How to remove and replace rear axles? - Polaris RZR Forum - RZR Forums.net
post #1 of 16 Old June 2nd, 2011, 09:40 AM Thread Starter
catalac's Avatar
My RZR: 2016 XPT
Member #15924
View catalac's Photo Gallery(0)
300M axles are here from Ricochet with cv's.
I've never changed axles on a atv/utv from looking on youtube it says basically after you clear the hub by removing the cotter pin and nut (which I can figure out) you basically just yank them from the case and jam the new one in untill it clicks in?
Would anyone have the associated pages from the service manual they could forward to me?
catalac is offline
post #2 of 16 Old June 2nd, 2011, 09:49 AM
Contact: 855-743-3427
Super ATV's Avatar
First Name: SuperATV
Member #7943
View Super ATV's Photo Gallery(0)
Re: How to remove and replace rear axles?
Basically you will remove the hub assembly if on the rear and it makes it easier if you remove the lower shock bolt and bungy both the upper a-arm and the shock up out of the way. Give your old axle and swift tug and it should pull right out. Next get your new axle with cv's, get it started into the differential and give it a nice swift hit with a rubber mallet on the outter cv to knock it into the differential.
If you are reffering to placing your stock cvs onto the 300m shafts here is a video how to do that as well:
SuperATV Official Website
10% Forum Member Discount Up to $400.00.
Just enter RZRFORUM code at checkout! No multiple forum coupon codes accepted.
Super ATV is offline
post #3 of 16 Old June 2nd, 2011, 01:37 PM Thread Starter
catalac's Avatar
My RZR: 2016 XPT
Member #15924
Excellent thanks for the info and the video, both axles came with cuts in the boots if you can believe it from who ever mounted the cv to the axles. I have to replace two of the boots from new.
catalac is offline
post #4 of 16 Old June 2nd, 2011, 02:25 PM
jpred1's Avatar
Member #1998
View jpred1's Photo Gallery(0)
New axles? If this is the xp forget about the a arm and shock deals. Remove wheel, remove trailing arms from hub, remove brake caliper, pull. Hub off. Yank axle out and pop new one in. Not sure on torque for the hub nut though. 8 bolts, thinking 15mm, hub nut, and the 4 on wheel.
2015 ranger 4 sale.
jpred1 is offline
post #5 of 16 Old June 2nd, 2011, 02:27 PM
jpred1's Avatar
Member #1998
Originally Posted by jpred1 View Post
New axles? If this is the xp forget about the a arm and shock deals. Remove wheel, remove trailing arms from hub, remove brake caliper, pull. Hub off. Now the other hub with 4 bolts and bearings . May be called carrier ?.Yank axle out and pop new one in. Not sure on torque for the hub nut though. 8 bolts, thinking 15mm, hub nut, and the 4 on wheel.
2015 ranger 4 sale.
jpred1 is offline
post #6 of 16 Old June 2nd, 2011, 04:27 PM
dirt deval's Avatar
Member #5619
View dirt deval's Photo Gallery(0)
I never removed the hub. I just removed the hub side of the radius rods. The hub nut. Then the trailing arm will pivot out enough for the axle to pop out of the rear end. Then slide out the other end out of the hub. I removed and replaced axles in under 10 min.
dirt deval is offline
post #7 of 16 Old June 2nd, 2011, 04:55 PM
jpred1's Avatar
Member #1998
Yea, thought about that. But didn't seem to want to do it. Also I like to give the axle a tug to make sure its locked in tranny.
2015 ranger 4 sale.
jpred1 is offline
post #8 of 16 Old June 2nd, 2011, 08:39 PM Thread Starter
catalac's Avatar
My RZR: 2016 XPT
Member #15924
Was an easy job to do, removed radius rods and hubs took 15 minutes to do the second one. Hopefully these guys are tougher.
catalac is offline
post #9 of 16 Old June 3rd, 2011, 12:11 AM
CashMoneyMan's Avatar
First Name: Steve
My RZR: 900 XP
Member #24503
View CashMoneyMan's Photo Gallery(0) Send a message via AIM to CashMoneyMan Send a message via Yahoo to CashMoneyMan
are your boots rubber or plastic?
CashMoneyMan is offline
post #10 of 16 Old June 3rd, 2011, 12:14 AM
King of crash!
Member #787
Steve. Karterr 44 is up at sand mtn for the weekend if your heading out for a ride....
johnnycat8 is offline
post #11 of 16 Old June 3rd, 2011, 04:27 AM
Super ATV's Avatar
Member #7943
I apologize I did not notice it was for the new XP900, but our fellow forum members cleared that up thanks guys.
post #12 of 16 Old June 3rd, 2011, 06:23 PM Thread Starter
catalac's Avatar
My RZR: 2016 XPT
Member #15924
plastic and being a canadian I laughed they are "made in canada" on the boots, guess I can't blame it all on china.
ps my bad Tyler I never stated 900 in the opening.
catalac is offline
post #13 of 16 Old June 3rd, 2011, 09:08 PM
AlbertanGP's Avatar
First Name: Dean
My RZR: '11 XP 900
Member #22904
View AlbertanGP's Photo Gallery(0)
Probably has to do with the fact that the same company makes them for Can Am and Polaris.
AlbertanGP is offline
post #14 of 16 Old June 3rd, 2011, 09:14 PM
AlbertanGP's Avatar
First Name: Dean
My RZR: '11 XP 900
Member #22904
Norm, how did those CVs look compared to the stockers? I went with LSR axles front and back for the lifetime warranty. But I wouldn't mind upgrading the CVs either. I think the upgrades should be axles, boots, and CVs in that order of importance. I'm convinced my boot tore because of the "plasticky" nature of it. Kimpex makes a nice generic rubber boot for the Rhino that is 10X more pliable, and it's cheap. I'm going to see if it will fit when I have mine apart next week. Have fun at Brule if that's where you're heading.
post #15 of 16 Old June 3rd, 2011, 09:57 PM Thread Starter
catalac's Avatar
My RZR: 2016 XPT
Member #15924
The cv's on the ricochet axles are stock polaris as best I can tell, I was worried about the cv's on one side but I think they were ok on disassembly, now I have spares... more parts on the shelf. I would have bought HD but they nor I could find any.
We are heading to west country tomm if the weather cooperates and rexburg next weekend if the weather cooperates.
catalac is offline
question on remove/replace crankshaft? thisrokz Engine and Drivetrain 2 April 15th, 2011 04:36 AM
Need to replace rear seal - need advice ArtVandelay Engine and Drivetrain 8 March 2nd, 2010 08:40 PM
should i remove rear sway bar? gto19 RZR-S Specific Discussion 16 January 18th, 2010 09:09 PM
Broke outer lower rear control arm bolt ... replace with? twvette Suspension 6 October 28th, 2009 11:26 AM
axles, need to replace 1...what to do 08 redrzr Engine and Drivetrain 6 July 22nd, 2009 06:51 PM
