Recommendations when lifting XP900 - Polaris RZR Forum - RZR Forums.net
post #1 of 5 Old January 9th, 2017, 10:34 AM Thread Starter
jeremyb2001's Avatar
Member #124033
View jeremyb2001's Photo Gallery(0)
Hello,
I am planning on doing a Rubberdown Customs 2.5 inch lift on my Xp soon. The Xp has quite a bit of weight on the stock Fox shocks and springs.
Would you recommend doing anything with the factory shocks and springs?
Would you recommend a different lift then the Rubberdown Customs setup?
jeremyb2001 is offline
post #2 of 5 Old January 9th, 2017, 11:38 AM
Ruko's Avatar
First Name: Rob
My RZR: 2013 900XP W.E.
Member #47257
View Ruko's Photo Gallery(0)
Re: Recommendations when lifting XP900
I have the Rubberdown lift and it has been great. I originally had my shocks cranked up for a little extra height. With the lift installed I was able to lower the shocks back down so the ride improved and I still maintained the ground clearance. I am still using the stock shocks however my are the Walker Evans.
Ruko is offline
post #3 of 5 Old January 9th, 2017, 05:01 PM Thread Starter
Member #124033
Here is a picture of the 900.
post #4 of 5 Old January 11th, 2017, 12:47 PM
Ruko's Avatar
First Name: Rob
Member #47257
Looks like yours is sitting pretty low. Are your shocks backed off? Here is a picture of mine from about the same angle before I installed the lift. So that was all stock but with the shock pre-load turned up a little. Your machine may be a little heaver with the front cage extension but it shouldn't be that much different.
Ruko is offline
post #5 of 5 Old January 11th, 2017, 01:02 PM Thread Starter
Member #124033
The shocks are backed off quite a bit.
VisionX RZR XP900 (11-14) Headlight Kits NOW In Stock! AlternativeOffroad Lighting, Stereo and Electrical 2 December 18th, 2016 02:09 PM
2011 xp900 dranger962000 Polaris RZRs For Sale 2 December 4th, 2016 05:14 PM
Xp900 stud size tmaxxman21 General RZR Discussion 1 September 20th, 2016 11:38 AM
fuel customs intake on xp900 bajarzrxp RZR 900 Engine 0 April 8th, 2016 08:55 PM
Stainless Lifting eyes for clip in harnesses? Justintoxicated Roll Cages and Safety Equipment 16 January 6th, 2016 02:58 PM
