I have been having some trouble trying to start my 2012 900XP, within the last few times I've had it out it seems like it's getting harder to start, you pretty much have to stand on the brake peddle to get it to start it has never done this before. i have checked the brake reservoir and it is full, I've been reading some forums about the brake pressure switch but a lot of them say "when they go they go"... but i can still get mine to start but like i said you have to pretty much stand on the brake peddle to get it to turn over. anyone have any suggestions thanks guys.
Bleed the brakes as you could have air in the lines... Start bleeding the brakes at the right rear (furthest point from master cylinder), then the left rear, then the right front and finally the left front...
ok ill try that thanks..do these 900 tend to do such a thing? one other thing i forgot to mention is on the top of the reservoir where the cap is it is wet around it, its on tight but it has done this a few times gets wet then dry and wet again?????
Having same issue with my dads jagged. We are in the dilemma of cost of part vs cost of fuel to get to dealership or should I say a dealership and mechanic I trust to work on are stuff.
Related Threads
3.1M posts
141.7K members
Since 2007
