Suggestions on removing dash stickers - Polaris RZR Forum - RZR Forums.net
This is a discussion on Suggestions on removing dash stickers within the RZR XP 900 forums, part of the General RZR category; I was looking to clean up my dash a little and i was wondering if anyone has an easy way of getting these pain in ...
Old March 3rd, 2012, 06:18 PM   #1
JD6's Avatar
First Name: JD
My RZR: 12 900XP Blk/Orange Maddness
Member #35374
View JD6's Photo Gallery(0)
I was looking to clean up my dash a little and i was wondering if anyone has an easy way of getting these pain in the ass stickers off and what will take the glue left behind off? I tried rubbing alcohol on a spot and it did nothing. Any help would be greatly appreciated
JD6 is offline   Reply With Quote
Old March 3rd, 2012, 06:25 PM   #2
scottr's Avatar
My RZR: 2014 XP 1000, 2016 Turbo
Member #16156
View scottr's Photo Gallery(4)
Re: Suggestions on removing dash stickers
I used a hair dryer and goo gone.
scottr is offline   Reply With Quote
Old March 3rd, 2012, 06:26 PM   #3
bubbys toy's Avatar
First Name: Arlie
My RZR: 2013 xp 900
Member #22654
View bubbys toy's Photo Gallery(5)
i used paint thinner, or you can use heat gun
bubbys toy is offline   Reply With Quote
Old March 3rd, 2012, 06:29 PM   #4
darterdad's Avatar
First Name: Claud RZR forum Rocks
My RZR: 2012 900XP LE The White One
Member #33002
View darterdad's Photo Gallery(0)
CA Re: Suggestions on removing dash stickers
That's what I'm doing Sunday,we have a heat gun at our shop I'm going to try.
Good luck with yours.
DC IMPORT SERVICE SINCE 1984
YOUR HONDA SPECIALIST
darterdad is offline   Reply With Quote
Old March 3rd, 2012, 06:31 PM   #5
jwiebers's Avatar
Member #25476
View jwiebers's Photo Gallery(0)
I used a heat gun and 3m general adhesive remover
2012 RZR XP 900 DGRhinos Radius Cage, UTV Inc. Doors, Dragon Fire harnesses, Rugged Radio 660 Intercom and Radio kit, Doonz Paddles and Moose Racing Rims.....SOLD
jwiebers is offline   Reply With Quote
Old March 3rd, 2012, 06:33 PM   #6
JD6's Avatar
First Name: JD
Member #35374
Thanks guys. Didnt even think about a heat gun. Ill have to go try that.
Old March 3rd, 2012, 06:33 PM   #7
darterdad's Avatar
Member #33002
That looks great!
Old March 3rd, 2012, 06:47 PM   #8
tugriveroutlaw's Avatar
My RZR: 900
Member #30451
View tugriveroutlaw's Photo Gallery(41)
you can also use naptha if you don't have goo gone.
for whatever reasons, i find myself removing decal residue quite often, best process i've learned is too remove decal with heat gun or freeze spray. either way will probably leave tacky residue. then take 1 ply toliet paper and stick on the residue and drop on goo gone or naptha. the paper allows it to dissolve the gum without drying out to fast. then take plastic razor blades and scrape off. you can buy lifetime supply of plastic razor blades on the net for cheap and always come in use, won't scratch delicate shiny plastics.
tugriveroutlaw is offline   Reply With Quote
Old March 3rd, 2012, 06:52 PM   #9
ncode-one's Avatar
Member #33653
View ncode-one's Photo Gallery(0)
and you really need patience !
ncode-one is offline   Reply With Quote
Old March 3rd, 2012, 06:57 PM   #10
rc2125's Avatar
My RZR: 2012 XP
Member #20422
View rc2125's Photo Gallery(0)
Removed the stickers on two rzr's now, the second time was easier and quicker than the first. It seems like Polaris has engineered the most hard to remove, pia decals of all time. I used a hair dryer, medium heat, ya kinda gotta find the magic amount of heat and exposure time to the heat to "keep the peel" going. Goo-gone to remove the residue. Good luck!
rc2125 is offline   Reply With Quote
Old March 3rd, 2012, 07:12 PM   #11
DYNO6's Avatar
Member #19538
View DYNO6's Photo Gallery(0)
Keep in mind when removing these type of things that sometimes pulling at a different angle will help. Sometimes it's 90 degrees, sometimes you need to pull at a greater angle. Believe it or not it can make a huge difference in how well the adhesive comes off. Also be careful with a heat gun on painted plastic! A hair dryer is also an option.
DYNO6 is offline   Reply With Quote
Old March 3rd, 2012, 07:13 PM   #12
Sr10's Avatar
My RZR: 2010 stealth le
Member #19632
View Sr10's Photo Gallery(0)
PRESSURE WASHER!!!!! Best way bar none!!! No residue either! Use a fan tip
Sr10 is offline   Reply With Quote
Old March 3rd, 2012, 07:14 PM   #13
rzrider50's Avatar
First Name: James
My RZR: 2011 rzrs sunset red
Member #36564
View rzrider50's Photo Gallery(6)
heat gun and wd 40 will get the glue off
rzrider50 is offline   Reply With Quote
Old March 3rd, 2012, 07:50 PM   #14
turboedsupe's Avatar
Member #22257
View turboedsupe's Photo Gallery(0)
A heat gun on plastics is a overkill just use a hair dryer and peel them off then use goo gone its that simple. People need to realize there are retards out there and shouldn't recommend heat guns or harsh chemicals
turboedsupe is offline   Reply With Quote
Old March 3rd, 2012, 08:11 PM   #15
tomz1sttoy's Avatar
First Name: Tom
My RZR: XP White Lightning
Member #35801
View tomz1sttoy's Photo Gallery(0)
ROTFLMAO!!! I thought a heat gun was excessive
tomz1sttoy is offline   Reply With Quote
900xp dash stickers
easiest way to remove decals from rzr 1000
how to remove decals from rzr
how to remove stickers on rzr
polaris sticker & decals
remove rzr decals
removing factory stickers
removing rzr stickers
removing sticker glue from rzr plastic
removing stickers
removing stickers from rzr
rzr dash sticker
rzr decal removal
rzr sticker removal
will a heat gun work on removing paint off of dash
Any suggestions on how to get these WARNING stickers off the dash??? RZRstealth General RZR Discussion 21 January 12th, 2012 08:16 AM
Removing those pesky safety stickers Progressiverain General RZR Discussion 5 May 8th, 2011 07:40 AM
Removing WARNING decals on LE dash REALRODDER RZR XP 900 25 April 6th, 2011 06:18 PM
Removing warning stickers? Parker22 General RZR Discussion 7 June 10th, 2010 09:41 AM
Dash Safety Stickers RZR on the ROCK Northwest U.S. / Canada 11 September 20th, 2009 08:28 AM
