If you had not replace only two shocks, front or rear? - Polaris RZR Forum - RZR Forums.net
This is a discussion on If you had not replace only two shocks, front or rear? within the RZR XP Suspension forums, part of the Technical category; Sorry for all the posts in this forum. I'm really trying to find a good way to compromise without compromising. I'm thinking of doing a ...
Go Back   Polaris RZR Forum - RZR Forums.net > Technical > RZR XP Suspension
Old June 10th, 2012, 06:36 PM   #1
rshosted's Avatar
Member #19849
View rshosted's Photo Gallery(0)
Sorry for all the posts in this forum. I'm really trying to find a good way to compromise without compromising. I'm thinking of doing a front or rear only purchase, then upgrade the other in a month or two. It is silly, but it makes me feel not so bad about spending so much on suspension.....
I'm thinking kings, walker evans or exits. I want something with rebound adjustment too
I've ruled out cognito becuase they don't come with a spring, fox becuase it's just a rebuild, and afco becuase of the remote resivour.
Thanks again.
rshosted is offline   Reply With Quote
Old June 10th, 2012, 06:41 PM   #2
bagman's Avatar
My RZR: 2015 1K Havasu Red
Member #649
Re: If you had not replace only two shocks, front or rear?
Rears. Fronts are easy to dial in, the rears are where the action is IMHO
bagman is offline   Reply With Quote
Old June 11th, 2012, 12:56 PM   #3
BIGGJIM's Avatar
First Name: Jim
My RZR: R1 Powered Rhino
Member #3236
View BIGGJIM's Photo Gallery(0)
Thanks again.
I Have spring options for the rear for guys like you that just dont want to use the stock springs. The stock springs work great but our true dual rate does work better. Believe it or not the XP doesnt seem to have the same spring issue as the RZR S did.
Also to answer your question...the rear is getting all the abuse. So i would start there.
WWW.COGNITOMOTORSPORTS.COM
JIM@COGNITOMOTORSPORTS.COM
661-588-8085 X206 UTV SALES
BIGGJIM is offline   Reply With Quote
Old June 11th, 2012, 01:42 PM   #4
rshosted's Avatar
Member #19849
Whoa! Jim.... Easy I think there are rules on this forum.
And back on topic, can you give me a ballpark price for shocks with springs?
Old June 11th, 2012, 02:25 PM   #5
BIGGJIM's Avatar
First Name: Jim
Member #3236
LOL Crazy! The front and rear shock kit is 1999.99 so half that would be rears only. The spring kit is 299.99. The only catch is you still have to use some of your OEM shock parts. Frame reducers, collars, and you lower spring retainer/rock gaurds.
Old June 11th, 2012, 05:56 PM   #6
rshosted's Avatar
Member #19849
That's too bad 'cause I plan to sale my old shocks. I'm sure they wouldn't sale with missing parts.
Seems to put your shocks back of the pack, even though I've only heard good things about them.
Old June 11th, 2012, 06:33 PM   #7
BIGGJIM's Avatar
First Name: Jim
Member #3236
To be 100% honnest with you, The difference I have seen is from 600 complete to 400 incomplete. The price to replace the oem parts is more than the difference that you make up selling them complete. Its the rock gaurds and such that get spendy. We are working on offerning them complete, it just has not made sence to most of my customers. Good luck with what ever choice you make, and if we can help you in the future let us know!!!
can i change only the rear shocks safely?
can i replace front suspension only
can you replace only two shocks
exit shocks vs walker evans
i sit ok to only replace from shocks
if you. put shocks on just the front and not back will it be ok
is it bad to just replace the front shocks
is it ok to change just the front shocks
is it ok to replace rear shocks and not fronts
is it safe to only change two shocks
is it safe to only replace front shocks
ok to replace 2 shocks?
replace only front shocks
safe only to replace just the back shocks
which shocks replace first rzr front back
Want to replace Sachs shocks Sammy RZR-S Specific Discussion 5 May 30th, 2012 02:21 PM
How long did it take you to replace your front/rear bushings? atvrider07 General RZR Discussion 11 May 17th, 2012 09:06 PM
what shocks to get to replace the fox dougr RZR-S Specific Discussion 21 November 21st, 2010 05:48 PM
Rear shocks/springs on the front now HioSSilver Suspension 38 February 5th, 2010 04:31 PM
can i replace the shocks instead of lifting? jevans5050 General RZR Discussion 6 June 17th, 2009 09:05 AM
