Jan 25, 2013
Does anyone know if there is a rev limiter in the 2012 XP? At WOT 70 mph it runs a little rough and cuts out a bit
Jan 25, 2013
Not sure Chris I wasn't paying attention, just the speedo
Jan 25, 2013
I think will be same as on 2011, rev limit start to cut in around 8500 RPM.
milos
Jan 26, 2013
Two things I can think of that would cause it to hit limiter early is smaller tires on rear
Belt worn
Primary hanging up
What is the RPM?
Jan 26, 2013
Does is sound like this........."NIIIIIIiiiiing ning-ning-ning-ning-ning-ning"
Jan 26, 2013
Lmao!!!! No it sounds more like a missing cylinder or fouled plug but stops sputtering when u back off the throttle. Seems fine at any other speed
1
Jan 26, 2013
rev limit is a set point doesnt change... so with aftermarket ex your ether running lean or the pipe changed your power curve
#13
Jan 26, 2013
If I were running lean, how would that lower my top speed(hitting the rev limiter too soon)?
Sorry to hijack, but it's related. :beer3:
0
Jan 26, 2013
Could it be possible that your factory clutching is little on light side. I know with adjustable weight clutch kits you can add weight on the toe to keep the rpms down and keep it from bouncing off the rev limiter. Just a thought don't know how common it is for factory clutching being off.
Just my thoughts on it,
Nathan
#15
Jan 26, 2013
I would say never off for a totally stock machine but anything is possible I guess
1
