Brake pressure switch? - Polaris RZR Forum - RZR Forums.net
This is a discussion on Brake pressure switch? within the RZR XP 900 forums, part of the General RZR category; I have been having some trouble trying to start my 2012 900XP, within the last few times I've had it out it seems like it's ...
Old July 29th, 2012, 07:44 AM   #1
XPWEEZ22's Avatar
First Name: Jack
My RZR: 900XP
Member #41159
View XPWEEZ22's Photo Gallery(0)
Rzr Icon Brake pressure switch?
I have been having some trouble trying to start my 2012 900XP, within the last few times I've had it out it seems like it's getting harder to start, you pretty much have to stand on the brake peddle to get it to start it has never done this before. i have checked the brake reservoir and it is full, I've been reading some forums about the brake pressure switch but a lot of them say "when they go they go"... but i can still get mine to start but like i said you have to pretty much stand on the brake peddle to get it to turn over. anyone have any suggestions thanks guys.
XPWEEZ22 is offline   Reply With Quote
Old July 29th, 2012, 07:48 AM   #2
Feedback Score: 176 reviews
swingarm1's Avatar
First Name: Tim
Member #7690
Re: Brake pressure switch?
First off WELCOME to the forum...
Bleed the brakes as you could have air in the lines... Start bleeding the brakes at the right rear (furthest point from master cylinder), then the left rear, then the right front and finally the left front...
Old July 29th, 2012, 08:00 AM   #3
XPWEEZ22's Avatar
First Name: Jack
My RZR: 900XP
Member #41159
ok ill try that thanks..do these 900 tend to do such a thing? one other thing i forgot to mention is on the top of the reservoir where the cap is it is wet around it, its on tight but it has done this a few times gets wet then dry and wet again?????
Old July 29th, 2012, 08:08 AM   #4
swingarm1's Avatar
First Name: Tim
Member #7690
No not common but it does happen... Make sure the bleeders on each caliper are snug not over tightened just snug...
The fluid could be from air purging from the master cylinder or it was over filled...
If it's under warranty take it back to the dealer...
Old July 29th, 2012, 08:27 AM   #5
XPWEEZ22's Avatar
First Name: Jack
My RZR: 900XP
Member #41159
yes it is still under warranty ill let them deal with it thanks for the help.
Old July 29th, 2012, 08:36 AM   #6
swingarm1's Avatar
First Name: Tim
Member #7690
If you wrench on it they can say you broke it... The master cylinder isn't a cheap part if it's bad...
Old July 29th, 2012, 01:27 PM   #7
PanamaRzR's Avatar
Member #40200
View PanamaRzR's Photo Gallery(0)
Have the same problem here. The dealer will change the switch/ sensor under guaranty. Less than 25 hours on this baby....
PanamaRzR is offline   Reply With Quote
Old September 11th, 2013, 08:41 AM   #8
Xpred558's Avatar
First Name: Lee
My RZR: 2013 Walker Evans Xp 900
Member #8023
View Xpred558's Photo Gallery(0)
Having same issue with my dads jagged. We are in the dilemma of cost of part vs cost of fuel to get to dealership or should I say a dealership and mechanic I trust to work on are stuff.
Xpred558 is offline   Reply With Quote
2012 polaris ranger 800xp brake switch
2012 polaris rzr xp 900 brake switch location
2014 rzr 900 xp brake switch
brake pressure switch on polaris 1000
how to fix brake sensor on rzr 900
polaris ranger brake pressure switch
polaris ranger brake switch
polaris rzr brake pressure switch
pure polaris 2012 polaris rzr xp 900 brake pressure sensor for sale
rzr 900 brake pressure switch
rzr 900 brake sensor
rzr 900 brake switch
rzr pressure switch
where is brake sensor rzr 900xp
Disabling the Foot Brake Start Switch Overlord Engine and Drivetrain 29 January 11th, 2015 10:00 PM
Brake Switch rorhound Lighting, Stereo and Electrical 4 June 24th, 2014 12:15 AM
Brake pressure switch rorhound General RZR Discussion 7 December 5th, 2013 07:09 PM
need help '11 rzr pressure brake harness disconnected ?????? Phillybull55 General RZR Discussion 4 February 19th, 2012 06:41 PM
Need: 4 wheel drive switch and headlight switch for pre 2011 RZR RZR4Crew Want to Buy 4 January 25th, 2011 11:07 PM
