Reported XP 900 issues and fixes - Polaris RZR Forum - RZR Forums.net
post #1 of 10 Old March 1st, 2011, 04:40 PM Thread Starter
Tuf-Skin's Avatar
At the request of the membership this thread has been started to list issues that owners of the new RZR-XP have experienced. Hopefully this will give new XP owners a place to look for things they can check quickly and easily.
This thread will be locked and only reported issues and fixes will be listed. This will keep the thread shorter and easier to read without random comments. If you would like to report an issue do so in the "report XP problems thread": http://www.rzrforums.net/ranger-rzr-...lems-here.html
If the membership deems your report worthy, it will be added to this thread by a moderator.
We'll see if this works!
Tuf-Skin is offline
post #2 of 10 Old March 1st, 2011, 04:46 PM Thread Starter
Tuf-Skin's Avatar
re: Reported XP 900 issues and fixes
Some RZR-XP were delivered with a negative battery cable disconnected.
There should be two connected to the battery. If the dealer forgets to connect it, the RZR will run for a while, but the battery will not be charging and will eventually go dead leaving you stranded. Make sure they are both connected.
Tuf-Skin is offline
post #3 of 10 Old March 1st, 2011, 04:53 PM Thread Starter
Tuf-Skin's Avatar
The owners manual says to grease the rubber gasket edge on the air intake filter.
There are debates on wether or not this is required. Decide for yourself.
Tuf-Skin is offline
post #4 of 10 Old March 1st, 2011, 04:54 PM Thread Starter
Tuf-Skin's Avatar
You may want to upgrade the spring style clamps on the coolant and oil lines.
Originally Posted by rzrguy67 View Post
Not sure if this has already been mentioned.
Behind the passenger seat there is a water hose (see pic)
this hose has spring clamps they need to be replaced with a regular hose clamp.
There is quite a bit of pressure when you are on the throttle (put your hand on it and rev it up the hose swells) Any way mine blew off yesterday i noticed the steam right away and shut down. I was lucky i had people with me so i was able to go get clamps and coolent and fix it on the dunes. Very easy cheap fix but it will ruin your day if you are out riding.
I also wanted to mention that we had 2 other xp 900's in our group that were bought from a differnt dealer 2 weeks after i bought mine and the dealer had slid the spring clamps down and installed standard hose clamps (slid them down so he could install clamp without draining coolent)
Not sure if thier was a service bulletin or he had a few come in with that hose blown off.
Tuf-Skin is offline
post #5 of 10 Old April 4th, 2011, 11:34 AM Thread Starter
Tuf-Skin's Avatar
There have been a couple reports of plastic melting/burning behind the passenger seat where the exhaust headers come close to the plastic.
Until Polaris responds, you may want to add an aluminum heat shield or header blanket like some members have done:
Originally Posted by milosusa
Also note that the clutch exhaust blows air over the engine exhaust header to cool it, so snorkeling the clutch may cause problems unless this is considered.
Some snorkel kits are coming with heat shields:
Originally Posted by AlbertanGP
[*]Header Heat Shield - The install video explains the importance of the supplied heat shield in the absence of air from the belt exhaust flowing over the headers after snorkelling. Be aware that there have been some serious problems with heat from the header melting or even burning the plastic behind the seats. While you have the rear fenders and bed off, it might be a good time to look into some additional heat reduction. Options include exhaust wrap, ceramic coating, or header blankets.
Tuf-Skin is offline
post #6 of 10 Old September 13th, 2011, 03:41 PM Thread Starter
Tuf-Skin's Avatar
A forum member reported that a "service bulletin" from Polaris has come out regarding a factory heat shield to install on the XP.
Check with your local Polaris dealer.
this has turned into a full recall for the 2011 RZR-900-XP: http://www.polaris.com/en-us/company...?articleID=142
Tuf-Skin is offline
post #7 of 10 Old August 28th, 2012, 09:52 AM Thread Starter
Tuf-Skin's Avatar
A few members have reported that the stator wires were routed on the wrong side of the coolant hoses and are getting too hot next to the exhaust. check yours before they melt!
Tuf-Skin is offline
post #8 of 10 Old August 28th, 2012, 10:11 AM
Feedback Score: 18 reviews
GIFF-TURBO's Avatar
I found the same crispy wires on my 2012 XP900
GIFF-TURBO is offline
post #9 of 10 Old August 28th, 2012, 12:31 PM Thread Starter
Tuf-Skin's Avatar
Apparently there was a change made on the valve springs.
Some 2011 and 2012 RZR-XP owners can have Polaris dealers change them out at no charge.
Call your dealer with your vin# and see if your XP qualifies.
#10 = 7043919 Spring, Valve [Built 4/10/12 and After]
#10 = 7043745 Spring, Valve [Built 4/09/12 and Before]
Tuf-Skin is offline
post #10 of 10 Old January 27th, 2013, 06:36 PM Thread Starter
Tuf-Skin's Avatar
There is an issue on some 2013 XP models where two bolts that hold on the skid plate are too long and can possibly puncture the oil pan if impacted when riding. Polaris has been mailing out shorter bolts with instructions to those that purchased these units.
Tuf-Skin is offline
Closed Thread
