Bad Starter!! - Polaris RZR Forum - RZR Forums.net
post #1 of 15 Old April 30th, 2012, 08:01 PM Thread Starter
Ryguy745's Avatar
My RZR: rzr xp 4 1000
Member #34855
View Ryguy745's Photo Gallery(0)
Bad Starter!!
Has anyone had a starter go out ???
Ryguy745 is offline
post #2 of 15 Old April 30th, 2012, 08:44 PM
DWRAT's Avatar
First Name: Dan
My RZR: 2014 RZR-XP1000
Member #5778
View DWRAT's Photo Gallery(0)
Re: Bad Starter!!
Yes, several people so far have posted about a bad starter.
2005 Rhino 660---Sold
2008 Rhino 700---Sold
2009 RZR-S------- Sold
2011 RZR-XP9-----Sold
2014 RZR-XP1K---Sold
2011 Rhino 700
2016 RZR-XPT----Sold that POS
DWRAT is offline
post #3 of 15 Old May 1st, 2012, 12:37 PM Thread Starter
Ryguy745's Avatar
Member #34855
Re: Bad Starter!!
Thanks that's good to know cuz my dealer says that they have never had that problem. So they won't do anything about it.
Ryguy745 is offline
post #4 of 15 Old May 1st, 2012, 04:13 PM
DWRAT's Avatar
First Name: Dan
Member #5778
Re: Bad Starter!!
Is it still under warranty???
2011 Rhino 700
DWRAT is offline
post #5 of 15 Old May 1st, 2012, 04:22 PM Thread Starter
Ryguy745's Avatar
Member #34855
Re: Bad Starter!!
That would be a negative !!
Ryguy745 is offline
post #6 of 15 Old May 2nd, 2012, 04:55 PM
DWRAT's Avatar
First Name: Dan
Member #5778
Re: Bad Starter!!
If it out of warranty why should they do anything about it.
I'm sure if you are willing to pay, the dealer would be willing to replace.
2011 Rhino 700
DWRAT is offline
post #7 of 15 Old May 2nd, 2012, 08:03 PM
Rowdy9's Avatar
First Name: Jason
My RZR: 2012 RZR4
Member #12258
View Rowdy9's Photo Gallery(0)
Re: Bad Starter!!
Polaris know that they have a problem, I would make a call to them. A buddy has had two replaced in his 900 with less than 100 miles on his, the 2nd one blew all apart and the shop is almost done putting the new motor in it. When the shop pulled the oil pan, it had many pieces all in it 20-30 pieces.
Rowdy9 is offline
post #8 of 15 Old May 2nd, 2012, 09:36 PM
RzrRash's Avatar
First Name: Daron
Member #6775
View RzrRash's Photo Gallery(6)
Re: Bad Starter!!
One guy in our group had about 500m on his xp. We stopped for a break and his didn't restart. Starter was completely fried. We even tryed jumping the starter direct and it didn't budge. Dealer replaced the started and the solenoid. Thanks to this awesome forum, I'd just read the week before how to pull start an xp because the same thing happened to him.
Launch. Land. Repeat.
Highly recommended: HiPer Racing Wheels / Quick Light / PEP Shocks / ALBA Racing
RzrRash is offline
post #9 of 15 Old May 2nd, 2012, 10:18 PM
Fimea's Avatar
First Name: Rick
My RZR: 2015 XP1000, 2011 XP900
Member #29192
View Fimea's Photo Gallery(0)
Re: Bad Starter!!
4013059 Starter 2011 XP900
4013245 Starter 2012 XP900 (there's a reason for the new part number).
It's my understanding that 2011 XPs had problems with the motor magnets coming unglued from the housing. I believe the replacement starters were backordered for a few weeks?
They also had the starter gear backing off, and engaging to the already running motor!
Search the forum, there's lots of comments on threads. I believe one is under "Report XP900 problems here"...
Good luck.
Fimea is offline
post #10 of 15 Old May 3rd, 2012, 06:28 AM
carla324's Avatar
First Name: gene & carla
My RZR: 2014 rzr xp 1000
Member #23538
View carla324's Photo Gallery(0)
Re: Bad Starter!!
I had a starter burn up on my xp at the koa north glamis ride,from what I have been able to find out is there are two reasons for this to happen on the xp...the most common is the solenoid stays closed when you start it making the starter stay engaged and spinning at motor speed,trust me that will burn up the starter real quick (if you look at how small that solenoid is you can understand why it can fail)the second reason is the starter idle gear backing out of the case and riding on the flywheel keeping the starter engaged,same result as above...mine was the solenoid
carla324 is offline
post #11 of 15 Old May 3rd, 2012, 06:34 AM
swingarm1's Avatar
First Name: Tim
Member #7690
Feedback Score: 176 reviews
Re: Bad Starter!!
Yes, on his first dune trip a friend of mine had his starter go south...
swingarm1 is offline
post #12 of 15 Old May 3rd, 2012, 06:37 AM
Contact: 855-743-3427
Super ATV's Avatar
First Name: SuperATV
Member #7943
View Super ATV's Photo Gallery(0)
Re: Bad Starter!!
Yes have heard of many going bad.
SuperATV Official Website
10% Forum Member Discount Up to $400.00.
Just enter RZRFORUM code at checkout! No multiple forum coupon codes accepted.
Super ATV is offline
post #13 of 15 Old November 7th, 2012, 07:33 PM
poflo's Avatar
First Name: Don
My RZR: xp 900
Member #11987
View poflo's Photo Gallery(0)
Re: Bad Starter!!
OLD THREAD......But , Ive seen 4- 2011 xp 900 starters lock up & destroy the magnets inside.....two broke the cases where the pilot gear shaft screws into the case.......Note new part # and says new design on the box........but no recall or replacement.....$ 300.00 out of your pocket
poflo is offline
post #14 of 15 Old June 15th, 2013, 03:51 PM
jdtech65's Avatar
First Name: Terry
My RZR: 2013 900 XP Walker Evans
Member #52222
View jdtech65's Photo Gallery(0)
Re: Bad Starter!!
My starter stays engaged on my 13 walker evans 900 xp. When I went to shut it off it would keep cranking the engine over. Turn the key back on and it fires up. I tried a couple times and every time I turned the key off it kept trying to start the machine yet. My Fluke meter is at work and the dealer is closed for the weekend. I'm guessing right now that the starter solenoid is stuck closed. Am I thinking right or can there be other things that could cause the starter to stay cranking with the key off? I had to unhook the battery to get it to shut off.
2013 Polaris 900 XP Walker Evans
jdtech65 is offline
post #15 of 15 Old June 16th, 2013, 08:05 AM
GrMeyer's Avatar
First Name: Greg
My RZR: 900 Xp
Member #15161
View GrMeyer's Photo Gallery(0)
Re: Bad Starter!!
I thought I had a starter go out but ended up being a bad relay. For the rest of my dune trip I just used a jumper wire to engage the starter. This is after using a Tester to even see if I was getting power to the starter. Changed out the relay and its good as new. FYI the starter is not and easy fix. I had to change out the two o-rings on the nose of the starter due to leaking oil.
GrMeyer is offline
170 starter help!!! uphillbothways RZR 170 Specific Disccusion 21 June 20th, 2014 08:56 AM
Starter shanek62 RZR-S Specific Discussion 5 March 1st, 2012 06:47 PM
RZR Starter HivoltageRZR Polaris RZR Parts For Sale 2 February 21st, 2011 09:54 PM
08 Starter HivoltageRZR Polaris RZR Parts For Sale 0 November 8th, 2010 09:06 PM
Starter HivoltageRZR Want to Buy 0 August 23rd, 2010 09:02 PM
