Stuck in park?
This is a discussion on Stuck in park? within the RZR XP 900 forums, part of the General RZR category; I had to park on a steep hill behind my house. Not that bad but started spinning in loose soil and had my daughter in ...
RZR XP 900 The Polaris Ranger two-seat RZR XP 900 Forum on RZRForums.net.
Old March 20th, 2011, 04:33 PM
ArkGL01's Avatar
My RZR: 2010 RZR S
Member #10112
View ArkGL01's Photo Gallery(0)
Stuck in park?
I had to park on a steep hill behind my house. Not that bad but started spinning in loose soil and had my daughter in it so thought I be safe than sorry. Put it in park got her out and went to go pull forward and I have pulled and pulled on gear shift and it will not budge!!! Rocked it back and forth and everything. what am I going to have to do? Really made me mad cause if I was far off I dont know what I would do?
2011 XP 900 with a few mods...
Old March 20th, 2011, 05:17 PM
GIFF-TURBO's Avatar
Feedback Score: 18 reviews
First Name: Gary
Member #3946
Re: Stuck in park?
If rocking the RZR didn't do the trick check the linkage at the transmission the cable housings have been known to bend when aggressive force is used to pull it out of park
Old March 20th, 2011, 05:42 PM
ArkGL01's Avatar
My RZR: 2010 RZR S
Member #10112
Re: Stuck in park?
Just got it out had to tow it out.. pulled it about 3ft and finally came out of park but gees what a pain!!!
Old March 20th, 2011, 05:55 PM
atvobsession's Avatar
RZR Rock Crawler
My RZR: XP 900 LE
Member #20341
View atvobsession's Photo Gallery(0)
Re: Stuck in park?
I was towing mine back to the storage garage after removing the pipe to get Ceramic Coated. Paused on a hill and put it on park. Was stubborn to un park.
This thing really needs an emergency brake, before putting into park.
Regards,
Ken Hower
Rubicon Trail Foundation Director
KOH 1962
Old March 20th, 2011, 06:29 PM
Dilledille's Avatar
First Name: Neil
My RZR: 2008
Member #2977
View Dilledille's Photo Gallery(0)
Re: Stuck in park?
Some of the vendors on this forum sell a parking brake set up. They look like they work and are not to big a deal to install. I don't think they should have put a park on the gear shift if it doesn't work but it is there. When you apply your brake pedal at the first pivot point you will see a small space open about 1/4". I took a small piece of 1"x1"
1/4" angle welded a short handle on it. When I am in a steep parking area I apply the brakes and slip this in that pivot spot. It works great and simple to make. When you want to remove it just apply the brakes take it out and put in the box under your seat for the next time you need it.
2010 ranger rzr stuck in park
2011polaris xp 900 how to set the shift linkage
2012 polaris ranger e brake stuck
helps getting polaris ranger out of park on a hill
my ranger is stuck in park
polaris ranger 900 xp stuck in safe mode
polaris ranger stuck in gear
polaris razor 800 stuck in gear
polaris razor shifter stuck on hill
polaris razor stuck in park
polaris rzr stuck in park
polaris sportsman xp stuck in gear
rzr gear shifter applying brake
rzr stuck in park
why does my polaris dye when i shift out of park
St. Joe Park, Park Hills, MO. Labor Day 2011 Ride. Snaredrum Local Rides and Events 29 August 17th, 2011 05:56 PM
Sabine ATV Park --- New ATV Park in East Texas texasboy General RZR Discussion 29 March 2nd, 2011 06:09 PM
STUCK!!! Matt20o6 Muddin' 16 July 27th, 2010 04:05 PM
Tranny stuck in park drprunner Engine and Drivetrain 14 November 1st, 2009 06:23 AM
