HILL
I don't have a turbo but my 1000XP does the same thing, it's basically a weight ratio thing. The engine in the back is heavier and it will tend to slide sideways as gravity pulls your bike downhill. This especially happens in wet or muddy situations.
I put my RZR in low AND in 4WD when going down steep hills. Don't put it in neutral going down a hill, it's harder to control your speed and if your back end does start to go sideways you can use your front tires when in 4wd to help straighten yourself out. In neutral you wouldn't be able to do this.
Oh, and welcome to the forum!!
bamagurl likes this.
I thought building guns was an expensive habit until I bought my first RZR!!!
2013 RZR 4 - ProArmor doors, Protop roof, 28" Moto MTC tires, SuperATV winch & Wild Boar bumper, Racertech HD springs & Dalton Clutch Kit.
2017 RZR 1000 Highlifter Edition - Shock Therapy tender springs, S3 5" lift, Dalton Clutch Kit, Clutch Blower, Powerbase Sound bar.
JDeere7296 is offline
post #3 of 17 Old April 19th, 2017, 08:01 AM
3pedal's Avatar
First Name: Kevin
My RZR: 15 1000XP VooDoo Blue
Member #37792
View 3pedal's Photo Gallery(0)
With my XP1K, on a very steep hill I have two footed it down the hill. I give it just enough gas so the drive train stays locked up to give what little engine braking the XP has, and of course the left foot is on the brake. It is a little odd, but seemed to work for me.
auburnu008 and bamagurl like this.
I'd rather have a toy I can use than a tool I try to play with.
3pedal is offline
post #4 of 17 Old April 19th, 2017, 08:09 AM
JDeere7296's Avatar
Member #111697
Yes, I do this as well. Last ride I was on we were going down a steep muddy pipeline road. I was two footing it and I was basically going about a foot or two down at a time. The last 15 or so feet were the steepest and my back end started slipping. I let off the brake got on the gas turned front tires the direction my back end was slipping and straightened up.
post #5 of 17 Old April 19th, 2017, 08:19 AM
LBOrange's Avatar
Member #192641
View LBOrange's Photo Gallery(0)
With my XP1K (no turbo) I put it in low and 4wd so it is ready but I can keep the back in the back primarily by using the brakes and letting it roll as needed. Sometimes the engine braking can cause the backend to break loose where as I feel I can better control just with the brakes. A lot depends on the type of hill. Plus the RZR throws a code if I two foot too much.
LBOrange is offline
post #6 of 17 Old April 19th, 2017, 08:33 AM Thread Starter
bamagurl's Avatar
Member #194873
Yes it does throw a code if 2 footing to much. I've done that before so I have to becareful of that.
bamagurl is offline
post #7 of 17 Old April 19th, 2017, 08:38 AM Thread Starter
bamagurl's Avatar
Member #194873
Friday night we were riding power lines in Tennessee and I've gotten gun shy again. Because I was going down a steep hill and liked to have lost control because the back end came around with me and I almost started flipping. I think I'm in need of lots of practice going down hills. Going up is a piece of cake for me and getting to be a little dare devil lol
bamagurl is offline
post #8 of 17 Old April 19th, 2017, 08:46 AM
LBOrange's Avatar
Member #192641
I think the key decision is whether to keep the clutch engaged. Some scenarios YES but others NO. It's hard to address all of the possibilities. So practice, practice, practice.
LBOrange is offline
post #9 of 17 Old April 19th, 2017, 08:57 AM Thread Starter
bamagurl's Avatar
Member #194873
I've had lots to say because it being the turbo leave in neutral going down it would be easier. But have had some to say place in low 4wd. I had been doing neutral but the other night it didn't seem to work out well because of needing the speed for the next hill.
bamagurl is offline
post #10 of 17 Old April 19th, 2017, 10:44 AM
FRAZR's Avatar
My RZR: 2014 XP1K
Member #82174
View FRAZR's Photo Gallery(0)
Gas that sum-bitch! Yeehaa! You may be able to change out your secondary helix for one with less or no EBS.
Expat and bamagurl like this.
2014 XP1K
FRAZR is offline
post #11 of 17 Old April 19th, 2017, 11:24 AM
Wanna Ride's Avatar
Member #182841
View Wanna Ride's Photo Gallery(0)
You should never go down a hill in any vehicle, in neutral. Descending is like any other driving characteristic... you only get better at it by having more seat time. When your RZR, or any vehicle is descending, you can feather the throttle and brakes, to help control vehicle direction. When you'in neutral, you're completely at the mercy of gravity.
Some riders have the same approach with coming to a stop on street bikes. They prefer to slip it in neutral and just brake to the stop. Much better to downshift, manipulating the transmission and front-to-rear braking, for a much more controlled stop. Use all your resources, not just one.
Like FRAZR said, there might be an advantage to modifying your clutch to better accomodate your type of terrain. I'd recommend talking to a reputable vendor for recommendations.
Rockwerx and bamagurl like this.
Wanna Ride is offline
post #12 of 17 Old April 19th, 2017, 12:27 PM
Metki's Avatar
Member #164697
View Metki's Photo Gallery(0)
Gas and brake but not too much of either and don't panic
Metki is online now
post #13 of 17 Old April 19th, 2017, 01:19 PM
dj41c's Avatar
My RZR: 12xp rzr 900
Member #40739
View dj41c's Photo Gallery(0)
They don't have helix's for the turbos yet
Rzr xp 900 spray painted springs paper air filter custom plugs in tires pep boys muffler tips with a compass for navagation
dj41c is offline
post #14 of 17 Old April 20th, 2017, 10:26 AM
lenb's Avatar
First Name: len
My RZR: 2013 s bl, blk pearl 14' xp 1k
Member #59085
View lenb's Photo Gallery(0)
thats quite a cage bamagirl.. who built it. wild
lenb is offline
post #15 of 17 Old April 20th, 2017, 10:49 AM
Mr Tommy's Avatar
First Name: Tommy
My RZR: 2011 RZR 800 S Military Desert Tan
Member #192865
View Mr Tommy's Photo Gallery(0)
I agree! Cool!
"Nobody cares what you REALLY do, as long as the paperwork looks good".
Mr Tommy is offline
Mike’s Peak Hill Climb Challenge RuggedRadios Short Track Racing 0 October 10th, 2016 03:17 PM
Limp mode on long steep hill 1stgear RZR 900 - 50'' Trail Models 2 May 28th, 2016 01:08 PM
My XC race write-up from Endeavor Bridgeport (2016 TORN rd 2) Mikeyboy_esq Short Track Racing 2 April 21st, 2016 01:16 PM
My XC race write-up from Oak Hill MX (2016 TORN rd 1) Mikeyboy_esq Short Track Racing 8 March 23rd, 2016 12:35 PM
2015 1000XP Fox Drivetrain Vibration after backing up hill - an idea? Itstoolate RZR XP 1000 5 February 23rd, 2016 12:59 PM
