Sway Bar Poll
This is a discussion on Sway Bar Poll within the RZR XP 900 forums, part of the General RZR category; Do you run with your Sway Bar connected or Not? Witch way is better?...
RZR XP 900 The Polaris Ranger two-seat RZR XP 900 Forum on RZRForums.net.
View Poll Results: Say Bar connected or Not
Connected 91 55.15%
Not Connected 74 44.85%
Voters: 165. You may not vote on this poll
Old August 8th, 2011, 06:09 PM
tom900xp's Avatar
First Name: Tom
My RZR: 900 XP
Member #26211
View tom900xp's Photo Gallery(0)
Sway Bar Poll
Old August 8th, 2011, 06:26 PM
HIGHOCTANE's Avatar
Feedback Score: 6 reviews
Member #16360
Re: Sway Bar Poll
Depends on what you need...medium to high speed handling...connected. Low speed articulation..disconnected.
• Makin Trax Springs•Motoactiv Doors
•Triple X Bench•DFR Harnesses
•Polaris EPS•DWT Diablo Beadlocks•UTV inc Nerf Bars
•DDP clutch kit•HL Radius Rods•Rhino Axles
•Holz/UTV inc A-Arm Braces•Thunderhawk Hitch
• SSV overhead• Polaris L&R Windshield/rear panel/top
Old August 8th, 2011, 06:27 PM
dsmracing1's Avatar
First Name: Cameron
My RZR: 2011 RZR Walker Evans Edition
Member #27601
View dsmracing1's Photo Gallery(19)
Re: Sway Bar Poll
I took my sway bars off right away and cranked my springs to adjust for the body roll. Way better in my opinion for rooted, muddy, rocky ground. allows the suspension to work as it should and the wheels to drop individually. I think If I were dune riding or higher speeds I would keep em connected.
Your Not Having Fun Til Your Rolled Or Stuck!
2011 Walker Evans LE RZR
Polaris 3500 lb Winch, 28" Gorilla Silverback Tires on STI HD2 Rims, Rhino Axles, Arctic Thunder Snorkled TTT! Racer Tech 2" Lift, EMP Park Brake and Gas Tank Guard, Pro Armor Doors, Polaris Rock Sliders, FUTV A-Arm Guards, Accessorized By Polaris, SSV Marine Stereo, 20" TQS LED Light Bar,
Old August 8th, 2011, 06:32 PM
tom900xp's Avatar
First Name: Tom
My RZR: 900 XP
Member #26211
I do trail and off Camber type riding. I just don't want the body to lean over if I'm on the side of a hill. What do you think?
Sent from my ADR6350 using Tapatalk
Old August 8th, 2011, 06:39 PM
HIGHOCTANE's Avatar
Member #16360
Re: Sway Bar Poll
I think you'd be better off with it disconnected and adjusting your springs..a sway bar tries to maintain the suspension at equal extension..cross camber you want to maintain as level as possible.. ie you want the upslope compressed and the down slope extended. Best bet is to expeiment both ways and see what you are comfortable with. Just make sure you add a little pre-load with it disconnected.
I like it better disconnected for technical terrain...but I also like to haul butt..I need a quick disconnect.
Old August 8th, 2011, 06:43 PM
reevesr's Avatar
Feedback Score: 4 reviews
First Name: Ray
My RZR: 2011 RZR
Member #7920
View reevesr's Photo Gallery(0)
Re: Sway Bar Poll
Disconnected mine, for trail riding it is much better than when it was connected.
Old August 8th, 2011, 06:45 PM
dsmracing1's Avatar
First Name: Cameron
Member #27601
Re: Sway Bar Poll
X2 I couldnt have said it better myself.
  #8
Old August 8th, 2011, 07:03 PM
swingarm1's Avatar
TAGTEAM 928-273-4249
Feedback Score: 93 reviews
First Name: Tim
My RZR: XP LE PROCHARGER 10 PSI SUPERCHARGER UTVINC BUILT IRONMAN EDITION
Member #7690
AZ Re: Sway Bar Poll
Is yours a XP???
I SELL AND INSTALL THE FOLLOWING PRODUCTS...
HOLZ RACING, RACER TECH, PROCHARGER SUPER CHARGER KITS, STAR ISLAND MOTOR SPORTS (OEM PARTS), I REBUILD & SELL STOCK & MODIFIED 800 & 900 ENGINES, AZ HYDROGRAPHICS, STM CLUTCHES, UTVINC 100% AMERICAN MADE PARTS 1ST DEALER
928-273-4249
  #9
Old August 8th, 2011, 07:08 PM
dsmracing1's Avatar
First Name: Cameron
Member #27601
Re: Sway Bar Poll
Is yours a XP???
no, just a std rzr with walker evans shocks and some budget spacers so I feel a little bit like a big boy rzr 900xp.
  #10
Waszak1977's Avatar
◄►STARS & STRIPES◄►
Feedback Score: 11 reviews
First Name: ╠══MIKELANGELO══╣
My RZR: ╠═o8 FULLBORE TURBO═╣
Member #18310
View Waszak1977's Photo Gallery(1)
Re: Sway Bar Poll
On my o8 RZR(S), I guess It should be called an "S", or I can always say "+5"? anyways, I don't run the sway bars at all. However I do recommend that if you are going to remove them that decision is best accompanied with a new set of springs.
Good luck!
Built for the RacerTECHnology for the win.
616-928-0616
www.goracertech.com
www.spectrumUTV.com
www.MWRAseries.com
www.spectrumsandsports.com
Follow Racer Tech on Facebook! Bullet Proof UTV Parts!!
  #11
Old August 8th, 2011, 07:11 PM
HIGHOCTANE's Avatar
Member #16360
Re: Sway Bar Poll
Is yours a XP???
Doesn't much matter IMO the swaybar function is very similar with the a-arm set up and the 3 link. OP should try both ways to answer his question IMO.. So many variables in terrain and what people perceive as better or more comfortable in many cases...generally though sway bars aren't of use in technical terrain...they are to control centrifugal body roll.
  #12
Old August 8th, 2011, 07:28 PM
tom900xp's Avatar
First Name: Tom
My RZR: 900 XP
Member #26211
Thank you for the excellent feedback. I can tell there is a lot of experience on this forum.
  #13
Old August 9th, 2011, 05:35 AM
itsruf's Avatar
My RZR: Prospector Edition XP
Member #16159
Re: Sway Bar Poll
I want a quick release/ quick-connect version of that.
swayloc will be my name for it.
  #14
Old August 9th, 2011, 06:17 AM
FunRide's Avatar
First Name: Jim
My RZR: '11 S
Member #17399
Re: Sway Bar Poll
Yep... I need a quick disconnect too. I like it disconnected, but there sure are times I'd like the azz to stay put a bit more at high speeds. It slides better connected. Not sure how a factory RZR would behave cranked down enough (stiff I'm thinking). My progressive springs help a lot to stabilize the machine without a sway bar. Those new springs are night and day.
I bet 70% of those with disconnected sway bars have the Racer Tech springs, or Makin' springs on their machines...
  #15
Old August 9th, 2011, 06:29 AM
FunRide's Avatar
First Name: Jim
My RZR: '11 S
Member #17399
Re: Sway Bar Poll
As a reminder for those that disconnect the sway bar, don't remove the entire sway bar mounting apparatus... Just disco the actual bar from both sides and get it out of the way. Some recent stories of frame damage (cracking) from removal of that cross support piece the bar mounts to. Clearly the frame relies on that piece.
http://www.rzrforums.net/general-rzr...me-cracks.html
2011 ranger xp sway bar delete
2012 xp sway bar removal
adjust sway bar links on racer tech lift
best shocks for 2011 std razor with no sway bars
polaris 900 xp sway bar
polaris 900xp sway bar
polaris ranger stabilizer bar break
polaris ranger stabilizer keep it or loose it
polaris razor 800 sway bar disconnect
polaris razor sway bars....connect or disconnect
polaris rzr sway bar quick connect
remove sway bar add racer tech springs
removing xp900 sway bar
rzr without sway bars
rzr xp sway bar removal
rzr xp swaybar
rzr-s sway bar clevis pin
taking sway bar off rzr
where can i buy swingbar suzuki thunder
witch aftermarket clutch kit for rzr do i buy
New Poll: Which ECU do you have and do you like it? Spicoli Engine and Drivetrain 29 April 2nd, 2011 11:20 PM
**POLL Which color RZR do you have? POLL** TH3APPL3GUY General RZR Discussion 59 January 8th, 2011 01:10 PM
poll on what eng do you want ? johnnycat8 Engine and Drivetrain 47 September 15th, 2010 06:32 AM
Hubs, rear sway bar, battery + box, rear sway bar, XMF rear sway bar linkage w/heims twvette Polaris RZR Parts For Sale 5 June 30th, 2010 01:30 PM
