Power Steering? - Polaris RZR Forum - RZR Forums.net
Power Steering?
This is a discussion on Power Steering? within the RZR XP 900 forums, part of the General RZR category; Iíve been thinking about adding power steering to my 2012 900XP. I see these kits from $500 to $1200. Whatís the difference in all of ...
Old April 21st, 2012, 11:26 PM   #1
o4hrly88's Avatar
First Name: Ryan
My RZR: 2012 900XP
Member #37230
View o4hrly88's Photo Gallery(0)
Power Steering?
Iíve been thinking about adding power steering to my 2012 900XP. I see these kits from $500 to $1200. Whatís the difference in all of these kits? I've heard the Polaris OEM has variable assist that is based on speed. Do they all work like this? What system do you have and what are your thoughts on it? Thank you
o4hrly88 is offline   Reply With Quote
Old April 21st, 2012, 11:38 PM   #2
darterdad's Avatar
First Name: Claud RZR forum Rocks
My RZR: 2012 900XP LE The White One
Member #33002
View darterdad's Photo Gallery(0)
Re: Power Steering?
I have EZ steer and it's great!!SATV
DC IMPORT SERVICE SINCE 1984
YOUR HONDA SPECIALIST
darterdad is offline   Reply With Quote
Old April 21st, 2012, 11:41 PM   #3
scottr's Avatar
My RZR: 2014 XP 1000, 2016 Turbo
Member #16156
View scottr's Photo Gallery(4)
Re: Power Steering?
X2 works great.
scottr is online now   Reply With Quote
Old April 22nd, 2012, 12:37 AM   #4
Cuzin Eddie's Avatar
First Name: Shane
Member #6393
View Cuzin Eddie's Photo Gallery(8)
Re: Power Steering?
Had the Polaris PS added to my XP4 and LOVE IT!!!!!!
Seven Oaks Fine Jewelers
"It's okay to throw our ROCKS at GIRLS"
Vernal, UT.
(435) 901-3307
12' XP 4 (Mine)
09' RZR S (Hers):rzrs:
09' Teryx (sold the Junker)
Cuzin Eddie is offline   Reply With Quote
Old April 22nd, 2012, 01:19 AM   #5
yamaha1's Avatar
First Name: jj
My RZR: 11' Benchmark XP9
Member #8544
View yamaha1's Photo Gallery(0)
Re: Power Steering?
X2 works great.
X3
www.utvinc.com/utvinclogo.png
11' Benchmark Performance XP9
12' T4
yamaha1 is offline   Reply With Quote
Old April 22nd, 2012, 01:29 AM   #6
SouthernGypsy's Avatar
My RZR: XP900
Member #30833
View SouthernGypsy's Photo Gallery(0)
Re: Power Steering?
I did a LOT of research of all the available brands (like 6 of them total) and ended up spending the extra for the Pure Polaris kit made for my 2012 XP900 and am very glad I did. I have now got to drive a couple of machines with aftermarket kits and they don't compare to the factory Polaris kit. Plus the fact that since it's genuine Polaris it's also coverd by my Polaris extended warranty on my machine. I was able to pick mine up at my dealer for less than $1000 out the door. The MSRP on these kits is a big mark up over what dealers actually pay so if you look around/check with different dealers you can find ones who will sell them much cheaper than the book price. The factory kit plugs into your factory harness, no cutting or splicing, and adjust itself baised on several inputs from your XP's computer, not just speed sensitive but I was told also reads RPM's, if it's in 4x4 or 2x4, and if engine braking is currently active and makes minor changes to sensitivity baised on a software map taking all of those factors into consideration. It also works with the factory EPS warning light and trouble codes on your dash in the event there is ever trouble. Like if your battery voltage drops below a certain level the factory kit will shut itself off until the battery voltage is back to normal to prevent further battery drain by the EPS unit. Something that could potentially keep the machine running long enough to get you back to camp in the event your charging system ever went out, it still steers fine if it's disactivated, just feels like before you added power steering. A few of the aftermarket ones said you could "tap-in" to the speed sensor wire so it adjust somewhat baised on speed but didn't do any of those other things and wont be coverd by your Polaris warranty or extended warranty because they are aftermarket. Besides that, the two I drove, I could just "feel" the difference compared to the ones with the factory kits that I have driven and I liked the factory units feel better across all speeds and conditions. The factory kit does cost noticably more, $1000 compared to $600 so an increase of $400 but to me the difference was worth it over the life of the machine and to know my 5 year extended Polaris warranty would cover it just like any other factory part on the machine. Took me about two hours to install it myself BTW with the instructions so didn't have to spend money to have it installed by the dealer, it was fairly easy. After doing my own first I've since helped friends do theirs and only just over an hour each time for those once I knew how do it, so it's not hard, just be sure to read your instructions TWICE before even starting, then refer to them each step as you go also. They arn't even long so reading them twice only takes like 5 minutes and it's good to have an overview of the whole procedure before you even start at all.
SouthernGypsy ~ Sandtown Offroad Ranch
2012 RZR XP900 EPS SxS / 2011 XP850 EPS ATV
Visit us on Facebook:
www.facebook.com/SandtownRanch
Watch our ride videos:
www.youtube.com/SouthernGypsy
SouthernGypsy is offline   Reply With Quote
Old April 22nd, 2012, 05:02 AM   #7
jbsharley's Avatar
Member #13768
View jbsharley's Photo Gallery(0)
Re: Power Steering?
I bought my 2011 -- 50inch 800 with Polaris EPS. I would not give it up.
jbsharley is offline   Reply With Quote
Old April 22nd, 2012, 07:50 AM   #8
JD6
JD6's Avatar
First Name: JD
My RZR: 12 900XP Blk/Orange Maddness
Member #35374
View JD6's Photo Gallery(0)
Re: Power Steering?
How does it handle at 70-80 mph with power steering? I have heard it make it real twichy. Id like to have it but i do alot of high speed riding down field paths and such.
JD6 is offline   Reply With Quote
Old April 22nd, 2012, 07:55 AM   #9
Feedback Score: 176 reviews
swingarm1's Avatar
First Name: Tim
Member #7690
Re: Power Steering?
The Polaris OEM P/S works fine at speed...
Old April 22nd, 2012, 08:03 AM   #10
JD6
JD6's Avatar
First Name: JD
Member #35374
Re: Power Steering?
So i take it the ez steer isnt as good at high speeds?
Old April 22nd, 2012, 08:06 AM   #11
swingarm1's Avatar
First Name: Tim
Member #7690
Re: Power Steering?
I didn't say that... I sell the OEM P/S Kit and I know how it reacts and the feedback from those that have bought one from me...
Read my thread on OEM P/S Kit 4 sale...
Old April 22nd, 2012, 09:44 AM   #12
MOHLSON's Avatar
My RZR: XP900
Member #28860
View MOHLSON's Photo Gallery(0)
Re: Power Steering?
I love my ez-steer but I will admit, its a little loose at 70. I just steers so easily. I really like it mostly for taking away the bump-steer. When I buy a new rzr I will just get the factory ps but this works great as an add on unit.
MOHLSON is offline   Reply With Quote
Old April 22nd, 2012, 09:58 AM   #13
HIGHOCTANE's Avatar
Member #16360
Re: Power Steering?
They all will take a little getting used to at speed, I have used the Unisteer and the Polaris EPS..the Polaris speed sensative feature does help at speed..but again take a little time to get used to it before you go high speeds where there is no room for error..heck that goes for no EPS too...at top speed on these things in an offroad enviroment, even a wide open field, bad things can happen fast.
HIGHOCTANE is offline   Reply With Quote
Old April 22nd, 2012, 10:03 AM   #14
Dustinv7's Avatar
First Name: Dustin
Member #38004
View Dustinv7's Photo Gallery(0)
Re: Power Steering?
i have a 2012 xp and have the pure polaris eps in it and i have nothing to complain about besides the price (1495.00 + 1450 for instillation here in canada)
Dustinv7 is offline   Reply With Quote
Old April 22nd, 2012, 10:05 AM   #15
HIGHOCTANE's Avatar
Member #16360
Re: Power Steering?
1450 for install??? Wow..it literally takes a couple hours taking your time.
do all 2014 polaris rzr s 800 have power steering
does a rzr s have power steering
does all polaris rzr have power steering
how many volts do u need for.power steering to.work on a rzr 900s esp
polaris rzr 800 power steering
polaris rzr 900 s power steering
polaris rzr power steering
polaris rzr power steering kit
power steering
power steering for polaris rzr
power steering manual installation kits an vidios for 2008 polaris 800 rzr
rzr power steering or not
rzr s power steering
used polaris oem power steering
what year did polaris razor 170 have power steering
xp power steering blumaro RZR XP 900 0 December 28th, 2011 07:30 PM
Steering is developing some play (power steering) motoadve General RZR Discussion 15 September 26th, 2011 10:24 AM
'11 LE Power steering drzr General RZR Discussion 0 August 22nd, 2011 05:52 PM
Power Steering hancop General RZR Discussion 5 March 25th, 2011 10:07 AM
power steering anybody jeepjunkie General RZR Discussion 0 February 17th, 2009 05:41 PM
