plow mount...revisited - Page 6 - Polaris RZR Forum - RZR Forums.net
post #76 of 183 Old November 30th, 2011, 10:01 AM
XSSSIVE's Avatar
My RZR: 2011 RZR XP 900
Member #4071
View XSSSIVE's Photo Gallery(0)
Re: plow mount...revisited
I purchased the Motoalliance plow for my RZR XP. I have it assembled and ready to go. Sadly, we haven't had any snow to try it.
From what I can see, the Motoalliance plow is very well built. It also appears that the mount is clean and simple to mount to the machine. I'm sure this plow will work well.
2011 Polaris RZR XP 900
2013 Ski Doo Summit 800 154
2012 Polaris Pro-RMK 800 163
2012 KTM 500 XC-W
2013 KTM 350 XC-F
XSSSIVE is offline
post #77 of 183 Old December 1st, 2011, 07:15 AM
AKRZRNUT's Avatar
My RZR: 900xp
Member #32852
View AKRZRNUT's Photo Gallery(0)
I think I am going to go with the KFI mount and 72" plow. Problem is it's 1100 with shipping up here to Alaska
AKRZRNUT is offline
post #78 of 183 Old December 2nd, 2011, 08:28 AM
twist-a-grip's Avatar
Member #33085
View twist-a-grip's Photo Gallery(0)
I haven't even bought an XP 900 yet, but if I do, a plow is a must. It appears there are only a few options out there, but with significantly different mounting points. What is the general opinion on the front end mounted Motoalliance vs the underbelly mounted KFI? I am interested in using the XP for moderate snow removal on my property, but mainly for sport. I want a system that, more than anything, will be the safest for the machine.
twist-a-grip is offline
post #79 of 183 Old December 2nd, 2011, 08:45 AM
asf1779's Avatar
My RZR: 800 RZR '11
Member #5928
View asf1779's Photo Gallery(4)
I have the motoalliance mount and it blows the competition away. Granted mine is on a 50" so I dont know if it fits the xp, but the fact that you dont drill any holes and it mounts in minutes. Comparison of the eagle and the motoalliance.
ID:	40421   Click image for larger version
asf1779 is offline
post #80 of 183 Old December 2nd, 2011, 10:42 AM
AKRZRNUT's Avatar
My RZR: 900xp
Member #32852
KFI now has a mount that mounts in the front and does not require any drilling. I spoke to them yesterday and they reassured me that the best place to mount is on the front. basically just like all the other old RZR mounts. They just finally made a bracket that fits the new XP front end style.
AKRZRNUT is offline
post #81 of 183 Old December 2nd, 2011, 12:27 PM
Walt54321's Avatar
Member #31794
View Walt54321's Photo Gallery(0)
I have a motoalliance setup and I would like to see how hard it would be to weld the kfi center mount to the moto front mount to spread the force on the frame out. As far as the plow end of it though I'm really impressed with the motoalliance quality.
Walt54321 is offline
post #82 of 183 Old December 3rd, 2011, 06:37 AM
AKRZRNUT's Avatar
My RZR: 900xp
Member #32852
Why buy a mount and try to rig it together!? If you want a plate up underneith the attach to the frame and your front mount, just get whatever thickness of steel you want to use make a cardboard template under your machine that buts up to the front mount and extends out to the points on the fram where you can attach U bolts take your template and cut the steel plate to that shape and drill the holes in the right locations on the plate for the U bolts. Then take your fronmount off and weld or have your friend that can do it, weld the two together. When cool to the touch re mount front mount with new under frame reinforcment plate.
AKRZRNUT is offline
post #83 of 183 Old December 3rd, 2011, 08:14 AM
tgolliver's Avatar
My RZR: 2011 900 XP White Lightning
Member #28191
View tgolliver's Photo Gallery(0)
Thus far my KFI setup works like a champ.
We had about 6" Thursday and I probably have about that much more right now. No big storms thus far but what I have had it works just as good as any other plow I've had.
I'm honestly not sure how to say one brand is better than another, all I know is my KFI does what I bought it for and it's a ton of fun.
Two other things that I have that I would suggest.
I bought the Polaris winch mount that is on the shift handle. That is absolutely awesome for plowing because you don't have to move your hand if your going back and forth front forward to reverse.
Second is EPS, I know it's not required but it sure is nice with that extra weight on the front end.
Happy plowing guys
tgolliver is offline
post #84 of 183 Old December 3rd, 2011, 03:20 PM
Jack Ramsey's Avatar
Member #23616
View Jack Ramsey's Photo Gallery(0)
My dealer put a quadovator on my machine but says he has to take the rear bumper off because the trailer hitch (needed for the hitch to mount properly) won't go on with the bumper. What the hell?
Jack Ramsey is offline
post #85 of 183 Old December 4th, 2011, 01:49 PM
mortsgne's Avatar
Member #5993
View mortsgne's Photo Gallery(0)
Originally Posted by Walt54321 View Post
No you dont have to you can use any winch mount. I went with the kfi mount because from I've read on here it seems to be the overall favorite and I am very happy with it. Overall I would buy another moto alliance plow setup but you have to be prepared to buy all new hardware than what they give you. I'm also thinking about drilling the mount out and putting some u bolts around the frame just for good measure. If anyone on here needs a list of the hardware you need for a motoalliance setup just pm me. I was able to get it all at my local ace hardware.
Hello just wondering if you could send me that list of hardware you used to setup the motoalliance. I havn't purchased one yet, but am thinking I will this up coming week. Thanks...!
mortsgne is offline
post #86 of 183 Old December 4th, 2011, 05:31 PM
Walt54321's Avatar
Member #31794
Well I,m starting to think it was just me that got the wrong hardware, because many people on here have installed the motoalliance setup without issues. I would wait to see what you get first, but I will say that with what they sent me there was no way it was going on. I don't know maybe it was hardware for a rzrs and not an xp.
post #87 of 183 Old December 4th, 2011, 05:37 PM
Walt54321's Avatar
Member #31794
And for those out there considering who to go with. After seeing my 72" blade installed I think it wouldnt plow very well with a much narrower blade. So just something to think about when your shopping around. Also for people considering the KFI setup I would also consider that they are supposedly already redesigning there mount. I will say that the KFI winch mount is the way to go though.
post #88 of 183 Old December 4th, 2011, 06:07 PM
Tiorum3's Avatar
First Name: Al
Member #10509
The larger the blade the more weight it pushes and the more strain on the mount and RZR. I mean the RZR only weighs 1000 lbs. 72 inches can collect a heck of a lot of snow. I personally believe in heavy snow a 60 inch plow can be too much. I bent the heck out of the blade and mount so I am speaking from experience. Just something to think about.
http://i265.photobucket.com/albums/ii202/Tiorum3/Allegheny%20off%20road/aor-stickerjpeg_zps3be9880e.png
see our website for more product details at: www.alleghenyoffroad.com
Tiorum3 is offline
post #89 of 183 Old December 4th, 2011, 07:26 PM
barry1me's Avatar
Member #21801
View barry1me's Photo Gallery(0)
so you bent your plow and mount on the XP?
barry1me is offline
post #90 of 183 Old December 4th, 2011, 07:33 PM
Tiorum3's Avatar
First Name: Al
Member #10509
No its on my S. The glacier 2 system. I have a friend who put the glacier 2 on his XP though. I havent seen it but he told me it works fine.
No matter what RZR its on, the physics are the same though. I just wanted to pass some experience with it along.
Tiorum3 is offline
900 xp plow mount yazzer RZR XP 900 8 November 15th, 2012 10:11 AM
Need help with plow mount popstix Want to Buy 15 January 14th, 2011 05:41 PM
OK, Anybody Know How to Mount This Huge Moose Plow Mount? Snow-Balls General RZR Discussion 4 December 21st, 2010 05:53 PM
Plow mount for RZR RZR23 General RZR Discussion 1 September 22nd, 2009 01:21 PM
Wtb plow and plow mount and winch Ballzout Want to Buy 0 August 16th, 2009 08:04 PM
