Acts Like It's Hitting Rev Limiter at WOT? HELP - Page 2 - Polaris RZR Forum - RZR Forums.net
This is a discussion on Acts Like It's Hitting Rev Limiter at WOT? HELP within the RZR XP 900 forums, part of the General RZR category; Quote: Originally Posted by Fimea Quote: Originally Posted by AlbaNate Quote: Originally Posted by poflo Getting pretty common for the Castle Nut to back off ...
Old August 28th, 2012, 05:57 AM   #16
HIGHOCTANE's Avatar
Member #16360
Re: Acts Like It's Hitting Rev Limiter at WOT? HELP
Quote: Originally Posted by Fimea View Post
Quote: Originally Posted by AlbaNate View Post
Quote: Originally Posted by poflo View Post
Getting pretty common for the Castle Nut to back off in the primary.......I have seen 4 already,including mine
Just had an XP4 do it on the dyno.
Nate
Alba Racing
I'm confused, are you guys referring to the spider jam nut, or the castle lock nut on the shift weights?
Spider jam nut
HIGHOCTANE is offline   Reply With Quote
Old August 28th, 2012, 11:09 AM   #17
Fimea's Avatar
First Name: Rick
My RZR: 2015 XP1000, 2011 XP900
Member #29192
View Fimea's Photo Gallery(0)
Nate
Alba Racing
Spider jam nut
Do you have to buy that tool from Polaris (PU-50578), or is there something else that will work? Since it gets torqued to 250lbs, it needs to be strong. When it backs off, does it come far enough off to allow the spider to come apart? I ask, because the manual says it's imperative to mark all the pieces before disassembly since its a balanced unit, and if it's not reinstalled correctly - the assembly MUST be replaced.
It's to bad Polaris doesn't take the 5 seconds to put a punch mark in the pieces so you can assemble it it the correct sequence.
The manual (pg 6.11) says "Using a permanant marker, mark the cover, spider, movable and stationary sheaves for reference, as the cast in X's may not have been in alignment before disassembly." I guess that's Polaris' way of saying our people are too careless to assemble it correctly, before it goes off to balancing? If it's so critical, why don't they do it right from the factory? You'd expect those X's to be there for a reason...
I guess anyone that ever changes their belt should take the time to mark the pieces so if somebody forgets, it's already done?
Fimea is online now   Reply With Quote
Old August 28th, 2012, 11:31 AM   #18
AlbaNate's Avatar
Member #24131
View AlbaNate's Photo Gallery(0)
I had to order the tool. We have tried tightneing without it twice now and it just keeps coming off...
Nate
Alba Racing
NATE@TEAMALBARACING.COM
LIKE ME AND ALBA!!!
Check us out on Yelp.
AlbaNate is offline   Reply With Quote
Old August 28th, 2012, 03:09 PM   #19
poflo's Avatar
First Name: Don
My RZR: xp 900
Member #11987
View poflo's Photo Gallery(0)
Nate
Alba Racing
SENT PM on the fix
poflo is offline   Reply With Quote
Old August 29th, 2012, 02:10 PM   #20
Fimea's Avatar
First Name: Rick
Member #29192
Nate
Alba Racing
SENT PM on the fix
Is it a good enough fix that it's worth sharing?
Old September 4th, 2012, 05:51 PM   #21
Fimea's Avatar
First Name: Rick
Member #29192
I guess not?
Old September 4th, 2012, 06:54 PM   #22
Cb1300's Avatar
My RZR: Xp
Member #39147
View Cb1300's Photo Gallery(0)
I'm curious about this also. Mine is doing the same thing
Chris
2012 Red xp
Cb1300 is offline   Reply With Quote
Old September 4th, 2012, 07:29 PM   #23
s_melchi's Avatar
My RZR: 2014 1000XP
Member #39704
View s_melchi's Photo Gallery(0)
Well I took mine in for 19 hour service and told them all the things recommended on the forum. They found no water or no loose parts in the clutch. I drove it a few more times before taking it in to the dealer. I think it was water in the clutch cover that evaporated as I drove it.
The dealer found nothing wrong when they test drive it also. So who knows at this point. Taking it to the UP of Michigan for 4 days next week. We will see if it acts up then.
s_melchi is offline   Reply With Quote
Old September 4th, 2012, 07:50 PM   #24
gmeade44's Avatar
First Name: Gary Meade
My RZR: 900XP
Member #37526
View gmeade44's Photo Gallery(1)
Just a little update… I called to see where the dealer was with the figuring out why it was hitting the rev limiter at 55. They told me there was nothing obvious they could see. They have a call in to Polaris on this issue and would let me know what direction they would go. I ask them about the “nut” backing off and they said it was tight. Now here we go…….. There are only two parts to this equation from the best I can tell. It is either the primary or the secondary clutch. For the price I paid, I think they should just replace either both or do a process of elimination to determine which one it failing. I am going to give them till the end of the week and then go pick it up and order a clutch kit for it and do it myself. This is sad to do but at this rate, it is un-telling when I will get it back. I will keep you all posted if any turn of events happen.
gmeade44 is offline   Reply With Quote
Old September 5th, 2012, 09:03 AM   #25
Fimea's Avatar
First Name: Rick
Member #29192
There's a possibility one of your rollers is sticking, or has a flat spot on it, not allowing your shift weights to move all the way out. Your shift weight might even have a rough spot on its back side, Be missing a piece of metal, or be missing one of its bushings. To raise engine RPMs, you need to lighten the shift weights, or keep them from fully extending. (as far as clutching is concerned).
If you pull your cover, then belt (note direction), then using a pry tool, gently spread the primary sheaves together, until you can put your finger in between the roller and shift weight, so you can manually spin the rollers.
Be careful to either use something to hold the sheave together, or make sure your pry tool is secure, so you don't get your finger caught in there. This tool will help:
UTV - Tools - Sheave Clamp Tool - Starting Line Products
Have you blown a belt, and not get all the debris out of the sheave? With the cover off, and the belt removed, start the engine and cycle the RPMs a few times so you can visually inspect that the sheaves are opening and closing properly. I recommend facial protection, because it has the possibility to fling debris out of the sheave with violent force due to the high RPM required to get the sheaves to open.
Here's a link for the spider nut socket:
UTV - Tools - Drive Clutch Spider Nut Tool - Starting Line Products
Good luck!
PS, don't lubricate any of the clutch pieces in a way that some of the lubricant could come into contact with the belt or sheave's belt contact area! Centrifugal force can/will fling stuff everywhere!!!
Old September 5th, 2012, 09:20 AM   #26
HIGHOCTANE's Avatar
Member #16360
You can also remove the 6 primary cover bolts and then the movable sheave will slide freely...so you can check the rollers and weight ect with no need to pry on anything. Mark the cover relationship so you put it back on just as it came off.
Old September 5th, 2012, 09:54 AM   #27
Feedback Score: 176 reviews
swingarm1's Avatar
First Name: Tim
Member #7690
Nate
Alba Racing
Nate
Alba Racing
SENT PM on the fix
I'd be interested to know Don, please send me a PM...
Thank you...
Old September 5th, 2012, 10:04 AM   #28
A.T.F.Performance's Avatar
First Name: Andy
My RZR: 2012 voodoo blue xp 900
Member #42578
View A.T.F.Performance's Photo Gallery(0)
It sounds like a lean condition. Mine did the same The same thing. Power commander and auto tune fixed it right up. These machines are way lean from the factory for emissions.
A.T.F.Performance is offline   Reply With Quote
Old September 7th, 2012, 01:27 PM   #29
gmeade44's Avatar
My RZR: 900XP
Member #37526
Ok, I went and picked my 900 up today. I asked them what they found and the service manager said “ it had a bolt lose in the clutch.” So I ask what bolt it was and he said, it was not the spider nut but a nut that holds one of the rollers in. I ask him if test drove it and he said “yes”. Then he proceeded to tell me it only missed one time around 65mph after they tightened the bolt up (is this normal). He told me to “ride the fire out of it to check it out”. I could not test run the machine at the dealer and had to work tonight but I will take it for a test run in the morning. If it is still not right, I may order a clutch kit for it and put it in myself. I was just wondering if it would void the warranty further down the road. I got the extended warranty (five years) but it does me no good if they can’t fix it…..
Old September 7th, 2012, 01:37 PM   #30
Cb1300's Avatar
My RZR: Xp
Member #39147
Please keep us informed, I'm going to take mine apart tomorrow and I will let you know if I find anything also. Mine accelerates great but when I reach about 55mph the tach goes to 8450rpms and starts skipping it just started this two weeks ago. I noticed it after cleaning it up and driving it down the road to dry it off. Mine is definitely in the clutch. I have had it apart before when I installed the adjustable weights, I'm thinking one of the bolts that hold the arms on is loose also.
Chris
2012 Red xp
2014 rzr 1000 hits rev limiter at 50mph
belt problem
bi18c not getting to rev limiter
polaris pu-50578
polaris sportsman seems to be hitting rev limiter early
rzr 1000 hitting rev limiter
rzr 1000 hitting rev limiter at 25 after being stuck in the mud
rzr 1000 hitting rev limiter at 68mph
rzr 1000 rev limiter
rzr 800 hiccup wot
what causes the rev limiter to hit while still gaining speed on 900s rzr
what happens when ranger 900xp hits rev limiter
xp 1000 rev limiter
xp1000 rev limiter
xp900 lean wide open throttle
Hitting REV Limiter at 50-52 MPH Polaris 900 RZR XP 900 14 June 23rd, 2011 04:50 PM
hitting rev limiter bhamilton1 General RZR Discussion 2 January 29th, 2011 05:56 AM
What is the Rev Limiter RPM - I' Hitting It 2fiftyR Engine and Drivetrain 7 August 8th, 2010 10:53 PM
Still hitting Rev limiter if I stomp it Top Dog Engine and Drivetrain 24 April 14th, 2009 09:42 AM
Hitting Rev Limiter Too Soon HivoltageRZR General RZR Discussion 18 March 25th, 2009 10:59 AM
