Xp is squeaking! - Polaris RZR Forum - RZR Forums.net
Xp is squeaking!
This is a discussion on Xp is squeaking! within the RZR XP 900 forums, part of the General RZR category; Anyone else have problems with their xp squeaking? i assume its the bushings but i may be wrong. only ridden in the woods once. i ...
Old July 19th, 2012, 08:17 PM   #1
swamp donkey
padge's Avatar
First Name: Adam
My RZR: rzr s
Member #41132
View padge's Photo Gallery(0)
Xp is squeaking!
Anyone else have problems with their xp squeaking? i assume its the bushings but i may be wrong. only ridden in the woods once. i got some wd and sprayed on them today hopefully that helps.
anyone else have this issue??
padge is offline   Reply With Quote
Old July 19th, 2012, 08:21 PM   #2
Jadan26's Avatar
My RZR: rzr xp le 900
Member #24158
View Jadan26's Photo Gallery(0)
Its the ends of your shocks where bolts go through. They are dry. Search the forum it has been discussed. Need to be taken apart and lubed a little.
Sent from my SGH-T989 using Tapatalk 2
Popo lnr box, half windshield, roof.. TS revolver seats.. Futv skid, sliders, a arm guards.. 26 sand blasters and smoothies.. Dfr harnesses.. Tribalwhips lighted whip and 30" led bar.. Ez steer PS.. Highlifter radius rods.. Utv inc gussets, trailing arm sliders, heat shield, billet mirror, snatches, seat lowering bases... Emp modified parking brake.. Pro armor doors and graphics..Dg cage..Pep utv shocks..holz motor mounts..
Jadan26 is offline   Reply With Quote
Old July 19th, 2012, 08:30 PM   #3
I just wanna ride
RZR Jeff's Avatar
First Name: Jeff
My RZR: S
Member #2344
View RZR Jeff's Photo Gallery(4)
Re: Xp is squeaking!
I don't know how to link to it from my I pad but go to the RZR S section and go back about 3 pages you will find fox podium shock maintance. I think it will help
09 RZR S, Pro Armor doors, DJ Safety 5 point harness, dual 4' Tribal Whips NightStalker Whips, UMP intake, My custom K&N pre-filter, Gibson exhaust, Po Po plastic roof, EMP spare tire mount, Burke 35 Watt HID's, My custom Bling Bling LED's inside the headlights. AFCO Silver Series Shocks, Makin' Trax Progressive Rate Springs,
RZR Jeff is offline   Reply With Quote
Old July 19th, 2012, 09:16 PM   #4
I just wanna ride
RZR Jeff's Avatar
First Name: Jeff
My RZR: S
Member #2344
OK I'm on my pc now so I can give you a link to a thread I started a while ago. The first post is the fix, the last few posts are from XP owners saying they are having trouble starting as early as 10 miles on a new machine. Click Me
Good Luck
Old July 19th, 2012, 10:46 PM   #5
krawnic's Avatar
Member #41659
View krawnic's Photo Gallery(0)
Thanks for the info guys!
krawnic is offline   Reply With Quote
Old July 19th, 2012, 11:16 PM   #6
...Sand Addict...
RideRed1's Avatar
First Name: Tyson
My RZR: '12 XP LE Liquid Silver
Member #41480
View RideRed1's Photo Gallery(0)
What he says^. My '12 XP was squeaking about 80 miles, tore the shocks off at 120ish and most heims were dry as a bone. It's a great write up.
RideRed1 is offline   Reply With Quote
Old July 20th, 2012, 07:36 AM   #7
BeezRZR9's Avatar
First Name: Brian
My RZR: 2016 RZR XPT
Member #40649
View BeezRZR9's Photo Gallery(0)
Same here, new XP and after a couple of rides/washes my XP "Creaks" when you stand beside the machine and grab the roll bar and push back and forth. My question is pulling the shocks off a big job? Did this take care of the creaking/squeaking?
2016 RZR XPT Orange - Rebel Style Kustom's Build: Low Profile Cage, Doors, Roof, Glass Windshield/Lex R., Front Bull Bumper, Rear integrated Bumper, custom powder coating/decals, Rokblokz ME Flares, ORB Hi-Clearance A-Arms, Pawltector, 15" HD5 wheels w/Blackwater 30X10X15 tires, 3p Clutch Shims, Hi-Lifter Radius Rods
SOLD 2012 RZR 900XP
BeezRZR9 is offline   Reply With Quote
Old July 20th, 2012, 07:59 AM   #8
sallee's Avatar
Member #40808
View sallee's Photo Gallery(0)
My xp4 900 was creaking badly. I loosend the front shock bolts about 1/4 to 1/2 turn as posted on earlier thread. No more sqeek.
sallee is offline   Reply With Quote
Old July 20th, 2012, 09:32 AM   #9
Barber's Avatar
First Name: Barber
My RZR: 2012 RZR 900 XP
Member #41495
View Barber's Photo Gallery(0)
I actually just came in from doing it.. Takes about 15 minutes a side..
1.. jack up one side until the tire daylights..
2.. take the nuts off the bolts on the top and bottom of the shock.. takes a 15mm.. (one will have a washer on the nut side) I think it's the bottom..
3.. grab the wheel and lift up to relieve presure and take the bottom bolt out.. then just slide the top bolt out and take the shock to your work bench.. or sit down and do it in the dirt, I don't care
4.. there is a metal sleeve in either side. pull those out then use your finger nail and pry the rubber O-ring out.
5.. use your fingers, or if your a girl, use a something for leverage and break the ball loose.. (It's a ball in socket joint).. then oil the hell out of it.. I used kroil oil but only because I didn't have any White lithium grease...
6.. work the oil/ or greese in until the ball moves freely... then lightly greese the rubber O-rings and push them back in.. then pop the metal sleaves back in and go put it back together....
7.. do other side...
Like I said.. takes about 15 minutes a side first time you do it...
Barber is offline   Reply With Quote
Old July 20th, 2012, 09:39 AM   #10
Barber's Avatar
First Name: Barber
Member #41495
Or you can just click the "click me" link above and see pictures.. although my front shocks are set up like his rear shocks..
12 800 polaris ranger roll cage squeaks
2012 rzr 900 front schock bushings
how to get the rear coilover shocks to stop squeaking on rzr xp 900
how+to+fix+squeaky+shocks+on polaris 6x6 utv
polaris 900 rzr squeak
polaris ranger box squeak fix
polaris ranger roll cage creaking
polaris ranger xp 900 roll cage creaking
rzr 900 shock squeak
rzr xp 900 bushings
rzr xp squeak
skreaking in polaris ranger when you turn
squeak rzr 900 xp
squeaking rzr 900 s
why does my 2014 polaris 900 ranger squeak
shocks squeaking bigcountry RZR 4 Specific Discussion 4 April 15th, 2012 09:39 AM
Squeaking Noises wadenq General RZR Discussion 8 September 3rd, 2010 10:43 PM
Shocks squeaking?? ces43 RZR-S Specific Discussion 2 December 1st, 2009 11:30 PM
Shocks squeaking?? ces43 Suspension 1 December 1st, 2009 08:21 PM
rzr suspension squeaking? bmcqueen RZR-S Specific Discussion 7 February 3rd, 2009 03:44 PM
