Flash ECM - Polaris RZR Forum - RZR Forums.net
Flash ECM
This is a discussion on Flash ECM within the RZR XP 900 forums, part of the General RZR category; Has anyone flashed their ECM? I'm looking into getting a little edge with my 900 and still race in the stock class. Does it make ...
Old December 29th, 2012, 09:49 AM   #1
wheelin-Roy's Avatar
First Name: Roy
My RZR: 2014 1000 4 XP Heel Clicker Viper Winch Polaris Full Doors Beard Four Point Harness Custom Cage
Member #24858
View wheelin-Roy's Photo Gallery(0)
Rzr Icon Flash ECM
Has anyone flashed their ECM? I'm looking into getting a little edge with my 900 and still race in the stock class. Does it make a noticeable difference? I want to stay as close to stock as possible right now or is there something else that would get the same results? We are racing on .7 mile course in Central Oregon. Any help would be great. Thanks
wheelin-Roy is offline   Reply With Quote
Old December 29th, 2012, 09:58 AM   #2
Hunterworks's Avatar
First Name: Todd
My RZR: 2016 XP1000
Member #47437
Re: Flash ECM
Flashing the ECM with everything being stock is not going to give you a edge nor is adding a programmer.
I race and we have our own dyno etc and I can tell you without a doubt that is not going to give you a edge.
Actually, the difference is going to be in the driver. Last race I passed everyone in the unlimited class while in the modified class although I should have been in the stock class.
The largest mistake people make is bad combinations of products that were not meant to run together.
If you are like me and put 26x9x12 on rear to I can tell you that you need a clutch change and if you hate the amount of engine braking while jumping and landing then a change in a helix in secondary clutch is in order both of which I can help you with.
Todd
www.hunterworks.com
Todd
Office phone: 601-771-0070
Hunterworks is offline   Reply With Quote
Old December 29th, 2012, 11:37 AM   #3
Feedback Score: 6 reviews
rappy60guy's Avatar
First Name: Kc
Member #19623
View rappy60guy's Photo Gallery(3)
Re: Flash ECM
Correct me if im wrong Todd, but one of the benifits of the ECU overwrite is the added rev limiter adjustment. If your in the high rpms banging the rev limiter i think this would help. Then there is all the timing adjustments that unfortunately i cant say i know how they help im not that knowing about motors. Wish i was.
rappy60guy is offline   Reply With Quote
Old December 30th, 2012, 07:43 AM   #4
First Name: Todd
My RZR: 2016 XP1000
Member #47437
Re: Flash ECM
THat's true but are you going to be racing over 75mph? I never reach speeds over 65mph where I race.
Best money would be spent on a PCV so you could adjust timing, add the 500 RPM, adjust fuel now and in the future.
The change in timing will not be felt in your butt.
Todd
www.hunterworks.com
Todd
2014 rzr 1000 speed sensor problems
best ecm upgrade 900 rzr
ecm polaris 1000
ecm polaris rzr 900 2011
ecm reflash rzr 900
ecm reflashing for polaris rzr
flash ecm
flashed ecm
flashed ecm on xp 900
how do you flash code a rzr
polaris ecm flash
polaris ranger xp 900 ecm upgrade.
rzr ecm flash
rzr ecm reset
rzr xp 900 ecm
900 ECU Re-Flash BRX RZR XP 900 56 August 31st, 2013 01:56 PM
To flash or not to flash DBR1990 RZR ECU Tuning 7 December 23rd, 2012 09:59 PM
xp 900 ECU Flash? Diagnostics? jordan07 RZR XP 900 0 April 16th, 2012 09:28 PM
? Hot Flash? RightFootDown Engine and Drivetrain 4 September 19th, 2011 06:23 AM
Help. Flash Code 51 and 52. R1rida Engine and Drivetrain 7 June 13th, 2011 04:23 PM
