Stock seat / Suspension seat Modification - Polaris RZR Forum - RZR Forums.net
post #1 of 15 Old May 4th, 2011, 08:41 PM Thread Starter
Hooty222's Avatar
First Name: FIX-IT-BOB
My RZR: White 2011 XP 975 / Aerocharged turbo / INFINITY ECU
Member #22075
View Hooty222's Photo Gallery(8)
Well the story goes like this..... Spent the extra money to get the fancy seats on my "white lightning" xp so I just couldnt throw them aside just yet.... I was at glamis with my 12yr old son and got alittle crazy in the whoop section and used up all the travel in the RZR... thus having my a** use up all the cushion, and make a nice sharp pain in my lower back... The xp is 99% of the time fine using the suspension but.... I made this MOD for the 1% I am driving faster than I should... Check it out... Send me a email if you need more info..
2nd seat: Well I built the other seat and took more pictures.... Key things are the using a sutable cutting tool (because the base has "ribs" to make the base strong) If your not good with tools dont mess with this die grinder / death machine. Possibly use a cutoff wheel or? That mini saw worked perfect for me, quick job of all plastic. Mark the opening with 3/4 wide electrical tape or? its hard to see but look for a ware mark from the seat base ... than lay the tape down for a guide. Cut open seat base and seat bottom, remove internal plastic piece (staples on that to hold seat cover, does not seem to change look of seat. Drill holes one inch apart, lace it up like a shoe (aprox 15 feet of parachute / bungee cord) Thats the quick version.
Hooty222 is offline
post #2 of 15 Old May 4th, 2011, 08:49 PM
Tuf-Skin's Avatar
First Name: Clifford
Member #2228
Re: Stock seat / Suspension seat Modification
how much does it help?
Tuf-Skin is offline
post #3 of 15 Old May 4th, 2011, 08:53 PM Thread Starter
Hooty222's Avatar
Member #22075
Not sure yet Just droping down on to it it seems worth the time and money.... Its not a Mastercraft but I know its got to be better than stock. Parachute cord was 10 bucks and it took about a hour to do give or take... cheap way for alittle give..
Hooty222 is offline
post #4 of 15 Old May 5th, 2011, 06:21 AM
rorhound's Avatar
My RZR: 2013 WE XP
Member #11315
View rorhound's Photo Gallery(0)
I'd also like to know how good it works. My cheeks are a little wider than that hole (and I'm not a fat a$$) so it will be interesting to find out how good it works. I like the idea for sure! Good job!
2013 WE XP, Alba BB & Stage II, Pro Armor Cage, Doors, Door bags, Harnesses & Steering Wheel, HRD Racing True Suspension Seats.
2012 27'CBG Attitude
2008 GMC 2500 Duramax
rorhound is offline
post #5 of 15 Old May 5th, 2011, 08:29 AM
hkunz's Avatar
My RZR: RZR XP LE
Member #25253
View hkunz's Photo Gallery(0)
OK, maybe I'm a little dense, but what did you do? I see the before and after pics, but can't get a sense of the steps.....
Please let me know, this is the weekend to work on my RZR before i take her out....
hkunz is offline
post #6 of 15 Old May 5th, 2011, 09:16 AM Thread Starter
Hooty222's Avatar
Member #22075
Ok nothing to tricky, just make a hole in bottom.... No to be serious I need to do the other seat I will take photos and explain from that.. Again its not a perfect answer to a real suspension seat... And I agree on that last comment my ass aint that small either but the seat gives better and there is a place for your tail bone to go instead of into hard plastic. After I do the pictures try it.... it might save some pain in your back.
Hooty222 is offline
post #7 of 15 Old May 5th, 2011, 01:41 PM
NorCalRider's Avatar
First Name: Toby
My RZR: 2011 XP Le
Member #9867
View NorCalRider's Photo Gallery(0)
Looking forward to seeing how you did this. Cant hurt thats foresure, no pun intended.
New machine coming soon
2011 XP Le 3/24/2011 Simpson 5pt, Diablo Beadlocks 12x7 4+3, 27x9x12 Bighorns all around, 10" Rigid, Polaris rock sliders, bimini top, bubble windshields, steering wheel, l-n-r gas can holder, 17" rearview, more to come SOLD
2011 XP Le 3/5/2011 Simpson 5 pt harness, polaris 3500 winch
2011 XP Indy Red arrived 3/5/2011 polaris 3500 winch, mirrors
NorCalRider is offline
post #8 of 15 Old May 5th, 2011, 02:46 PM
AlbertanGP's Avatar
First Name: Dean
My RZR: '11 XP 900
Member #22904
View AlbertanGP's Photo Gallery(0)
Same idea as the seat lowering bases the vendors sell for suspension seats. Should work as good as the stock seats will allow.
AlbertanGP is offline
post #9 of 15 Old May 5th, 2011, 03:58 PM Thread Starter
Hooty222's Avatar
Member #22075
Ok did the second seat.. hope that helps out. See the ORIG post above.
Hooty222 is offline
post #10 of 15 Old May 5th, 2011, 04:45 PM
First Name: Toby
My RZR: 2011 XP Le
Member #9867
Looks good, I like that your letting the boy do work . Quick question for you. I used to live in Flagstaff back in the 90s, is the cinder pits still there just northeast of the town? I used to live right across the highway from them and worked at the feed store there, back when I was in highschool. Wish I could ride out in the pits again. That was alot of fun growing up. I have heard Flagstaff has changed alot now.
post #11 of 15 Old May 6th, 2011, 04:26 PM Thread Starter
Hooty222's Avatar
Member #22075
Hey Toby, The cinders is still open, I live across from them also. Moved here in 05, Still is a small town. I from Pittsburgh Pa Orig. compaired to that its still a mellow place to live. Good luck on your seats. I dont think i am leading you down a bad path, cant hurt....
Hooty222 is offline
post #12 of 15 Old May 6th, 2011, 11:58 PM
First Name: Toby
My RZR: 2011 XP Le
Member #9867
Cool, I am going to have to get back that way some time soon. Alot of great memories of that place. I went to Coconino Highschool. That just popped into my head. Funny the things you forget. Thanks for the info.
post #13 of 15 Old May 8th, 2011, 06:30 PM Thread Starter
Hooty222's Avatar
Member #22075
This died on the vine...thought I would have had more takers, took out the Xp yesterday noticed a better feel in the seat. Wont know how it does on G-outs until dune season. But for sure a good cheap MOD.
Hooty222 is offline
post #14 of 15 Old May 16th, 2011, 07:57 AM
DoctahB's Avatar
First Name: Doc
My RZR: Gen 2 Greenie
Member #1012
View DoctahB's Photo Gallery(0)
How'd this seat work out for you? Have you had any trouble out of it? I'm thinking about doing this mod this week myself.
26" Maxxis Bighorns, Highlifter springs, Rubberdown 2" lift kit, Hunterworks 1.5" wheel spacers on the back, Warn 3500, Pre-runner bumper and rock sliders, F&R cv covers, Front swaybars off, Overfender mud flaps, DFR harness. HID's, Odessey battery, EPI clutch kit,
DoctahB is offline
post #15 of 15 Old May 16th, 2011, 12:33 PM Thread Starter
Hooty222's Avatar
Member #22075
So far so good. To me its worth the time. I just rode the rally on the rocks. Seemed to be better. Ahh just go for it.. good luck
Hooty222 is offline
Stock RZR seats / Suspension seat MODIFY Hooty222 Seats and Belts 13 December 3rd, 2013 06:40 PM
vent racing rear seat cage and bench seat Marc_0850rzr Polaris RZR Parts For Sale 5 August 14th, 2012 07:05 PM
Check seat belt locking mounts! Make sure they are not rubbing the side of the seat. Snaredrum General RZR Discussion 4 July 6th, 2010 06:42 AM
What's special about a suspension seat? guy48065 General RZR Discussion 6 March 22nd, 2010 05:18 PM
Suspension seat sold by JC Whitney khorton Seats and Belts 2 October 29th, 2009 10:54 AM
