This is a discussion on Sway Bar Poll within the RZR XP 900 forums, part of the General RZR category; Need advise from the hardcores please......... I disconnected mine and I'm lookin at it. I wanted to look at range of motion. When disconnected the ...
| RZR XP 900 The Polaris Ranger two-seat RZR XP 900 Forum on RZRForums.net. |
| View Poll Results: Say Bar connected or Not | |||
| Connected |
91 | 55.15% |
| Not Connected |
74 | 44.85% |
| Voters: 165. You may not vote on this poll | |||
#31
Re: Sway Bar Poll
I disconnected mine and I'm lookin at it. I wanted to look at range of motion. When disconnected the shock smacks down an xtra 1.25" or so to full extension. also the boot thing and axle look unhappy. They go waaaay down. Is disconnecting that safe on the other parts? |
| Sponsored Links | ||
#32
Re: Sway Bar Poll
![]() • Makin Trax Springs•Motoactiv Doors •Triple X Bench•DFR Harnesses •Polaris EPS•DWT Diablo Beadlocks•UTV inc Nerf Bars •DDP clutch kit•HL Radius Rods•Rhino Axles •Holz/UTV inc A-Arm Braces•Thunderhawk Hitch • SSV overhead• Polaris L&R Windshield/rear panel/top Last edited by HIGHOCTANE; September 2nd, 2011 at 11:17 AM. |
#33
Re: Sway Bar Poll
Yeah you must have a problem there.. you don't have the other side supported do you? Is the other end connected and is the other trailing arm hanging? If so something must be tweaked.
Here is mine wheels off the ground left side swaybar bolt removed..still lines up perfectly. ![]()
![]() • Makin Trax Springs•Motoactiv Doors •Triple X Bench•DFR Harnesses •Polaris EPS•DWT Diablo Beadlocks•UTV inc Nerf Bars •DDP clutch kit•HL Radius Rods•Rhino Axles •Holz/UTV inc A-Arm Braces•Thunderhawk Hitch • SSV overhead• Polaris L&R Windshield/rear panel/top Last edited by HIGHOCTANE; September 2nd, 2011 at 11:37 AM. |
#35
Re: Sway Bar Poll
Took the sway bar loose on the rzr s this weekend and went for a 55 mile ride. It really made a huge difference in the ride over rough and rocky areas. It is a little tippy feeling at higher speeds and cant have as much fun sliding on gravel roads but the smoother ride in rough areas is gonna be worth it.
#37
Re: Sway Bar Poll
You align it with the suspension. On flat ground the holes should be close to lining up, if they are off a little you can have some rock the machine to one side a little until it lines up so the bolts go in easily..flexing the bar to get it lined up would be a pain.
#39
Re: Sway Bar Poll
With one side hooked up you then get the other aide hooked up..usually on flat ground it is close..then have some one rock it a little to get the other side last bolt in..not hard at all..unless maybe your springs sag VERY unevenly and it sits cockeyed on flat ground..in that case do it on a slope lol.
#41
Re: Sway Bar Poll
What about slow and hard as in mild rock crawling or is it due to the forces applied during turning at high speeds?
#42
Re: Sway Bar Poll
Frank how are they twisting? The front mount and the radius rods mount the arm of course..the radius rods should stop any twisting. I'm not understanding the sway bars roll in supporting the trailing arms? If that is part of the design ( swaybar needed to prevent trailing arm damage) I'm not crazy about that line of thinking lol.
![]() • Makin Trax Springs•Motoactiv Doors •Triple X Bench•DFR Harnesses •Polaris EPS•DWT Diablo Beadlocks•UTV inc Nerf Bars •DDP clutch kit•HL Radius Rods•Rhino Axles •Holz/UTV inc A-Arm Braces•Thunderhawk Hitch • SSV overhead• Polaris L&R Windshield/rear panel/top |
#43
Re: Sway Bar Poll
good info on the mounting bracket I left mine on seeing it was a support bracket, plus it has a slot for the muffler (on an S) like most have said above, depends on your riding, I ride slow rough terrain, with it off it rides much better...for my environment
Don't mistake lack of talent for genius....some people are just not talented... |
#44
Re: Sway Bar Poll
#45
Re: Sway Bar Poll
| Search tags for this page |
2011 ranger xp sway bar delete,2012 xp sway bar removal,adjust sway bar links on racer tech lift,best shocks for 2011 std razor with no sway bars,polaris 900 xp sway bar,polaris 900xp sway bar,polaris ranger stabilizer bar break,polaris ranger stabilizer keep it or loose it,polaris razor 800 sway bar disconnect,polaris razor sway bars....connect or disconnect,polaris rzr sway bar quick connect,remove sway bar add racer tech springs,removing xp900 sway bar,rzr without sway bars,rzr xp sway bar removal,rzr xp swaybar,rzr-s sway bar clevis pin,taking sway bar off rzr,where can i buy swingbar suzuki thunder,witch aftermarket clutch kit for rzr do i buy
| Thread Tools | |
| Display Modes | |
| New Poll: Which ECU do you have and do you like it? | Spicoli | Engine and Drivetrain | 29 | April 2nd, 2011 11:20 PM |
| **POLL Which color RZR do you have? POLL** | TH3APPL3GUY | General RZR Discussion | 59 | January 8th, 2011 01:10 PM |
| poll on what eng do you want ? | johnnycat8 | Engine and Drivetrain | 47 | September 15th, 2010 06:32 AM |
| Hubs, rear sway bar, battery + box, rear sway bar, XMF rear sway bar linkage w/heims | twvette | Polaris RZR Parts For Sale | 5 | June 30th, 2010 01:30 PM |
