Camper Trailer an XP can tow - Polaris RZR Forum - RZR Forums.net
This is a discussion on Camper Trailer an XP can tow within the RZR XP 900 forums, part of the General RZR category; I would like to once again tap into the incredible wealth of knowledge that the members of this forum possess : ). I take clients ...
Old August 30th, 2012, 09:27 PM   #1
KJD's Avatar
Member #32896
View KJD's Photo Gallery(0)
I would like to once again tap into the incredible wealth of knowledge that the members of this forum possess : ). I take clients and friends out on our RZR into the mountain fed rivers in Northern Alberta...fishing quite often in the fall. Usually we go for day trips but it would sure be nice to do overnight trips. Problem is that we usually trailer the RZRs down to an unload point near the caribou gates and then have an hour or two ride down to the rivers on the machines. There really isnt any good spots to pull RV's into where we go fishing and its a pain to have to ride back to the trailer every morning and night...so..
What have you all come across for small campers that:
1.) Can be pulled by a RZR XP
2.) Sleep at least two
3.) Preferably have descent ground clearance
4.) Are made of primarily of aluminum or some light weight material. I prefer to stay away from the fabric options out there do to the excessive amount of curious grizzly bears we tend to encounter.
Thanks again in advance for all of your suggestions...Pics would be greatly appreciated!
KJD is offline   Reply With Quote
Old August 30th, 2012, 09:41 PM   #2
Banned
Feedback Score: 5 reviews
Wren's Avatar
My RZR: 2009 800
Member #42017
View Wren's Photo Gallery(1)
Re: Camper Trailer an XP can tow
Not really sure how much a RzR can tow, but check out these trailers.
Adventure Trailers - Off Road Trailers & Overland Equipment
Wren is offline   Reply With Quote
Old August 30th, 2012, 09:55 PM   #3
phuggit's Avatar
First Name: Curt
My RZR: 2012 RZR 4 LE
Member #27801
View phuggit's Photo Gallery(0)
OMF makes one. I think they run about 3grand.
droidage.....
Work gets in the way of all my fun
phuggit is offline   Reply With Quote
Old August 30th, 2012, 10:26 PM   #4
tightline's Avatar
My RZR: RZR 4 XP
Member #3399
View tightline's Photo Gallery(0)
Check out the Simply Rugged trailers. Devin drug them all over the rocks at Moab 2 years ago behind a rzr. They held up awesome and go over some killer landscapes. They are a hybrid hard sided and canvas. They are tough and in a category all their own. Perfect for a SXS.
tightline is offline   Reply With Quote
Old August 30th, 2012, 11:29 PM   #5
KJD's Avatar
Member #32896
Thanks for the suggestions. Does anyone know what a safe max tow weight for the xp would be in low? It's blank on the spec sheet...probably due to the fact there is no factory receiver.
Old August 30th, 2012, 11:42 PM   #6
dmax61's Avatar
First Name: Tom
My RZR: 2010 RZR-S White
Member #10609
View dmax61's Photo Gallery(0)
Youshould be safe at about 1500lbs
dmax61 is offline   Reply With Quote
Old August 31st, 2012, 12:18 AM   #7
KJD's Avatar
Member #32896
Wow. That's quite a bit more than I expected!!!!
Old August 31st, 2012, 01:08 AM   #8
Cadiero's Avatar
My RZR: 2011 RZR XP 900
Member #24352
View Cadiero's Photo Gallery(0)
Think about it this way....would you feel comfortable towing another RZR home if it broke down? That's 1100-1500 lbs right there! I have towed broke down RZRs with my 700 Sportsman 20 plus miles no problem.
2016 RZR Turbo
32" Roctanes on GMZ LiteLoc wheels, Zbroz high clearance radius rods, Factory UTV Rocker and Skids, PRP harness, RIGID boxes, Superwinch Terra 4500 wide spool winch, 3P clutch shims, Thunder Hawk hitch, heated seats, Tusk aluminum doors, 3 forward facing LEDs, LED rock lights, home made front tow point. Soon to come: cage, axles, high clearance suspension, shocks re-valved and springs.
Cadiero is offline   Reply With Quote
Old August 31st, 2012, 12:55 PM   #9
Standard Vendor
dmcmark's Avatar
Member #36968
View dmcmark's Photo Gallery(0)
Sounds pretty cool.. From what i've read in the manual the XP is good for two passengers and 300lbs. in the bed. The bed weight is centered over the axels, and since your hitch will be past that point that weight will be reduced. Like my deisel truck, if i'm towing a fifthwheel it's good to 17k lbs. if your towing a tag it's only good for 14k lbs. IMO, keep it as light as you can and keep an eye on the tounge weight of the trailer you choose.
dmcmark is offline   Reply With Quote
Old September 1st, 2012, 09:02 AM   #10
KJD's Avatar
Member #32896
Good thinking
Old September 1st, 2012, 09:06 AM   #11
Owner-Light it Up Offroad
Feedback Score: 16 reviews
MATT1524's Avatar
First Name: Matt
My RZR: 2016-Turbo 4
Member #13639
View MATT1524's Photo Gallery(0)
The xp doesnt come with a tow hitch. and i think that is for a reason. The radius rods and trailing arms arent really setup for such. Pulling a broke down machine out once a year is a lot different than pulling a trailer several times a year. Not saying it wont do it, it will. Make sure you prepare to have extra belts on standby, maybe some clutching work done, and good springs/shocks. Not saying dont do it, but make sure you get it setup right, so its safe and easier on the machine.
We Sell: Totron, Viper, Rigid, PRP & MORE!
CALL 479-222-5398
479-434-4161
WWW.GETLITFS.COM
Your one stop shop for all your UTV & Truck needs!
We have a REAL store front!
3201 Wheeler Ave-Fort Smith, Arkansas
MATT1524 is offline   Reply With Quote
Old September 1st, 2012, 10:47 AM   #12
bsracing's Avatar
Member #24039
View bsracing's Photo Gallery(0)
You do have to keep I mind it's not 1500lbs of dead weight. You can easily push around a 1500lb trailer by yourself if you have a wheel on the tongue. I would tow in low gear if you get to some rough stuff. Keep the tongue weight low and 1500lbs shouldn't be anything to it. I had an arctic cat 650 that I could pull around a 20' car trailer to move it around. Well over 1500lbs and half the machine the xp is
bsracing is offline   Reply With Quote
Old September 1st, 2012, 11:10 AM   #13
MATT1524's Avatar
First Name: Matt
Member #13639
Very good point.
But at the same time, if you hooked that 20ft trailer to your atv and tried to drive down the trail, up hills, down hills, thru creeks, mud, sand, etc it would be hard ton the machine no doubt.
CALL 479-222-5398
479-434-4161
WWW.GETLITFS.COM
Old September 1st, 2012, 11:54 AM   #14
bsracing's Avatar
Member #24039
I did tow a long travel rhino back to camp through the dunes in Oklahoma up and over the big ones.. That's pretty much 1500 lbs of dead weight lol.
Old September 1st, 2012, 02:38 PM   #15
MATT1524's Avatar
First Name: Matt
Member #13639
well...it is a rhino....
CALL 479-222-5398
479-434-4161
WWW.GETLITFS.COM
Tags
camper, rxr, trailer
800 polaris ranger camper
camper for polaris ranger
camper for polaris ranger 900
can a jumping jack haul a ranger 570
can a polaris ranger 570 tow 2500 pounds
can rzr tow
how much can rzr 800 pull
how much can the ranger 900 pull
how much weight can my polaris rzr pull
polaris ranger pulling camper
ranger utv camp trailer
trailers able to be pulled by a polaris ranger
where can i pull from on a 900 rzr xp?
xp camper bears
Cargo trailer / camper? USMCSKI Tow Rigs, Trailers and Camping 153 June 5th, 2014 06:49 AM
Cargo trailer camper conversions scott434 Tow Rigs, Trailers and Camping 36 September 7th, 2012 09:33 PM
AWESOME ATV camper Cactus Tongue General RZR Discussion 12 March 21st, 2012 10:08 AM
Vintage 1962 Terry camper trailer Trashpicker Misc For Sale 0 September 24th, 2011 07:11 PM
Camper TennesseeRXP Want to Buy 0 October 25th, 2009 10:29 PM
