2017 Turbo top speed - Polaris RZR Forum - RZR Forums.net
 2Likes
post #1 of 43 Old February 4th, 2017, 06:55 PM Thread Starter
cowboys football's Avatar
First Name: Scott
My RZR: 2015 RZR XP 1000 Voodoo Blue
Member #81409
View cowboys football's Photo Gallery(0)
Does anyone know the top speed of the 2017 RZR 1000 Turbo? (168 HP)
cowboys football is offline
post #2 of 43 Old February 4th, 2017, 07:49 PM
Bako RZR's Avatar
My RZR: 2017 RZR 1000 Turbo
Member #177297
View Bako RZR's Photo Gallery(0)
Re: 2017 Turbo top speed
Mine did like 70
Bako RZR is offline
post #3 of 43 Old February 4th, 2017, 08:05 PM Thread Starter
First Name: Scott
Member #81409
No way, my 2015 xp 1000 will do 82, sorry but I don't believe that unless they cut back the speed limiter. If they did, that sucks, you need to get an ECU tune!
post #4 of 43 Old February 4th, 2017, 08:19 PM
Dstew619's Avatar
My RZR: 2017 Turbo XP4
Member #174273
PHP Code:
Just because it a turbo doesn't mean the top speed is higher, it'll just get there quicker. It would have to be geared differently to get a true higher speed limit. An ecu reflash won't change that either unless you are hitting a factory speed limiter and getting rid of that with the reflash. Not sure the factory has a speed limiter though, I only hear about rpm and rev limiters.
Dstew619 is offline
post #5 of 43 Old February 4th, 2017, 08:30 PM Thread Starter
First Name: Scott
Member #81409
I suppose that is true, it has a lot to do with the gearing. Just seems strange that a motor with that much horsepower would be slower. I think you are right about the ECU tune, they remove the rev limiter and rpm limiter. Not sure about the speed limiter.
post #6 of 43 Old February 4th, 2017, 09:09 PM
Kakarot's Avatar
Member #159769
View Kakarot's Photo Gallery(0)
I just got my hands on something to flash my machine and the stock Ecu has a speed límit of 85 in High gear 50 in reverse and if am not mistaken 60 or 65 in Low gear so yes it's limited everywhere this thing rocks can edit all of that can even edit the DTC disable them
Kakarot is offline
post #7 of 43 Old February 5th, 2017, 05:48 AM Thread Starter
First Name: Scott
Member #81409
So you're saying that the top speed is 85 mph from the factory? If so that makes more sense than 70 mph. Also, what is DTC? So how fast will it go after you do your tune?
post #8 of 43 Old February 5th, 2017, 07:00 AM
docbones's Avatar
Member #6630
View docbones's Photo Gallery(0)
Guys mine did 78 stock. With BMP stage 2 flash and stage 2 clutching exhaust etc. now see 87-88 mph
docbones is offline
post #9 of 43 Old February 5th, 2017, 08:44 AM
Michigan man's Avatar
First Name: Dan
My RZR: 2016 matte red xpt
Member #130625
My 16 turbo will hit 90 plus with two guys, it has an evo tune. Evo does raise the top speed limiter. Also lifts the torque limiter as well.
evo stage2 tune, evo bov, osp clutch kit, Polaris half windshield, Polaris roof, siezmik mirrors, prp door bags, trinity stage5 exhaust, 3p shims, a little rubber bendy pink panther dude hanging on the roll cage for dear life! and I'm sure I'm missing some stuff.
Michigan man is offline
post #10 of 43 Old February 5th, 2017, 08:47 AM
First Name: Dan
Member #130625
I think evo claims that with their reflash they raise top speed to 93.... I can tell you first hand that 90 is a Rzr is getting it!! Surprisingly stable though
post #11 of 43 Old February 5th, 2017, 09:00 AM
Bako RZR's Avatar
Member #177297
Ok just to clarify a bit, my top speed of 70 was its first run out of the box. 3 adults in the car, on a pretty flat trail. I had it pinned and glanced at the speedo. Will it do 80, 85? Probably, for all I know it'll do 100 but it seemed to be topped out at the time.
Bako RZR is offline
post #12 of 43 Old February 5th, 2017, 04:52 PM
dj41c's Avatar
My RZR: 12xp rzr 900
Member #40739
View dj41c's Photo Gallery(0)
250 mph
DBR1990 likes this.
Rzr xp 900 spray painted springs paper air filter custom plugs in tires pep boys muffler tips with a compass for navagation
dj41c is offline
post #13 of 43 Old February 5th, 2017, 04:53 PM
dj41c's Avatar
Member #40739
Why does it matter? It only matters if you can drive it that fast 10% of the time I bet you are below 20 mph average
dj41c is offline
post #14 of 43 Old February 5th, 2017, 05:37 PM
First Name: Dan
Member #130625
The op asked a question and I gave him an answer..... And by the way. My average is higher than 20. I ride 99% trails, and they are pretty wide and fast for the most part.
post #15 of 43 Old February 5th, 2017, 09:08 PM
dj41c's Avatar
Member #40739
Don't care
dj41c is offline
Deeper Explanation of Shift RPM Hunterworks Hunterworks 19 June 13th, 2017 06:55 AM
2011 XP900 AEROCHARGER Turbo build PT#1 Hooty222 Forced Induction 72 January 2nd, 2017 11:59 PM
2017 turbo Braap857 RZR XP Turbo 35 December 11th, 2016 07:46 AM
2017 sway bars on a 2016 Turbo zzaaiinn RZR XP Turbo 3 November 21st, 2016 07:25 PM
45 mph top speed Shep RZR 800 Specific Discussion 29 March 10th, 2016 02:44 PM
