Xp secondary clutch removal need help - Polaris RZR Forum - RZR Forums.net
This is a discussion on Xp secondary clutch removal need help within the RZR XP 900 forums, part of the General RZR category; I'm taking my motor out to upgrade some internals and my secondary clutch won't come off the shaft, I have beat it with a rubber ...
Old September 18th, 2013, 01:15 PM   #1
raptor02's Avatar
First Name: Shelby
My RZR: 12 TURBO RZR XP
Member #5392
View raptor02's Photo Gallery(1)
I'm taking my motor out to upgrade some internals and my secondary clutch won't come off the shaft, I have beat it with a rubber hammer sprayed it with pb blaster overnight I used a puller and pushed on the shaft while having no luck getting it off? I need some ideas
2012 RZR XP K&T Turbo
raptor02 is offline   Reply With Quote
Old September 18th, 2013, 01:18 PM   #2
Feedback Score: 176 reviews
swingarm1's Avatar
First Name: Tim
Member #7690
Re: Xp secondary clutch removal need help
Dead Blow Hammer, hit it at 12, 3, 6, 9 rotate it and do it again , keep repeating these steps until it breaks free and you can remove it...
Once off clean the shaft really good, including the splines, apply a micro amount of anti-seeze then re-install clutch when your ready...
Old September 18th, 2013, 07:53 PM   #3
raptor02's Avatar
First Name: Shelby
Member #5392
I tried you method with no luck ?
Old September 18th, 2013, 07:55 PM   #4
Feedback Score: 14 reviews
dartersracing's Avatar
First Name: DONNY
My RZR: 2014 PACE Z1 1000
Member #19554
Do you have a good snap on dead blow hammer..your not hitting it hard enough..
2014 PACE OFF ROAD BUILD Z1 complete
2016 XPT for US! Trail car
DC IMPORT SERVICE INC
Manteca Ca
dartersracing is offline   Reply With Quote
Old September 18th, 2013, 07:56 PM   #5
swingarm1's Avatar
First Name: Tim
Member #7690
That would be a first...
Old September 18th, 2013, 07:58 PM   #6
Blazonic's Avatar
First Name: Daniel
My RZR: 900 XP
Member #37628
View Blazonic's Photo Gallery(1)
did you take the bolt off first?.... Sorry, I had to.
I ran into your problem once and did like has been said for about 45mins and finally was able to get it off.
Blazonic is offline   Reply With Quote
Old September 18th, 2013, 08:01 PM   #7
First Name: DONNY
Member #19554
I just pound the center & keep spinning it & pops off..there is always something new to happen to keep life exciting..
Manteca Ca
Old September 18th, 2013, 08:06 PM   #8
raptor02's Avatar
First Name: Shelby
Member #5392
Well I already broke the corner of the clutch using a puller so I haven't been holding back on how hard I hammer it, every time I take this thing apart something breaks in the process! Not fun, I even cut the plastic clutch cover on the back so the whole thing is exposed i have beat on the front beat on the back preyed on it, I might try to heat it up and hit it some more. I'm about out of ideas
Old September 18th, 2013, 08:07 PM   #9
raptor02's Avatar
First Name: Shelby
Member #5392
Haha
And yes I took the bolt off
Old September 18th, 2013, 08:11 PM   #10
clintSullivan's Avatar
Member #51704
View clintSullivan's Photo Gallery(0)
do you have the right clutch puller, the one that's made for the xp secondary
clintSullivan is offline   Reply With Quote
Old September 18th, 2013, 08:25 PM   #11
swingarm1's Avatar
First Name: Tim
Member #7690
There isn't a clutch puller for the XP secondary...
Old September 18th, 2013, 08:27 PM   #12
jsandgren10's Avatar
First Name: Jeff
My RZR: 2014 RZR XP4 1000
Member #19949
View jsandgren10's Photo Gallery(0)
Put some wd40 or some equivalent and squirt it in there. You don't have to hit it hard just let it set for 15min after you squirt the wd40 and then give it some good taps around the roller areas and it will pull off
There is no puller for the secondary. I also put a little anti seize on the shaft when I put secondary goes back on and never had an issue removing after
2011 RZR-XP 900, Factory UTV skid, UTVinc goodies, Lock and Ride box, Twisted Stitch Revolver Seats, Toysforbig boys Cage, 28x10x14 Mongrels, Alba Stage 2, Rugged Radios-SOLD
2014 RZR-XP4 1000 White-UTVinc harnesses and switches, heated seats, Rugged Radios, XTR GPS, Holz Racing fuel cans, Light bar, Polaris roof, Polaris Glass Windshield, Shock therapy Stage 2, Method Standards with ITP Ultracross R spec-SOLD
2016 Turbo RZR 4 - PRP GT seats, Shock Therapy Stage 4, S&B Particle Separator, Desertcraft clutch fan and intake relocation, XTR GPS, Polaris Glass windshield, Light bar, Method Standard wheels with Maxxis Liberty tires, ISOTA rear box
jsandgren10 is offline   Reply With Quote
Old September 18th, 2013, 08:27 PM   #13
swingarm1's Avatar
First Name: Tim
Member #7690
Don't heat it or you'll screw the seal behind it up from heat transfer through the shaft...
Old September 18th, 2013, 08:51 PM   #14
raptor02's Avatar
First Name: Shelby
Member #5392
I wondered about that
Old September 19th, 2013, 08:41 PM   #15
raptor02's Avatar
First Name: Shelby
Member #5392
Well I went back out to the shop to tonight to try and get the clutch off I soaked it again with on blaster and hit it hard, cause I know everyone was concerned about my hammer size or if I was hitting hard enough and no luck just more carnage see attached video
Still looking for ideas
1000 xp rzr secondary clutch spring removal
2015 rzr 900s secondary clutch removal
2016 xpt clutch tool
do you need a puller to take of the secondary clutch in a polaris razor
how to remove secondary clutch on polaris rzr
how to remove secondary clutch polaris 900 rzr with pic steps
how to take out the secondary spring clutch 2013 xp
polaris ranger 900 xp clutch removing secondary
polaris secondary clutch puller
ranger 900 xp secondary clutch removal
remove secondary clutch on xp 900
remove stuck polaris 1000 secondary clutch screw
rzr 1000 secondary clutch wont come off
rzr 1000 secondary shaft
taking secondary clutch off rzr 1000
secondary clutch bobby25514 Engine and Drivetrain 2 July 23rd, 2012 10:12 AM
WTB Secondary Clutch buckethead Want to Buy 2 February 26th, 2012 04:13 PM
secondary clutch backwoods_rzr General RZR Discussion 2 July 24th, 2011 05:53 PM
$5 dollar secondary clutch spring removal tool mjackson Engine and Drivetrain 9 December 2nd, 2010 04:02 PM
need secondary clutch chrisrzr Polaris RZR Parts For Sale 2 April 4th, 2010 08:38 AM
