Brake safety start - Polaris RZR Forum - RZR Forums.net
post #1 of 6 Old September 11th, 2012, 08:12 PM Thread Starter
murdock's Avatar
Brake safety start
Lately i have had to push my brake alot harder to get the ignition to kick in. Is there an ajustment for this?
murdock is offline
post #2 of 6 Old September 11th, 2012, 08:22 PM
RMR Man's Avatar
Re: Brake safety start
Murdock, the brake safety switch is on of the few on the RZR that isn't a sealed connection. I noticed my was rather nasty on a recent service job. Remove the seats and the rear panel that covers the clutch housing. There sits the switch on top of the hydraulic brake valve body. Pull the connector off, wire brush the switch contacts, spray some of your favorite liquid on the switch. try it now. If that doesn't help, you may need to replace the switch.
RMR Man is offline
post #3 of 6 Old September 11th, 2012, 09:16 PM
Terso01's Avatar
Is there anyway to disable this feature?
2012 RZR XP 900, 5" HL Lift, 31" outlaws S/W on ITP SS 316, Dirty Dawg Clutching, Gorilla Axles on all Corners, HL Radius Rods, and High Clearance Trailing Arms, HL Forward A-Arms, Triple Threat Motor (935 BBK, 12:1 Compression, Polished/Ported Heads, Alba Stage 3 Cams), Alba Exhaust and PCV/Autotune, Proarmor Doors, Snorkels to the roof, SSV Stereo, Still more to come...
Terso01 is offline
post #4 of 6 Old September 12th, 2012, 04:18 AM
western196611's Avatar
I think you can bypass it but your brake lights will stay on all the time.
2012 RZR 900 XP, Jackson Motor Sport cage, Lone Star arms, Warn 4500 winch.
western196611 is offline
post #5 of 6 Old September 12th, 2012, 04:48 AM
RMR Man's Avatar
I bypassed mine while diagnosing what turned out to be a bad bearing in the nose of the starter motor. I pulled the 2 prong connector off of the switch, and installed a homemade wire with 2 spade terminals across the wire connection. Now I don't have to step on the brakes, but that comes off and I go back to factory set up when I am done. It is simply too dangerous to leave it bypassed IMHO.
RMR Man is offline
post #6 of 6 Old September 12th, 2012, 08:27 PM Thread Starter
murdock's Avatar
Thanks guys. Called the dealer today and he said to bring it in to change the brake switch. Oh well i have extended warranty i should use it.
murdock is offline
Disabling the Foot Brake Start Switch Overlord Engine and Drivetrain 29 January 11th, 2015 09:00 PM
Engine want start while pressing brake Boliver P Engine and Drivetrain 18 May 27th, 2014 06:55 PM
engine start/die, start die, give throttle pop/backfire then clean up RacerSam RZR 800 Specific Discussion 10 August 2nd, 2012 08:11 PM
Polaris RZR 800 WTB rear left brake caliper and brake line andyrzr Polaris RZR Parts For Sale 3 June 7th, 2011 11:22 PM
Foot Pedal e-brake or Line Lock e-brake RZRider General RZR Discussion 10 December 12th, 2009 09:04 PM
