Tire question - Polaris RZR Forum - RZR Forums.net
 11Likes
post #1 of 39 Old April 17th, 2017, 07:19 PM Thread Starter
waller49's Avatar
Member #81374
View waller49's Photo Gallery(0)
Tire question
I have a 16 Turbo razor. I was wondering what tire combination people were using for all four corners people told me to go with the skinny tire that it handles better but others say that the Turbo has too much power for the skinnier tires what are people running
waller49 is offline
post #2 of 39 Old April 18th, 2017, 06:13 AM
rynomx785's Avatar
First Name: Ryan
My RZR: 15 XP 4 1000
Member #61131
View rynomx785's Photo Gallery(0)
Re: Tire question
Most people are running 30/10, 31/10, or 32/10 tires on 14x7 or 15x7 wheels.
IMO opinion a 10" wide tire is plenty sufficient on a Turbo and you just need to make sure you pick a good tire for the type of terrain that you generally ride in.
rynomx785 is offline
post #3 of 39 Old April 18th, 2017, 07:02 AM
sand shark's Avatar
First Name: Noel
My RZR: XP1000
Member #23358
View sand shark's Photo Gallery(0)
Re: Tire question
What type of riding do you do? All the turbos in the group I ride with are running 32" tires. They all run the wider tires, but they all like to do trails and rock crawling.
I just put 31" Ultracross R-Specs on my XP1000. Was out in the desert this past weekend and was super happy with the performance. We did some rocky trails and they have great grip.
sand shark is online now
post #4 of 39 Old April 18th, 2017, 07:33 AM
rynomx785's Avatar
First Name: Ryan
Member #61131
Re: Tire question
How tall do they measure off your car? I think those will be my next tire as well.
post #5 of 39 Old April 18th, 2017, 09:18 AM Thread Starter
waller49's Avatar
Member #81374
Re: Tire question
I guess I will go with a offset wheel and the M1 evel 30" tire
waller49 is offline
post #6 of 39 Old April 18th, 2017, 09:25 AM
Acer2428's Avatar
My RZR: '16 XP Turbo
Member #84839
View Acer2428's Photo Gallery(0)
Re: Tire question
32x10 Maxxis Carnivores on mine on 14x7 STI HD5's
Acer2428 is offline
post #7 of 39 Old April 18th, 2017, 09:39 AM
sand shark's Avatar
First Name: Noel
My RZR: XP1000
Member #23358
Re: Tire question
I believe they measured right at 31" at 15psi. I knocked the PSI down to 10, so I will have to measure again.
Amazing how much better the car rolls with the bigger tires. I was very impressed with the tire. Also nice that they do not balloon up when you are doing over 60mph, like the stock big horns.
rynomx785 likes this.
post #8 of 39 Old April 18th, 2017, 09:48 AM
rynomx785's Avatar
First Name: Ryan
Member #61131
Re: Tire question
I am running 30s currently and I really like them. They are pretty short though and only measure 29.5" at 12 PSI. My back tires are toast and it's time for new ones. Not sure how that happened.
post #9 of 39 Old April 18th, 2017, 09:48 AM
sand shark's Avatar
First Name: Noel
My RZR: XP1000
Member #23358
Re: Tire question
deleted for double post
post #10 of 39 Old April 18th, 2017, 09:52 AM
sand shark's Avatar
First Name: Noel
My RZR: XP1000
Member #23358
Re: Tire question
Try to find a 5+2 off-set, if possible. Less feed back in the steering wheel.
I went with a 4+3 and had feed back in the steering wheel. Could of been a combo of the off-set and the bigger tires.
post #11 of 39 Old April 19th, 2017, 09:07 AM
sand shark's Avatar
First Name: Noel
My RZR: XP1000
Member #23358
Re: Tire question
I measured my tires last night and looks like they are right around 30 1/2" with 10psi in them. I think next time out I am going to run them at 12 psi.
BruceSherer likes this.
post #12 of 39 Old April 19th, 2017, 07:39 PM
NW Mt.rider's Avatar
First Name: Jeff
My RZR: 16 rzr xpt
Member #173017
View NW Mt.rider's Photo Gallery(0)
Re: Tire question
I ran 32x10x14 roctanes on itp black ops dual beadlocks (73lbs a corner) for a year and went through 4 belts 1000 miles. Mostly deep snow ridding. Just mounted 15" methods with 32x10x15 aftershock XDs (52lbs a corner) approximately... huge difference!!!!!!
NW Mt.rider is offline
post #13 of 39 Old April 19th, 2017, 09:32 PM
mannysouza's Avatar
Member #48340
View mannysouza's Photo Gallery(0)
Re: Tire question
I am running 32" tensors on 14" method beadlocks. I wouldn't want it any other way.
mannysouza is offline
post #14 of 39 Old April 20th, 2017, 05:07 AM
rynomx785's Avatar
First Name: Ryan
Member #61131
Re: Tire question
52 lbs for a 32/10r15 tire/wheel setup is REALLY light. A 15" Method 401 is 19 lbs by itself and a 30" Aftershock is 35 lbs. How much does the 32 weigh? You running the new Roost non beadlock wheels?
post #15 of 39 Old April 20th, 2017, 06:46 AM
First Name: Jeff
My RZR: 16 rzr xpt
Member #173017
Re: Tire question
ID:	415217 the aftershock is 37.7lbs. I was off bc the method 401 14" I weighed was 14lbs. This is a 15".
Wheel offset vs Suspension performance Shock Therapist Shock Therapy 148 April 5th, 2017 06:09 AM
Lift / Tire Size Question??? WFMike RZR 4 Specific Discussion 31 December 21st, 2016 04:27 AM
Tire question from a newbie sfsapper Wheels and Tires 2 November 30th, 2016 03:36 PM
DIY Tire Changing BeadBuster Projects and How-To 0 November 28th, 2016 02:22 PM
Which Tires? wwpuller RZR XP 4 1000 34 September 25th, 2016 07:47 AM
